Test/Review of LG 18650 HB2 1500mAh (Green)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
DSC_8609
Official specifications:
  • Nominal Capacity: 1500mAh
  • Minimum Capacity: 1400mAh
  • Nominal Voltage: 3.65V
  • Max. Charge Voltage: 4.2V
  • End voltage: 2.50V
  • Max. discharge: 22A
  • Diameter: 18.30mm ± 0.05mm
  • Height: 65.00mm ± 0.15mm
  • Weight: 47g ± 0,01g
LG%2018650%20HB2%201500mAh%20(Green)-info
This is a high current battery with fairly low capacity.
DSC_8608
DSC_8610 DSC_8611
DSC_8612
DSC_8613
LG%2018650%20HB2%201500mAh%20(Green)-Capacity
The two cells tracks very fine and the capacity does not change much with load.
LG%2018650%20HB2%201500mAh%20(Green)-CapacityTimeHours
LG%2018650%20HB2%201500mAh%20(Green)-Energy
LG%2018650%20HB2%201500mAh%20(Green)-PowerLoadTime
LG%2018650%20HB2%201500mAh%20(Green)-TripCurrent
LG%2018650%20HB2%201500mAh%20(Green)-Charge
Conclusion
The cell works very well, a few years ago the performance would have been very good, but today you can get cells with more capacity that can deliver the same high current.
Notes and links
Compare to 18650 and other batteries
DavidEF
DavidEF's picture
Last seen: 1 day 10 hours ago
I’m wondering why they even still make such a low capacity cell. Surely there is little or no profit.
- The YKK Philosophy
HKJ
HKJ's picture
DavidEF wrote:
I'm wondering why they even still make such a low capacity cell. Surely there is little or no profit.
It was probably designed a few years before the 2500mAh high current cells.
Also remember that equipment with this battery designed in will need a lot of work (Documentation, certification) if they want to change to better cell.
shadockan
shadockan's picture
Last seen: 1 month 1 week ago
Ι think this is an *IMR *cell.
The 2500mAh is IMR/INR.
30 Amps from 2500 IMR/INR is difficult . From *1500mAh IMR *it’s not so difficult.
Sorry if I’m wrong.
HKJ
HKJ's picture
shadockan wrote:
Ι think this is an *IMR *cell. The 2500mAh is *IMR/INR*. 30 Amps from *2500 IMR/INR* is difficult . From *1500mAh IMR *it's not so difficult. Sorry if I'm wrong.
In the datasheet the chemistry is listed as: Li[NiMnCo]O2 (NMC)
shadockan
shadockan's picture
Ooooppss ……
My mistake .
Thanks HKJ
