D.I.Y. Illuminated tailcap
1813 posts / 0 new
djozz
djozz's picture
Last seen: 7 hours 13 min ago
btw, the pot I linked is 3x3.5mm, should fit your pads Smile
djozz
djozz's picture
pilotdog68 wrote:
I guess I don't understand the circuit, pyro. The diode is just on one led? What does the back of the board look like?
From Oshpark:
pyro1son
pyro1son's picture
Last seen: 10 months 1 week ago
It occurred to me that the layout wasn’t optimum
Pastebin                                      &nbs
pilotdog68
pilotdog68's picture
Hey pyro, where did you get your library part for the pot? I want to try playing with it tonight. Yours looks good! So the diode is to protect if the pot is left fully “open”? I’m wondering if it might be better to put a 500ohm or 1kohm resistor for that instead. In the past the diode in series has made the light drop off too fast as the battery gets low.
pyro1son
pyro1son's picture
I can change the pad then people can choose what they use but your right a resistor may work better, but wouldn’t give polarity protection.
Pastebin                                      &nbs
pilotdog68
Yeah I wasn’t thinking about reverse polarity. I tend to put my batteries in the correct way Wink Oops
pyro1son
pyro1son's picture
Yeh so do I but you never know
.lbr file is here
Thinking of just making an order of some then measuring and making sure before any boards are ordered. What value are we thinking 20k? 50k?
Pastebin                                      &nbs
djozz
djozz's picture
pyro1son wrote:
Yeh so do I but you never know .lbr file is "here":http://forum.arduino.cc/index.php?PHPSESSID=luta6krda4f5g79mnpqe96k3n3&a... Thinking of just making an order of some then measuring and making sure before any boards are ordered. What value are we thinking 20k? 50k?
To be able to make it really dim definitely 50K, perhaps even 100k (you can always set it lower)
Polarity protection is only needed with the pot fully open I guess? In that case when setting the pot you have to be careful, when it is set you can just put in your battery the wrong way around with no damage to the tail leds?
pyro1son
pyro1son's picture
I use clear perspex spacers so can get away with even lower brightness and longer run times I’m leaning towards 50K then use the D1 pad to set the lowest available value around 10K
Pastebin                                      &nbs
pilotdog68
where do you get that perspex? Wouldn’t the LED’s themselves be reverse-polarity protection?
pyro1son
pyro1son's picture
Yes I suppose that’s true. They are the ones from aliexpress
Pastebin                                      &nbs
djozz
djozz's picture
I make the spacers myself, I have a chunk of 2mm clear perspex. Drill a 7.5mm hole, saw a squarish piece around it and then sand it round to size with the disc-sander.
pilotdog68
Would you mind posting a link? The link I had in the op originally now redirected to a completely different product, so I deleted it.
Thanks
pyro1son
pyro1son's picture
HERE
Took me a while to find
Pastebin                                      &nbs
pilotdog68
pyro1son wrote:
HERE
uhh is the brown just a peel off paper or something? I think that’s the link I had originally, but the pictures used to show clear
pyro1son
pyro1son's picture
Oh that’s not right! Bare with me!
Appears they no longer stock them. I have quite a few if you’re in need.
Found! HERE
Pastebin                                      &nbs
pilotdog68
lol that looks better. Do those require any trimming at all?
pyro1son
pyro1son's picture
I haven’t had to trim any so far but depends on the light being used.
Pastebin                                      &nbs
pilotdog68
Cool. The smaller ones from Home Depot I always have to increase the interior diameter a bit to fit over the switch.
Rufusbduck
Rufusbduck's picture
What Home Depot dept? I have a step drill.
Scott
pilotdog68
They’re nylon washers, in the hardware/screws/nails aisle at my home depot. I also use a step bit to drill out the middle.
They’re not exactly clear, but they help to diffuse the light more evenly under the boot at the cost of some efficiency.
Linked at the bottom of the OP
Rufusbduck
Thanks. I think Orchard Supply might also have them. That’s where I normally get nylons. Wink
Scott
pilotdog68
A while ago I realized 17mm was still too big for many lights. A few months later, I have finally gotten around to shrinking the pcb down to 16mm. While I was at it, I enlarged all pads bigger than they were on v3, and added the pot footprint (thanks pyro for the idea and .lbr). Also, instead of adding 1 or 2 more vias, I made all vias much larger than before. The only negatives I can think of vs the 17mm v3 board are:
- The two sides are now dependent, you can’t just cut a trace and have two distinct circuits
- The spring pad diameter has gone down from 10mm to 9.5mm
As always, let me know if you see any errors.
pilotdog68
I was thinking about doing one with the pot right in the middle of the spring pad. Thoughts?
My initial concerns:
I don’t know if the pot case is electrically neutral
It would make spring bypasses more difficult
cajampa
Last seen: 5 years 7 months ago
The kind of spring bypass i do with silicon wire shouldn’t connect to the casing of the pot if the spring dosen’t bottom out, are you thinking of copper braided spring bypasses?
We could always do spring bypasses on the outside if the pot where in the way.
pilotdog68
I think a slider switch in the middle of the spring is a better idea, but the switches I have are just barely too big. Has anyone found a switch smaller than 6.75*4.5mm?
mattlward
mattlward's picture
Last seen: 4 hours 13 min ago
I really like that last design, with the pot in there, it could be fine tuned or one could even eliminate the fixed value resistor with a jumper and only tune the pot. Maybe a thru hole behind the pot to allow for adjustment without taking it all apart? Please?
Matt
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
pyro1son
pyro1son's picture
I’m not 100% on which pads we need to be using for the pot. I think the way you have it set at the moment will be fixed at the maximum value of the POT
Pastebin                                      &nbs
pyro1son
pyro1son's picture
It occurred to me this morning that as long as the bleeder resistor is on the cap after the D1 on the driver board we would still have reverse polarity protection.
Pastebin                                      &nbs
djozz
djozz's picture
mattlward wrote:
I really like that last design, with the pot in there, it could be fine tuned or one could even eliminate the fixed value resistor with a jumper and only tune the pot. Maybe a thru hole behind the pot to allow for adjustment without taking it all apart? Please? Matt
Hmm, you're on to something here Smile . But in an assembled tail, the hole would be behind the retaining ring. How about a version with the pot on the spring side, right in the middle? The middle contact of the pot can be made the batt-minus to that contact with the compressed spring is allowed.
(artist's impression:)
