D.I.Y. Illuminated tailcap
1813 posts / 0 new
Halo...
Halo...'s picture
Last seen: 5 years 10 months ago
You want the highest Luminous Intensity. That usually gets you the highest brightness even at very low currents. For example most blue 0603s are rated at 20ma but the Luminous Intensity of different ones range from 3.6 mcd to 180 mcd. Best to pick one from the higher end. Though you should double check (using the datasheet) that the mcd listed is for the actual part number mouser is selling. Occasionally there is a mistake where the specs listed are actually for a higher bin.
emarkd
emarkd's picture
Last seen: 1 week 6 days ago
I haven’t messed with my blue S2+ again. I’m really very happy with it as-is, although the drain through the tailcap is a bit high. Still, it would take about a month to drain the battery just sitting on the shelf and I find that acceptable. And yes, I used the smaller board in there. It looks like this stacked up on top of the original switch:
I did start on my red S2+, however. Same bleeder resistor on the driver and it works great. I made a silly mistake though – I assumed the LEDs that look red when powered off would also look red when powered on. They don’t…
So I’ve gotta work on that one a bit more :/
pilotdog68
pilotdog68's picture
I notice there isn’t a white ring around the middle of the board there. Did you drill it out or did Oshpark print it that way?
emarkd
emarkd's picture
I didn’t modify the board at all. They came like that. Here’s a shot of my whole shipment of PD-boards all dumped out on the table:
Is there some issue with them? Or is the change only cosmetic?
pilotdog68
No, if they’re working at all it’s fine. I probably put that line too close to the edge. The “2” channel has a trace closest to the center on the bottom, but obviously it’s working fine.
zoom zoom
Last seen: 3 years 5 days ago
I like to split larger orders into several smaller orders so I get moar stickers! They have always shipped the same time lol..
264
264's picture
Last seen: 2 years 4 months ago
Sorry if this question has been asked or answered before. Can you make these very cool lighted tail caps for customers like me?
Thanks.
wight
Last seen: 2 years 3 months ago
Thanks.
Answered in the OP: “I am not currently taking orders for them.“ :-/
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
pilotdog68
One reason for that is it is rarely a drop-in upgrade. Many times it requires fiddling with the driver or at least fiddling with the tailcap stack to get the light working again. So it’s usually much better to work on a complete light than just sell the tailcap parts. Shipping a light back and forth adds at least $10 to a mod.
The second reason is that I don’t have the time to build as many as I think there would be demand for, and I don’t feel right saying yes to some people and no to other people.
But like I said in the OP, I’m sure someone would do it for you for the right price.
DrafterDan
DrafterDan's picture
I tried to sell one of my spares on Panjo some weeks ago. zero interest.
I’m using it to build up a C2 style solarforce to gift to a friend
have light, will travel
mattlward
mattlward's picture
Last seen: 1 day 7 hours ago
Well crap! I have an S2+ that is my EDC and I decided to try out one of the new washer replacement tailcap boards. Got it build, it ohmed out well and all of the leds lit on my bench supply. So, I took the 2 led switch out of my S2+ and replaced it with this…
!2016-02-25_08-26-58!
It lit up and worked well, for a while.
!2016-02-25_08-22-51!
Then I lost mode switching! If I very quickly lock out and lock in the tailcap it will switch modes. But, if I half press the reverse clicky it will not switch modes to save it soul now.
What the hell? My meter sees an open on a half press with it mounted in the tailcap. I used 4.7k resistors, so now it would be seen as 3*4.7k in parallel?
Any ideas? Can a switch go bad this way?
Matt
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
mattlward
mattlward's picture
Well, after spending more time with this… the 4*7135 in this light does not like this board even though it is currently working with a 2 blue led board. But, this board works fine in my JAX C8 Mini with an 8*7135 board. These things could lead to drinking on a bad night! It also did not work properly in the BLF X5, mode changes were wonky.
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
emarkd
emarkd's picture
I finally got boards built for all of my colored S2+ lights.
All are the 14mm v5.1 ring boards used in place of the metal washer that was in there. Looks like this all mounted up:
All of them are using color-matched 0805 emitters, obviously. Resistor value varies greatly between them, from 5.9Kohm for the blue down to 1.5 Kohm for the red. Yes that means the red isn’t very efficient, but I didn’t build them for practicality. They’re fun! All of them have MtnElectronics 105C drivers with varying numbers of 7135s depending on the emitter in the light, and all flashed with GuppyDrv. They all work as expected after I got the bleeder resistor value worked out, 220 ohms in my case. I connected that bleeder resistor directly from V+ to GND right here:
Since I had to remove the original black rubber piece that provides all the waterproofing in the tailcap of this light, I added some nylon rubber I cut from a disposable glove. I put it directly under the switch assembly, like this:
I haven’t tested it yet so I have no idea if that works or not, but it looks…reasonable. Would probably be better without the crease in there but they all did that when I screwed them down.
I’ve shared this before elsewhere but here’s a bonus shot of the other end of these lights.
This is fun! Thanks PD and everyone else involved in this project!
wight
Nice, thanks for the pics!
pilotdog68
The green one looks especially nice
djozz
djozz's picture
Last seen: 5 days 16 hours ago
Really goodlooking! 8-)
emarkd
emarkd's picture
Thanks, the blue one is nicer than it looks in the photo. It slightly overexposed here because its really still the brightest of the bunch, but I’m kinda tired of tearing it down and swapping those resistors. Smile They’re not exactly in an easy spot to get to on those boards. Maybe I’ll increase those another step or two one day when I’ve got nothing else to do. But for now I’m very satisfied with how they turned out.
vinte77
I need some help… I have rev. 3 board and for some reason I can’t get 2 lights to work on the board. I can only seem to get only one of the leds to light up. Below is a picture of the switch side of the board. Any insight would be appreciated.
akhyar
akhyar's picture
Last seen: 3 hours 12 min ago
Really good looking tailcaps there emarkd
pilotdog68
Vinte did you mean to put the LEDs on the resistor pads and vice versa?
vinte77
No, I didn’t. So I have the LEDs on the resistor pads and the resistors on the LED pads? No wonder it’s not working right! Thanks.
thijsco19
Last seen: 2 days 9 hours ago
Afiak that isn’t the reason that it isn’t working, a resister can be placed before or after a LED. (Correct me if I’m wrong)
Did you place the LEDs the correct way? Positive on the + side?
pilotdog68
You’re right, but I don’t remember exactly how I had the traces laid out on that board, so using the resistor pads I don’t know the polarity. However, the polarity is marked for the LED pads
vinte77
How can you tell which side is positive (since it so small)?
Microa
Last seen: 4 hours 45 min ago
It seems that one of the LED was mounted in reverse. Usually the end with green mark is the cathode (negative). Correct the way of that LED did not light up.
vinte77
So the side with the green mark attaches to the board? Or the side with green make needs to be oriented in a certain way while being attached to the board? Both LEDs are attached to the board with the green side down.
- so I found a diagram online showing which side of the led is positive but it still only one led lights up
thijsco19
I think that the left led has to be reversed.
Microa
I found the photos at #592. Both of the cathodes of the LED are pointing to the centre. So your LED at the right side was mounted in the reverse way.
thijsco19
This is how I see it.
The positive side of the right led pad is at the bottom, so the cathode has to be pointed up. Like the way it is now.
But the other led pad is reversed, e.g. the positive is pointed up. That led has now the cathode pointed up (‘at the positive pad’).
Microa
thijsco19, you are right. The cathode of the LED at the left side should be pointed down ward. My distake.
