D.I.Y. Illuminated tailcap
1813 posts / 0 new
davidkappelt
Last seen: 2 years 4 months ago
If you jump P I dont think you have to jump both resistors, but maybe I am wrong, yeah try it outside the flashlight exactly how u said.
gchart
gchart's picture
Last seen: 57 min 54 sec ago
Jumping P doesn’t really make any difference in this situation. It’s just used when you’re using 6 LEDs and want to run them off a single resistor (or single jumped resistor pad).
Yeah, try a bench test. Hook up your negative lead to the spring. Connect positive to the grounding ring. *** Make sure the switch is off or you’ll end up with a short & sparks! ***
davidkappelt
I am having problems. I built a complete 5.3 with a 5k ohm resistor on both channel. I bypassed one pot and that whole setup works great. When I put it in the flashlight everything works OK but when I turn the light off and then back on it acts as if I do a long press. I am using a MTN FET+1 driver and have a 500 ohm bleeder. Should I go lower and how much lower. Also if anyone could recommend where to put the resistor that would be great.
mattlward
mattlward's picture
Last seen: 10 hours 4 min ago
None of the H17f drivers I have in lights with lighted tailcaps need a bleed resistor. I always use a 560 on the driver and adjust the tailcap resistors to control brightness.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
davidkappelt
So I can just get the H17F driver from mtn and not worry about a bleeder?
mattlward
mattlward's picture
So far, that has been the case for me. I have 3 running that way, but YMMV
EDC rotation:
FW3A, LH351D 3500k
ToyKeeper
ToyKeeper's picture
Last seen: 10 hours 11 min ago
I want to fit fancy lighted tailcaps into some of my lights, but a 19mm board won’t fit. I don’t suppose anyone has found a way to fit the rev6 smart board into a 17mm form factor for common tube lights?
The voltage divider isn’t really needed since the MCU can sense voltage on its VCC pin, so that saves a bit of space and reduces overall power use. And if necessary, a smaller version of the MCU could be used, with pins extruded to pads or vias for reflashing bed-of-nails style.
Is this a thing anyone has attempted? I like the idea of a smart tailcap light, but 19mm doesn’t fit in very many hosts.
mattlward
mattlward's picture
Tk, I have not tried to shrink it. It is above my abilities with eagle… I did get one of them to sort of run with your firmware but never did get a true usable result. Has the firmware matured for the smart boards and I just did not see that in the monster thread?
EDC rotation:
FW3A, LH351D 3500k
ToyKeeper
ToyKeeper's picture
I’ve never gotten to try a smart board, so the code is mostly just a shot in the dark. The closest I’ve seen to it actually working was on a Ferrero Rocher driver, where it blinked the two indicator LEDs and the main LED in patterns.
To actually get it working for real, I would need some hardware to test it on… and I haven’t tried to build one yet.
mattlward
mattlward's picture
I could send you a build one… I may have one still assembled.
EDC rotation:
FW3A, LH351D 3500k
ToyKeeper
ToyKeeper's picture
I would definitely not complain. Smile
At 19mm I doubt it’d fit in any of my current hosts, but it should still work fine for testing purposes.
KFulton
Last seen: 2 years 5 months ago
Texas_Ace wrote:
Although most if not all the issues with the lighted tailcap stem from the use of the OTC. The latest firmware that is being worked out should eliminate the OTC and thus fix all the lighted tailcap issues along with all the timing issues.
I built a TAv1 with OTSM (Bistro-HD) last night with a 500 ohm BR, and a rev 5.1 tailcap with a 63k ohm resistor on each of the 3 channels. It’s almost perfect, but occasionally short presses are interpreted as medium presses (opposite from the usual problem I have with these tailcaps).
Any idea if I should I try more resistance or less on the bleeder to fix this? It’s kind of a pain to replace the BR on this board, so I thought I’d ask here first.
**Edit: The answer was no bleeder at all. I didn’t even think to try it without one present.
ToyKeeper
ToyKeeper's picture
Yeah, the lack of bleeder should, if anything, actually make OTSM work better. It thrives on not losing power.
NeutralFan
NeutralFan's picture
Any recommendations on where I can a buy a 0805 SMD 560 ohm bleed resistor?
I’d rather use my flashlight around the house than turn on the lights.
emarkd
emarkd's picture
Last seen: 11 months 2 weeks ago
I usually buy mine in those combo packs with lots of different values, just so I’ll have options on-hand. You can get those lots of places, like Amazon. But if you know that one is what you need, and only that, you’d probably be best off with one of the big parts houses, like Digi-Key.
gchart
gchart's picture
I’ve gotten some from eBay (US sellers) or from Banggood if I’m not in a rush.
NeutralFan
Looks like I can get 20 0805 SMD 560 ohm resistors on eBay for $1.89 from a US seller. From reading this post, it appears that should do the trick to resolve the Bistro firmware issues I’m having with the MTM 17DDm FET + 7135 Driver and the Astrolux SC/SS BLF X5/X6 Flashlight Lighting Switch. I plan to put it between the spring and the retaining ring, shown below with a green line. Please let me know if you think I should use a different resistor or do something else.
emarkd
emarkd's picture
Overall I think your plan is sound. Placement looks good and your value is logical, at least. If I were you I’d order a few different size bleeder resistors just in case though. There’s not a lot about these mods that’s black n white, and sometimes it takes a different value to achieve the desired results. But you could get lucky on your first try.
NeutralFan
Good advice emarkd. When I looked at the variety pack from Fastech (0805 SMD Chip Resistors Value-Pack ) and Banggood, they do not include a 560 ohm resistor. They instead include the following: 10Ω, 22Ω, 47Ω, 100Ω, 220Ω, 470Ω, 750Ω, 1KΩ, 2.2KΩ, 4.7KΩ, 6.8KΩ, 10KΩ, 22KΩ, 47KΩ, 75KΩ, 100KΩ, 220KΩ, 470KΩ, 750KΩ, 1MΩ
So closest would be 470 or 750 ohm. Is that close enough?
emarkd
emarkd's picture
Mostly likely it would be fine. I’ve used those same 470s in lots of builds. Its a difference of about 20% though, so your parasitic drain when the light is on would increase by about 20%. Not that that’s a lot, but its not zero. But then if high efficiency is your goal these taillight builds aren’t really that anyway.
gchart
gchart's picture
I’ve also had good luck with 680 and 750 ohm bleeders, but those were with the Gen2 boards.
The 0805 won’t be long enough to bridge where you have the green line. But you can scrape away some solder mask on that large area at 12 o’clock and solder it between there and the spring.
emarkd
emarkd's picture
gchart wrote:
The 0805 won’t be long enough to bridge where you have the green line. But you can scrape away some solder mask on that large area at o’clock and solder it between there and the spring.
…or just “drag” your solder to fill the void. It’ll stretch across there pretty easily.
NeutralFan
I thought a 0805 SMD resistor would be better to use than 1 of those carbon film resistors that I can get from my local Radio Shack (a 5 pack for $0.78). I should be able to stretch the solder to make it work, but I’m open to other ideas.
NeutralFan
Looks like I may have gotten lucky. My youngest son likes to save electronic parts that he takes apart at school. I looked through them and found this.
Jarder28
Last seen: 4 years 2 months ago
I am curious about this since I had bought a convoy s2+ clear with lighted tail switch. How much power does this light in switch consume? And does this bleeder resistor they call drains the battery even there is no led on switch?
NeutralFan
Here’s what I found out. This was not a fun process, but in the end, worth it. I started with 2 0805 SMD resistors, a 220 and a 470 ohm in series, so 690 ohms. I was able to solder them together and then solder them to the spring and the retaining ring. It looked great and it appeared to work. I was able to medium press back between the modes, but the off time memory was screwed up. When the flashlight was turned off for an extended period, it would turn on in some random medium or high mode. So I used 2 220 ohms resisters and tried again. And again I got the same issue. I then tried to solder a single 220 ohm SMD resister, but was not able to bridge the spring and retainer ring. Then I used a 328 ohm carbon film resistor, and it worked!
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 1 year 3 weeks ago
Hi i want to convert the bad switch construction in this light (http://budgetlightforum.com/comment/1144771#comment-1144771). I would like to use pilotdog68s design. But the available PCBs did not fit. Now i want to ask if you would help me to make two new PCB for this light? I have the measurements ready but i have not decided on the switch. I am waiting for BanL to get me the info i need( i would like to use this one (http://www.kaidomain.com/p/S024079.DIY-LED-Flashlight-Reverse-Clicky-Switch-12mm-x-12mm-for-LED-Flashlight-Black-button-5-pcs) but if it is not high enough i would have to use a KAN28. It has nearly the perfect hight.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
DrafterDan
DrafterDan's picture
Last seen: 1 year 11 months ago
My original torch (the top LH solarforce shorty with the green cap in the first post) has been working perfectly since I put it together. It runs almost two months before it fully drains an 18350.
My wish list would be to find a way to fit a converter so we could run EL Wire instead of surface-mount LEDs, but those things require about 100v up-converted from DC to function.
~D
have light, will travel
djozz
djozz's picture
Last seen: 2 hours 23 min ago
I have been thinking of using EL wire in a flashlight, but what has put me off trying it is what the cheap (few $ from Gearbest) EL-wire with driver does, that produces a pretty loud and annoying high tone. Are there versions that do not do that? (perhaps uses a higher frequency for generating the high voltage)
CRX
CRX's picture
Last seen: 7 months 1 week ago
Maybe it just needs potted.
