D.I.Y. Illuminated tailcap
1813 posts / 0 new
Lights-Out
Lights-Out's picture
Last seen: 10 months 2 weeks ago
i got it to work but it is loosing connection at the spring so im guessing the switch board is bad ? anyone know where i can order a few i think its 20mm
gchart
gchart's picture
Last seen: 13 min 43 sec ago
I forgot, which light is this going into? I always struggled with grounding at the tailcaps on my Convoy S2’s. The setup makes the switch retaining ring sit too low and there battery tube won’t make good contact. I usually end up building up the switch board thickness with some solder on the grounding ring. Not a good long term solution but it works.
Lights-Out
It’s a rigid industry flashlight and looks like the older C8’s
ZozzV6
ZozzV6's picture
I found mine. It was an earlier version.
gchart
gchart's picture
Gotcha. I thought I remembered someone else running into a similar problem before. Man, what a bugger to pin down!
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 1 day 14 hours ago
This is my first post here, so I welcome everyone. My name is Adrian.
I’d like to add this switch to my s2 +. I added a bleeder to the driver, but it still does not work as it should. After switching off and on again, the mode changes to the next one. I’ve tried a bleeder 10k, 4k7, 1k, 750R, 680R, 470R, 240R and even 68R, but it still does not work. I am a beginner, so please be understanding and make suggestions.
ZozzV6
ZozzV6's picture
What color leds do you using and what resistor values did you placed in the tailcap before them?
g_sintornillos
g_sintornillos's picture
Last seen: 11 months 1 week ago
You need to wait about 5 seconds before turn off to memorize the last mode
Sorry for my bad English (gogole transtorla)
djozz
djozz's picture
Last seen: 58 min 32 sec ago
Welcome to BLF Leviatan!
When contact is broken upon a switch (half)press, normally the driver measures the time before contact is resumed, if that is quick enough it interprets it as a switch to the next mode, if it is longer it interprets it as a switch-off. That timing is often influenced by the lighted switch assembly, and can be so off that even a long switch-off is still seen as a mode-change.
I have had drivers that I never got to work with lighted switches, I remember having trouble with 105C-type of drivers, but can’t remember how bad it was.
NeutralFan
NeutralFan's picture
Last seen: 17 hours 31 min ago
Being somewhat of a noob myself, is connecting the bleeder resistor between the spring (battery plus) and the star the same as connecting it to the ground (the flashlight body)? I thought the stars are used to change driver functions and perhaps that’s not connecting it to ground.
Leviatan, have to tried soldering the resistor between the spring and the outer ring (or you could solder it to the middle pin of 1 of those 7135s)?
I’d rather use my flashlight around the house than turn on the lights.
gchart
gchart's picture
Star #1 is directly connected to the grounding ring, it actually can’t be used for changing settings (whereas stars 2, 3, & 4 can be in your typical star firmware). That placement is exactly how I do all my 105c drivers.
Lexel
Lexel's picture
Last seen: 10 months 1 week ago
This is the reason why drivers like Bistro HD OTSM were developed, the bleeder does not mess up the off timing as the MCU is powered on while the switch is half pressed
OTSM driver can be used with MOSFET or without, depending which mode group you use, but strobes use the FET
So if you use it with FET upgrading to a DTP LED board is nessesary if you put high drain cells in the light
Chatika vas Paus
There are two blue leds. 360R for each.
I can wait even 2 hours, but still mode is changed.
g_sintornillos
I never tried with such a low value in tailcap, the lowest was 2k
Did you test without the bleeder resistor?
I use normally 15K to 30K in the tailcap and 470R bleeder
Normal behavior of the memory of the 105
-Turn on -> wait over 5 seconds -> turn off -> turn on last mode
-Turn on -> wait less 5 seconds -> turn off -> turn on next mode
Or
-Turn on -> wait over 5 seconds -> tap (medium press) -> no change mode
-Turn on -> wait less 5 seconds -> tap (medium press) -> change mode
g_sintornillos
What is this?
These components do not remember that they are in my 105
Chatika vas Paus
These resistors (360R) were original there. Without bleeder, the modes do not change.
This driver doesn’t have a default firmware. It is a driver with proprietary software, and is specially modified for this.
I will try to replace the resistors.
Chatika vas Paus
I replaced the resistors. As a bleeder, I gave 240R, and for LED 4k7. I also tried 2k2 for led and it did not work. It works, but it is not bright…
ZozzV6
ZozzV6's picture
I use 560 Ohm or 1K as bleeder and 4,7K to 47K at tailcap depends on what brightness I want. Blue leds are fine with 1K bleeder and 10 to 47K at tailcap.
Lexel
Lexel's picture
With 2.2K and a transparent washer and tail boot it should be quite bright
The best way to get really bright tailcap is getting the washer replaced with a board so the LEDs are very close to switch cover
Lighted tail switch board replacing the washer around the switch
16mm
17mm
https://oshpark.com/shared_projects/yplKNhqL
Tail board without balance resistors tested successfully
Pink and warm white in the 2 I tested
3×3mm Potentiometers will take a while from China
Have such boards ready but not yet the potentiometers
If you want very bright tail caps you have to go to Bistro HD OTSM drivers
NeutralFan
I just want to say, “Don’t give up!”. I pretty much thought I should have yesterday, but kept tinkering anyways. According to the OP: “I’m sure there are some drivers that simply won’t work correctly at all after it is added.” I thought I found the driver/firmware that wasn’t compatible with a lighted switch.
This is what I was trying to add a lighted switch to: Moonlight Special 17mm Driver with the BLF A6 firmware.
I spent about 8 hours figuring out how to make this work. Part of my “fun” was when I asked my wife what color she would prefer in a tailcap. I had it working (for the most part) with yellow, but she thought green would look better. I found out that yellow is terribly inefficient – it requires a lot more current than green.
And in hindsight, green actually worked out better since I was not able to get yellow to work fully. I was able to get forward and reverse mode to work, but it never reset to no memory despite my efforts with various bleeder resistors. It always kept the reverse mode after it was turned off.
What was strange with this driver/firmware is that the normal 500-800 ohms for a bleeder resistor was not even close. I ended up with a 6.9K (22K and 10K ohms in parallel) ohm resistor.
Here are my notes testing the green LEDs, which shows my attempts with different resistors (I count 13 total):
Every attempt required me to solder a different resistor to the driver and test like this:
Here’s the resistor (combination) that eventually worked. Please note this is not the final installation:
Here are a lot of the resistors I was working with:
And finally, which makes this worth all the effort, here’s the switch with the green LEDs and a 47K ohm resistor:
I will post later once I get everything all cleaned up and put together. I’m thrilled I was eventually able to get this to work!
Lexel
Lexel's picture
TA Bistro OTSM driver I build and sell have no problems with very low tail resistors, you could drive the LEDs with 5mA if desired
I also got a circular board that replaces the washer which makes a lot more light of the LEDs used
with 6 LEDs and has the option of 2 potentiometers as well balance resistors
In this picture external potentiometes as I am waiting for the 3×3mm ones to arrive
Pink and warm white
gchart
gchart's picture
NeutralFan wrote:
I just want to say, “Don’t give up!”…
Wow, glad to see your persistence paid off!
I just built up about 10 this past week (Christmas orders for friends), but I have a pretty set standard for what I usually do. Typically just 105c drivers, Mtn FET+1, or BLF A6 drivers. I haven’t tried one of the OTSM drivers yet, but I’m sure they’re good stuff. And I always use the ring board that Lexel mentioned – those really do give good results.
Keep on modding!
lumenzilla
lumenzilla's picture
Last seen: 5 hours 26 min ago
Just FYI, GB sells a nice glowing tailcap package, including the transparent ring.
https://www.gearbest.com/flashlight-accessories/pp_1403798.html
johnkey68
Last seen: 2 weeks 3 days ago
Hello friends !
I ask advice how to make friends with six-voltage drivers type FX-6 , CF FX-17A , RNX-28A , FX-30 with illuminated buttons from OSH Park?
djozz
djozz's picture
johnkey68 wrote:
Hello friends !
Hi johnkeyy68, I think that no one has tried it with those drivers, but it could work alright. If you try it let us know the result.
johnkey68
Already tried. I assembled the Convoy L2 with XHP 50.2 and the FX-6 driver. Two-channel board with OSH Park, LEDs nervously flicker
It is necessary to try the bypass resistor between the anode and the cathode, but with what resistance?
Lexel
Lexel's picture
johnkey68 wrote:
Already tried. I assembled the Convoy L2 with XHP 50.2 and the FX-6 driver. Two-channel board with OSH Park, LEDs nervously flicker It is necessary to try the bypass resistor between the anode and the cathode, but with what resistance?
you need a bleeder of 1-2kOhms from battery positive to battery negative ground ring on the driver
pilotdog68
pilotdog68's picture
Just noticed how much this has taken off! Lots of cool developments from Led4Power and others.
DoNkEyConN
DoNkEyConN's picture
these will only work in convoy lights without the biscotti driver
XXX-Man
XXX-Man's picture
Last seen: 1 week 2 days ago
With biscotti you just have to solder 1k resistor on driver.
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
