D.I.Y. Illuminated tailcap
1813 posts / 0 new
NeutralFan
NeutralFan's picture
Last seen: 9 hours 44 min ago
Here’s the final install of the green lighted switch in my Convoy S2+.
This is the 6.9K ohm bleeder resistor (4.7K and 2.2K in series) that worked with the RMM Moonlight Special driver with BLF A6 firmware. Certainly a lot higher than I would’ve ever imagined.
And here’s the 47K ohm resistor used in the lighted switch.
I measure 0.03 milliamps for the lighted switch. A lot lower than I was expecting since it’s plenty bright at night. Here’s how it compares to the Meteor M43 turned off (FYI, the M43 lighted switch gets brighter when the flashlight is turned on).
Here’s a link to my build in case you’re interested: Convoy S2+ Mod With A Lighted Switch
I’d rather use my flashlight around the house than turn on the lights.
Ratus
Last seen: 2 years 2 months ago
Wow, 6.9kΩ.
I’ve only tried less then 1kΩ on my moonlight V3’s.
So the reverse mode switching works?
Now I have to go through my 1206 and 805 resistors to find a 7kΩ-ish one.
Thanks.
Refugee from CPF and long time lurker on BLF.
Ratus_ on r/flashlight.
1536 on the GT List, Arrived 05-23-18
1271 on the FW3A List
NeutralFan
Yes, the reverse press works as it should along with all the other functions. I kept experimenting with different bleeder resistors until I found the right value.
Light Years
Light Years's picture
Last seen: 24 min 54 sec ago
DoNkEyConN wrote:
lumenzilla wrote:
Just FYI, GB sells a nice glowing tailcap package, including the transparent ring.
https://www.gearbest.com/flashlight-accessories/pp_1403798.html
these will only work in convoy lights without the biscotti driver
Got a few yesterday and they do work with the Biscotti driver and the BLF A6 driver as well, but it enables the next mode memory on those drivers.
ZozzV6
ZozzV6's picture
Light Years wrote:
Got a few yesterday and they do work with the Biscotti driver and the BLF A6 driver as well. I tried them in my 3 C8s (3/5, Biscotti and BLF A6) and they work fine without any mod.
Are you sure?
without bleeder resistor on driver it works with 3/5 fw but for BLF A6 and Biscotti it turns the driver next mode memory for me in all cases. So for biscotti I always use bleeder.
Light Years
ZozzV6 wrote:
Are you sure? without bleeder resistor on driver it works with 3/5 fw but for BLF A6 and Biscotti it turns the driver next mode memory for me in all cases. So for biscotti I always use bleeder.
Just tested again and you are correct. It enabled the next mode memory on both the A6 and Biscotti driver. I will edit my previous post.
djozz
djozz's picture
Last seen: 1 hour 2 min ago
…the blf x5 and x6 came with this lighted tailcap and bistro driver but in fact the lighted tail works easier with the older blf-a6 driver that was never tuned for it. Essential for working without endless tuning of resistors is a single and high Vf emitter, like the XP-L Hi that was in the X5/X6 lights. Using it in a triple and/or with a low Vf led like the 219c or XP-L2 means trouble with resistor values, but the blf-a6 driver can be tuned well with some effort (the bistro driver that has the Attiny25 is quite hopeless and you end up with a very dim tail light).
Lexel
Lexel's picture
Last seen: 10 months 2 weeks ago
Newer Bistro HD OTSM drivers have no problem with tail cap lights at all
Also LED ring boards replacing the washer help a lot
djozz
djozz's picture
My observations are with the standard Banggood drivers, and with a bistro-driver from Richard that I bought a year ago.
NeutralFan
g_sintornillos
g_sintornillos's picture
Last seen: 11 months 2 weeks ago
Convoy version
https://www.fasttech.com/products/9627747
Quote:
  • Specially designed for Convoy C8 / M1 / M2 / S2 / S2+ / S4 / S5 / S6 / S7 / F12
  • 3 pieces one set, suitable for flashlight replacement or DIY
  • With light, convenient to use
Sorry for my bad English (gogole transtorla)
Dutcheee
Last seen: 5 days 20 hours ago
Nicolicous wrote:
Just mod two Thorfire TG06 and this is my current favorite AA size light.
no bleeder needed Big Smile
Hi Nicolicous,
Looks very nice!
What parts did you use?
I have a lumintop tool aa in the mail, looking forward to build a illuminated tailcap for it.
Not sure how though.. Pictures or parts would be great!
You use stock driver?
Lexel
Lexel's picture
Hi Nicolicous,
Looks very nice!
Pilotdog and myself have made those ring boards
I added balance resistors to it so it can have 6 different LEDs
Lighted tail switch board replacing the washer around the switch
For the exampke pink and warm white, other combinations possible the board with balance resistors could use more than 2 different colors
16mm
17mm
https://oshpark.com/shared_projects/yplKNhqL
16mm
17mm
https://oshpark.com/shared_projects/aqiAxQx1
20mm
https://oshpark.com/shared_projects/fWtrkfax
Dutcheee
Thanx Lexel. Can I sand these dowm to fit the Tool AA you think? Is it possible to populate only 2 leds?
And will it work with your 15mm driver without enabling next mode memory?
djozz
djozz's picture
Just using two of the leds is no problem.
You may be the first to try it in the Tool AA, let us know your findings! Smile
Lexel
Lexel's picture
Without measurements on Tool tailvap and switch no way knowing if it fits
You can populate 1 to 6 LEDs
NeutralFan
For those that are fans of the Generation 1 lighted switch, here’s something to consider when installing your switch. The washer is essentially a diffuser for the switch LEDs. The clearer the washer, the more light that can pass thru, but also shows more artifacts (outline of the switch and the position of the LEDs). Less transparent the washer, less light, but a more uniform illumination of the tailcap.
I initially used the Home Depot washer from the link in the OP (left picture below): 5/16 in. Nylon Washer. I had to sand down the perimeter to make it fit in the Convoy S2+ and the hole was too big for the Omten switch so I filled the gap with a smaller washer that I also sanded down. When installed it looked good, but it seemed to block too much light from the LEDs and looked a little dull. So I made some washers from some plastic items I had in my workroom.
Here are some of the washers on the switch (left is the Home Depot washer).
And here’s how they look in the flashlight. Please notice (and I tried to take the pictures to show this) that the left is less bright and a little dull, but uniformly lights the tailcap. The middle is bright and crisp, but definitely shows some artifacts. And the right is a good compromise.
The clear washer and the semitransparent washer had the same effect in the tailcap. I then sanded 1 side of the semitransparent washer, and then both sides, but that still wasn’t enough to adequately defuse the light. So I sanded down 2 washers to make them thinner and stacked them. I’m pleased with the final result.
djozz
djozz's picture
Thanks for the nice comparison NeutralFan!
Because the classic lighted tail set is for sale, it is attractive for people who do not solder to build this version. Fiddling with the washers is something within reach of almost everyone Smile
crz6662
crz6662's picture
Last seen: 2 weeks 5 days ago
djozz wrote:
I still have a hundred or so translucent silicon thingies for the S2+ which I can sent out for shipping costs. Even to the US it is just $1.70 from here (long live postnl!).
(that reminds me there was a request for them that I never sent, I’ll look that up Facepalm )
I could use a few of those. 3 Convoys & an Astrolux. PM me ?
djozz
djozz's picture
To prevent confusion, they are for the Convoys with the metal tailcap, the early ones came with a black waterproofing silicon seal inside the switch that would not let light through. For well more than a year the S2+ already comes with a transparent seal. I have a stash of transparent seals for who still has the old S2+ with black seal and want to build a lighted tail for them.
Nicolicous
Nicolicous's picture
Last seen: 8 months 53 min ago
Hi Nicolicous,
Looks very nice!
I did this a long time ago. I have to pull them apart and tell u on weekend.
From memory, i had to trial and error with different types of resistors to get the LED lid evenly without affecting the driver and i didnt have to use bleeder resistor.
Nico -.-
crz6662
crz6662's picture
@djozz, never mind. No S2+‘s. thanks
djozz
djozz's picture
Last night I made a EDC for a collegue of mine who is a fan of my flashlight hobby. It has a lighted tail and because not all combinations of led. driver, bleeder resistor, tail resistors and tail leds, work well I tend to post them if I did a succesful build. Here are the numbers that I used on this light and that work very well and do not disturb the user interface. It has a 6-led ring with red 0805 leds under an orange tailcap that give out medium bright light: already well visible in low light conditions and visible at a distance in the dark.
-it is a S2+ shorty with Aspire 18350 battery
-Luxeon V led on a DTP board
-BLF-A6 driver with 470 Ohm bleeder
-both springs bypassed
-Lexel tail ring with two strings of 3 leds, for each string a 10K Ohm resistor
-6x red 0805 leds
Lexel
Lexel's picture
First I tried it on my regular 6x Tail boards with conventional 6 Balance resistors and a 1kOhm Bleeder
Main Problem was that with low battery voltage the higher voltage LEds (Blue, White, pink, ice blue) get dimmer tan the low voltage ones (red, yellow, green)
I came up to enhance this idea with a voltage regulator, but had to do some steps to make it work
first get the voltage and resistor value for each LED at the same brightness
Then I made some calculation to get fixed current draw versions
It is also possible to use this with side switch lights like Convoy L6, as I can get the parasitic drain for the 18kOhm bleeder down to 0.4mA when the tail board has 0.15mA for the LEDs
Now the first 4 Prototypes
I did quite some measurements and tests to even out the brighteness of them
Firt L6/L2 prototypes are build and successfully tested on my bench, modding the lights will follow
One tme i skipped the very current hungry Emerald green for a warm white
The tail board itself uses a voltage regulator so the brightness is constant down to 3V cell voltage and can be fitted with 1S or 2S voltage regulator
The 2S Voltage regulator has a 0.1mA higher drain
I haver also ordered fitting 3×3mm trimmers so that the brightness of the board can be adjusted for 2V and 2.5V LEds in 2 groups
On the other hand I can also build em with a current draw from 0.15-1mA with the balance resistors without trimmers
have made a 4×4 cross section board for 2 channels in cross pattern
The rainbow LED boards have one drawback which are the inefficient Emerald green and yellow LEDs,
so their brightness is lower than green or white LEDs at the same current
light.speed
Last seen: 1 year 9 months ago
Could somebody list me all the components I need to build the Rev6 illuminated tailcap including the type of LEDs with the metal Convoy S2+ button?  I'm new so I found the list it came with a bit confusing. Any help is appreciated.
hyperduc
Last seen: 7 months 1 day ago
I’m interested in adding a lighted tailcap to my new S2+ build from MTN.
With the qlite 7135 running guppydrv do I need a bleeder resistor?
Can I buy one of these as a drop in with the current tailcap? Which is recommended?
https://www.aliexpress.com/item/Jiguoor-1288-LED-Lighting-Switch-For-Convoy-C8-M1-M2-S2-S2-Flashlight/32843005481.html
I can see on the Aliexpress listing that it has an Omten switch, but I can’t tell in the other listings. I think it’s a good idea to keep that switch.
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 1 hour 24 min ago
You’ll probably need a bleeder resistor. All of those switch is the same, but if you want to buy on aliexpress, buy from Simon
https://www.aliexpress.com/store/product/lighted-switch-for-convoy-flashlight/330416_32843122324.html?spm=2114.12010612.0.0.3d1273814vhpZp
fishymamba
Last seen: 7 months 23 hours ago
I got mine from the same seller on ali express. Got it in not too long and it had a omten switch. It did mess with mode memory with both my mtn electronics driver and blf a6 driver. Need to figure out what resistor to get.
S8 Triple - 219c, MTN-17DDm
M1 - XP-L 7a, 105c
C8 - XP-L HI, A17DD-L
hyperduc
Ok, thanks for the feedback. I’m in no rush, I should order one so it’s ready when I get to it.
BeamN8
Last seen: 3 years 6 months ago
i have a quick question I suppose in the same realm of tailcap lighting. On the emisar d1 driver there is a unused pad for an indicator light, or other device but indicator is what im after. What type led should be used and how would I go about doing it for the e switch?
