Test/Review of Fujitsu AAA HR-4UTHC 950mAh (Black)
14 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 2 min ago
DSC_8344
Official specifications:
  • Nominal voltage: 1.2V
  • Typical capacity: 950mAh
  • Minimum capacity: 900mAh
  • Low self discharge (LSD)
  • Retains 85% charge after one year
  • Rechargeable up to 500 times.
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-info
Maximum temperature raise at different discharge currents: 1A:+2,3°C, 2A:+5,8°C, 3A:+9,0°C, 5A:+12,5°C
These cells are high capacity NiMH from the FDK factory in Japan.
DSC_8324 DSC_8325
DSC_8345 DSC_8346
DSC_8347
DSC_8348
DSC_8349
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-Capacity
There is very good tracking between the two cells. They can handle 5A current, but as usual it is better to use a lower current.
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-CapacityTime
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-CapacityTimeHours
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-Energy
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-PowerLoadTime
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-CurrentTest
Fujitsu%20AAA%20HR-4UTHC%20950mAh%20(Black)-Charge
Conclusion
These cell has very good performance.
Notes and links
The batteries was supplied by FDK German for a review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
kloppholz
kloppholz's picture
Last seen: 2 years 8 months ago
Great review. Thanks HKJ!
Pete7874
Pete7874's picture
Last seen: 17 min ago
Cell: HR-4UTHCEX
Mfg date: 2/2018
Charger: Opus C-2400
Discharge current: 0.2A
Barkuti
Barkuti's picture
Last seen: 10 hours 37 min ago
Another funny thing with the capacity figures. This cell cannot do 950mAh even if brand new, and I doubt going down to 0.8V would change anything. Where do you get those figures, Henrik?
Another example is the Panasonic NCR18650G 3600mAh (green), it's rating can only be 3300mAh minimum down to 2.5V, I guess of course. Only a miracle would make that cell hit 3600mAh under HKJ's testing conditions. Literally. Davie
Cheers Party
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Keanu Reeves may need your help. Join his Telegram channel here.
Pete7874
Pete7874's picture
I’m not following. Where did HKJ claim that it does 950 mAh?
Quote:
Another example is the Panasonic NCR18650G 3600mAh (green), it’s rating can only be 3300mAh minimum down to 2.5V, I guess of course. Only a miracle would make that cell hit 3600mAh under HKJ’s testing conditions. Literally. Davie
Again, not following you. Where did HKJ claim that it hits 3600 mAh?
Are you feeling OK? Smile
Barkuti
Barkuti's picture
Pete7874, for the love of God. Let's check:
The title of this thread is “Test/Review of Fujitsu AAA HR-4UTHC 950mAh (Black)”. And then there is the Panasonic NCR18650G 3600mAh (Green) one.
Cheers Party
Pete7874
Pete7874's picture
Barkuti wrote:
Pete7874, for the love of God. Let’s check:
Cheers Party
These are just names of the cells, based on how the manufacturer identifies/describes them.
Maybe try actually reading his tests to see what figures he got (“Measured Capacity”). Smile
Fujitsu AAA
NCR18650G:
SIGShooter
SIGShooter's picture
Last seen: 7 hours 59 min ago
Unless I’m mistaken the 950mAh comes from Fujitsu’s claim for the battery. I just bought 2 packs of them and I only got around 850 mAh discharging at .7A.
Pete7874
Pete7874's picture
Exactly. That is the manufacturer’s claim, not HKJ’s claim. He’s just using it as a thread title to easily identify the product.
SIGShooter
Capacity ratings from battery companies remind me of car MPG ratings. Something to aspire to but never obtained by the consumer Sad
SIGShooter
Forgot to mention that of the 80 or so 1900 mAh Enloops I’ve bought over the past 5 years none of them ever tested out at that capacity. At first I thought I had defective batteries or equipment but then I realized it was just the way things are.
However the 12 Fujitsu HR-3UTHC 2450mAh that I bought several weeks ago tested out at: 2510, 2474, 2561, 2521, 2451, 2427, 2478, 2467, 2461, 2479, 2513, and 2455 when discharged at .5A on my Opus 3100.
HKJ’s test results also show them to exceed Fujitsu’s claim unlike the AAA’s.
Barkuti
Barkuti's picture
Barkuti wrote:
… Where do you get those figures, Henrik?
This was not a judgemental question, but a literal one. I do not see a 3600mAh figure in the Panasonic cell wrap, for example.
Another example: LG states in their M36 datasheet 3.63V average voltage and 12.5/12.1Wh typical/minimum energy. This is 3444/3333mAh typical/minimum capacity down to 2.5V, but the cell neither meets typical nor minimum rating even if it were to be discharged that low, I see it by my integrating eye LoL. Thus, 3600mAh?
If I am to sell something I deeply believe in claiming actual figures which my product can meet or surpass at the hands of my customers. This carves out trustworthiness and peace of mind.
Cheers Party
HKJ
HKJ's picture
My search for capacity goes:
1) The wrapper
2) The datasheet
3) The internet
I first measure the capacity long after I have named the cell.
HydrAxx
HydrAxx's picture
Even I see for mobile phone batteries, I have a Samsung Galaxy S9 Plus equipped with a battery that is officially 3500mAh and when I use the battery manager “AccuBattery” (very good software fairly accurate) that installed as soon as I bought the phone so new, based on the first 10 complete cycle of charge/discharge, the battery did not exceed 3420mAh according to his estimate, so there is always a gap between what is written on the paper and reality.
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
