Hello everyone, you can now get Tiablo flashlights here at Lightake with free worldwide shipping!
TIABLO Unique Design Characteristics:
1 Special purpose flashlight for hunting, searching and explore.
2 Unique body designs with perfect handle.
3 The high difficulty of process on the rear of lamp is much beneficial to imitate-proof.
4 It can be used by headstand. For example, in a space of 30sq.m, headstand TIABLO can make the same irradiation as a 25W daylight lamp.
5 Military grade and hard anodized finish in black color is much wearable.
6 Infinitely Variable Brightness System suitable for various distance lighting requirements.
7 Multifunctional circuit
8 Double circuit design with high-efficient electricity driver and multifunctional setting of birghtness adjustment.
9 With premium stripe for present
Tiablo A10-G Cree 7090 XR-E R2 2-Mode 260-Lumen LED Flashlight Black
This version of the A10 is designed specifically for use on any universal 1-inch flashlight gunmount. The brass insert inside the tube has been removed, allowing the light body a smaller diameter. The circuitry is the same fully variable and programmable circuit in the classic A10.
Specifications
* CREE 7090 XR-E LED. WC R2 LED
* Step up and down constant current driver, with high efficiency dual mode DC-DC regulator (PWM / PFM) and circuit to protect Li-ion battery from over-discharging. Working voltage is 2.75V to 8.5V, under the circuit will flicker to remind users to replace battery.
* High output: 1A at 260 Lumens for 3.5 hours
* Function: multifunctional circuit with advanced Mini computer chip, and it can set according to customers?variety requirement
* 53 mm diameter x 50 mm deep reflector provides greater efficient illumination over longer distances than the standard with similar power
* Support battery sizes Two 3.0V CR123A batteries or one 18650 Li-ion battery
* Type-III hard anodize high quality aerospace grade T7075 aluminium construction
* Switch: Tactical forward clicky switch
* Waterproof Capability: IPX-8 standard
* Toughened ultra clear glass lens with AR coating
* Weight: 180 g
* Length: 175mm Head diameter: 57mm Housing Diameter: 25.4mm
Tiablo A50 SST-50 3-Mode 900-Lumen LED Flashlight Black
Tiablo A50 SST-50 Product Features
- Brand Tiablo A50 SST-50 3-Mode 900-Lumen LED Flashlight
- Special tactical flashlight for hunting, searching and outdoor sports
- Super large smooth aluminum alloy reflector, raise the reflection efficiency
- Type-III hard anodize, Aircraft aluminum
- Smooth reflector and toughened ultra clear glass with AR coated led
- Tactical clicky switch: High-Low-Strobe
- Constant current high efficiency circuit, voltage range is 4V-8.5V
- Unique sculpture for the torch body
- Can be used as candle to illuminate 30m sq, approximately 300 square foot area, similar to a 25W daylight lamp
- Powered by 2xCR123A or 1x 18650 batteries (not included) or powered by 2x18650 batteries (not included) with extension tube (included)
- Water: beyond 5m depth (manufacture rated)
Tiablo A50 SST-50 Specifications
Model: A50
LED: SST-50
Max output: 900 Lumens
Reflector: Smooth reflector
Color: Black
Working voltage: 4.8V to 8.5V
Switch: Tactical
Lens diameter: 56.5mm
Length: 175.0mm
Net weight: 255.1g
Weight (including the packing):435.0g
Tiablo A9 Cree 7090 XR-E Q5 2-Mode 256-Lumen LED Flashlight Black
Specifications
* Cree 7090 XR-E LED. WC Q5 LED
* Step down constant current driver. High efficiency with dual mode DC-DC regulator (PWM / PFM), working voltage is 2.75V to 10V.Supports three battery sizes: one 18650 Li-ion battery, or two pcs CR123A, or RCR123A battery.
* Two stage output:
o 1. High output: 1A at 256 Lumens for 3.5 hours
o 2. Low output: 300mA at 60 Lumens for 8 hours
* 42 mm diameter x 36 mm deep reflector provides greater efficient illumination over longer distances than the standard with similar power
* Water proof: waterproof to 5m/15ft
* Tactical type switch: Low/High/Off button
* Weight: 155 g / less than 5.5 ounces excluding the battery.
* Length: 158mm Head diameter: 45mm Housing Diameter: 25.4mm
Tiablo A7 Cree 7090 XR-E R2 3-Mode 230-Lumen LED Flashlight Army Green
Specifications, Features, and Instructions:
Model: A7
LED: CREE 7090 XR-E R2
High output: 230 Lumens for 2.5 hours
Lens: Toughened ultra clear glass with AR coating
Body: Hard Anodized Type III Aerospace Grade Aluminum Alloy T7075
Colour: Green
Battery: Two CR123 batteries or one 18650 Li-ion Battery
Working Voltage: 2.7V to 8.5V
Switch: Tactical
Button: Metal Precision Designed
Waterproof: IPX-8 beyond 5m depth
Size: Head diameter 32mm, Length 134mm
Weight: 130g excluding battery
My shop on aliexpress , welcome to visit my shop !
You just have to love the look of the A9........
With Darkness, there will always be Light.
They look good but they're also very expensive.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
They are actually pretty reasonable prices - For Tiablos. As long as they aren't fakes like the ones DX used to sell. The DX fakes weren't that good from the comments on the other board.
Most places seem not to carry them any more. No idea why.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
There is no fake Tiablo flashlight in our website ,although it is a little ,I think the brand and quality is worth the price ! our Tiablo is cheaper most of the others flashlight dealer !
Lightake looks like they are trying really hard to provide a good variety of flashlights at good deals. The way I see it, you can never have too many sources for flashlights!
