Test/Review of UK A1299 usb power supply/charger
UK A1299
Official specifications:
  • 100% New and high quality
  • Compatible with all iPod and iPhone models, except iPod Shuffle
  • Charger: Input: 100V - 240V (U.S. & World Standard). Best replacement for original charger.
  • Wall charger chargers your iphone/ipod quickly.
  • IC chip inside recognizes a fully charged battery and automatically switches to a saver mode
  • iPod / iPhone can still be used during charging
  • 3rd Party Products, Not an Apple product.
I got it from Ebay dealer vivaxu
No retail package for this charger, I got it in a envelope.
With the large plug size UK uses, the charger fits inside it.
Measurements
  • USB output is coded as USB charger (DCP).
  • Power consumption when unloaded 0.05 watt
  • Failed 2500 volt test and is permanently shorted between low volt and mains!
These adapters are often rated at 1A, but on my copy it is not possible to read the rating and the test shows that it can only supply 0.4A.
The circuit does not have any overload protection.
It could supply 0.4A for one hour, but the voltage was a bit low.
M1: 32,1°C, M2: 30,9°C, HS1: 35,4°C
With this low output current the temperature is fairly moderate.
M1: 31,4°C, HS1: 42,1°C
M1: 38,4°C, M2: 33,0°C, HS1: 43,7°C
HS1: 35,3°C
The noise is not moderate, but very bad. At 0.35A I got 190mV rms and 1.2Vpp.
Even without any load, there is a lot of noise: 86mV rms and 1.2Vpp
Tear down
A simple design on the mains input with only one diode and a capacitor, no fuses or filters.
The isolation is rather bad it is supposed to be over 6 mm on the circuit board, but here it is only 1mm
The charger failed a isolation test with 2500 volt, this makes it doubtful to use with 120VAC mains. The fail made a shorted between mains and low voltage side (Very bad)!
Conclusion
Low output current, lots of noise and bad isolation (I will rate the isolation dead trap).
Stay away from this one!
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Thanks for the review.
I had already found out the hard way that these are really nasty.
I was lucky that this was all that happened when it self destructed…
The unit itself was much worse, this is just the mark it left on the socket.
Thank you very much for the review.
