Known working TIR optics that fit S2 AND S2+ from Fasttech?
10 posts / 0 new
OrionLight
OrionLight's picture
Last seen: 4 years 7 months ago
My stock reflector from my S2 is 21mm wide and about 20mm deep. I’ve looked through the fasttech site and can’t find anything that fit that dimension. I’ve also seen some on Simon’s ali store but some of the comments say that you’d have to file some down to fit the S2+ too. Has anyone bought optics from Fasttech and fitted them to an S2 and/or S2+ without having to do any filing?
xelario
xelario's picture
Last seen: 7 months 2 weeks ago
Not from Fasttech, but these fit S2+ (after removing the TIR from the white plastic case, which is very easy). They have 10, 25, 45 and 60 degree TIRs.
OrionLight
Cool! Thanks!! Do you know if there are any there for the slightly longer S2 fit? I’d like both, but I need it more for my S2 than the S2+.
xelario
xelario's picture
Sorry, don’t know about S2.
OrionLight
Xelario, I just received my optics to put into my S2+, and I tried fitting in, but it’s a bit wide so I took off the plastic case like you said and now it’s a little too small. When you have it installed, are you still using the stock glass lens of the S2+ to hold everything inside or did you manage to use just the optic?
xelario
xelario's picture
I tried it both with stock glass lens, and without. Worked either way, using the lens seemed to be easier, so try that first. I ended up removing it (the o-ring stayed), because the TIR just happens to be the perfect diameter to fit without falling out :). Just have to be careful while screwing the pill in, adjust the TIR so it doesn’t go sideways. Here’s some pics:
I also tried filing down the plastic case so it fits the head, but later removed it, because that red Noctigon and Nichia 219B combo just looks too good to cover up. Smile
Gunga
Gunga's picture
Last seen: 2 hours 31 min ago
Great stuff! Can’t wait to get mine.
alexvh
Last seen: 4 years 10 months ago
Those look interesting. They also have some elliptical ones that could be good for a bike light.
My firmware for nanjg attiny13 flashlight drivers: https://github.com/alexvanh/basic_off_time_driver
Discussion: http://budgetlightforum.com/node/36932
Off-time mode switching on stock drivers (no off time capacitor mod necessary) and ramping withou
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 6 months ago
S2 you need a spacer behind the star to have it fit…search the forum..there is alot of information about the length of reflectors and whatnot
Otanacious
Otanacious's picture
Last seen: 7 hours 21 min ago
Already ahead of you Wink In an Eagle Eye X2, which is a 1:1 carbon copy of the S2+.
