Flashlight Firmware Repository
2370 posts / 0 new
Skylight
Skylight's picture
Last seen: 9 hours 48 min ago
Is there an Anduril version that uses only the FET and no 7135’s? I would need one for 6V and 12V drivers.
SammysHP
SammysHP's picture
Last seen: 23 min 29 sec ago
You can use any single channel config (often “nofet”) and use the corresponding pin.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 19 hours ago
Please help. I tried to flash an fw3a driver with narsil and got this error… “Event not declared”
SammysHP
SammysHP's picture
Cannot see the picture. Have you modified narsil to run on the driver?
pinkpanda3310
I’m a numpty so I didn’t realise narsil needs to be modified to work on this driver. It’s the pic visible now?
SammysHP
SammysHP's picture
It is. I highly doubt that you can compile and flash Anduril or Narsil with the Arduino IDE. Wink You’ll need comman line avr-gcc and avrdude for compiling and flashing. There are several tutorials how to do it.
Does Narsil work with three channels? Does the pinout match?
pinkpanda3310
Damit this stuff is way too complicated for me. I can’t even get the name right. It was andruil.c from toykeepers launchpad. I just tried with command prompt / avrdude and i get a file directory error. I appreciate your willingness to help SammysHP but this is already irritating the c^@p out of me
pinkpanda3310
I don’t know if I’m a step closer but in command prompt i got the directory sorted but the hex file cannot be opened or read
gchart
gchart's picture
Last seen: 2 days 9 hours ago
Have you got it to compile? How does the command prompt look when you run the build-all script?
pinkpanda3310
I finally got it to flash. It turns out the directory was the issue. I moved the hex file and it worked fine Smile Now that i got it to work (once at least Silly ) i need to learn how to modify the hex file Tired
Skylight
Skylight's picture
Thank you SammysHP. To change the pin you need to modify the file, right? I was hoping for a complete hex file. Maybe I will need to figure out how to create a hex file myself. Last time I tried it just showed me a bunch of errors.
SammysHP
SammysHP's picture
No, just use the FET on the 7135 pin of the MCU.
chadvone
chadvone's picture
Last seen: 1 month 1 week ago
I have flashed drivers in the past. But after 2 computer crashes and many motorcycle crashes I can’t seam to put it all together again.
I have used ToyKeepers README file.
I believe I have downloaded all the necessary files to my HOME folder.
I have connected with an Attiny85.
After compiling an untouched rampingiosv3.c just to test.
I get 6 pages of errors.
Basically a few #warning “device type not defined and #error Requested EEPROM_BYTES too big
then about 5 pages of undeclared and implicit declaration.
I believe I am missing a library, or don’t have library in path.
gchart
gchart's picture
Linux or Windows? I’m guessing Linux since you referenced a Home folder. If Linux, are you using the “build-all.sh” script or are you trying to build a single config? When downloading the files, did you maintain all of the folder structures? If not and you just stuck all of the files in the same folder, you’d need to fix the directories for all of the #includes.
chadvone
chadvone's picture
Using Ubuntu. Vim. avr-gcc. Do I need to add anything to avr-gcc rampingiosv3.c when compiling?
gchart
gchart's picture
No. But I wouldn’t compile with gcc directly. Use the build-all.sh build script.
Sunnysunsun
Sunnysunsun's picture
Does anyone else’s build-all.sh build script not compile 1634 hexes? All the attiny85 hexes show up but none of the 1634 ones get created for me.
gchart
gchart's picture
Do your config files for the 1634 targets include this towards the top?
// ATTINY: 1634
And does your build-all.sh script include this line?
ATTINY=$(grep 'ATTINY:' $TARGET | awk '{ print $3 }')
Sunnysunsun
I dunno. I’ve been downloading my files directly from the latest revisions on launchpad.
https://code.launchpad.net/~toykeeper/flashlight-firmware/trunk
Is this the right place to get them? I just click the number, 247 at the moment, and then click download tarball
I guess I have to add those lines in if they’re not they’re already?
On another note, how do you guys bring the spaghetti monster files into a project? Do you just copy paste into the project’s folder? I’m not sure how to open anduril in atmel studio as a project so I can build natively in atmel.
The old guides I could find on blf have lost their images/are out of date
SammysHP
SammysHP's picture
That’s an ancient version, many years old. Which version do you want?
Anduril 1: https://code.launchpad.net/~toykeeper/flashlight-firmware/fsm
Anduril 2: https://code.launchpad.net/~toykeeper/flashlight-firmware/anduril2
Sunnysunsun
Oh I see. Thanks for the link. Is “download tarball” the right button to click?
SammysHP
SammysHP's picture
Don’t know, I use brz on the command line. If it downloads the full repo head it should be correct.
Wesku79
Last seen: 2 weeks 22 hours ago
Hello, new user here.
I have been looking for a source code of this 7135 driver: https://a.aliexpress.com/_mPVnPSJ
5modes: Low-Medium-High ,Recycling; Double-Click at any mode turn to strobe mode; Three times Click at any mode enters into stepless dimming mode (In the current state, the brightness first decreases and then rises. When it reaches lowest or highest, it will flash once and wait for 1 second to continue to increase or decrease. When it is turned off at any time in the stepless dimming state, the brightness at the time of shutdown can be saved.)
So far I haven’t found the code. Does it even exist in this repository?
I would like to modify it with a few elements of TK’s crescendo firmware. For example, I don’t need strobo, but I would definitely use battery check instead.
MtnDon
MtnDon's picture
Last seen: 3 hours 9 min ago
I’m not an expert, but I believe Crescendo is designed to be used on attiny 13A, 25, 45 or 85 MCU’s. (on the 13A there are reduced features) Those are all 8 pin devices. The driver pictured appears to have 10 pins. I don’t have any idea what that is but my guess is that it might not be easy to get crescendo to run on that MCU. Chances are there is no open source code for the firmware on that driver, but I am guessing.
Wesku79
Oh,I didn’t spot it had 10 pins. I thought all of the 7135 drivers are attinys. Too bad, I have already ordered a couple of those. Maybe I can live with them, but i will surely miss battcheck.
Maybe that chip is CH552E or CH554E
nojump
Last seen: 1 year 3 months ago
Hey I’m sorry if this isn’t the right place to ask this. If it isn’t, please direct me to the correct place. But I was wondering if someone could make a custom anduril mod for me?
gchart
gchart's picture
Someone might be able to. Are you looking for a pre-compiled hex file? You might want to briefly describe what you’re looking to have done.
nojump
Yes, I just want a hex file that I can flash to my d4v2. And I just want some of the strobe modes removed, and one strobe mode modified. I will pay for the services btw.
Garik F
Is it Anduril 1 or 2? What mode you need to be removed and what mode need to be changed? For what light?
Light Veteran
Last seen: 22 hours 21 min ago
Question..
Is this the place where I can write or suggest modifications about anduril 2 or there is an other thread? (Like “Anduril..2?” By Toykeeper)
I want to help but I desire I am in the right position
Thanks
Flashlight addicted
