Test/Review of 2A dual port charger
Official specifications:
  • 100% Brand new, high quality!
  • This adapter can charge 2 USB devices simultaneously
  • Input: AC 110-240V, 50/60Hz
  • Output: DC 5.1V 2.1A (2100mA)
  • Output: DC 5.1V 1A (1000mA)
  • Output Connector: USB female
I got it from Ebay dealer double-turbo
I got this charger in a cardboard box with a picture of the charger on the outside.
There is a red window on the charger with a led behind. The led shows when the charger is powered.
Measurements
  • Power consumption when unloaded: 0.17 watt
  • USB output 2.1A is coded as Apple 2.1A
  • USB output 1A is coded as USB charger DCP
  • The two usb outputs are in parallel.
  • Failed 5000 volt test and shorted between mains and low volt side.
The two outputs looks fairly identical because they are running in parallel. The overload protection kicks in between 2.1A and 2.2A
No problem running at 2A for one hour.
M1: 74,3°C, M2: 49,9°C, M3: 40,8°C, HS1: 75,9°C
The charger do get warm at 2A. As usual the output diode do get rather hot.
HS1: 72,2°C
M1: 51,2°C, M2: 49,0°C, M3: 33,5°C, HS1: 56,7°C
HS1: 55,7°C
M1: 57,7°C, M2: 43,8°C, HS1: 77,9°C
There is some noise at 0,5A with 58mV rms and 0.56Vpp
And even more at 2A with 117mV rms and 0.7Vpp
Tear down
The mains input is very simple, not noise filter or fuses, first component is a bridge rectifier, then the capacitor.
The isolation is rather bad, CY1 is mounted between the low volt side and the mains. This is NOT a safety capacitor.
The charger passed 2500 volt isolation test, but failed a isolation test with 5000 volt, this makes it doubtful to use with 230VAC mains. The fail made a short between mains and low voltage side (Very bad)!
Conclusion
The load test looks fairly good, but the noise is not as good and when we get to safety it fails completely.
Stay away from this one!
Notes
Read more about how I test USB power supplies/charger
Thank you for your tests warnings. :wink:
I will stay away from double-turbo! Thanks for the review.
I had one of these ages ago that died, looked the same but wouldn’t know the internals were the same. I noticed if I touched sensitive skin (like armpit) against the ground on the USB I could feel a slight current, noticed the same thing on a ultra cheap laptop charger, but not with my OEM charger, do you know why the ground could be giving off current?
That is probably due to the capacitor between mains and low volt side, it allows a small current to flow. Turning the mains plug in the socket will probably remove the current.
If equipment has a 3 pin mains plug (i.e. earth connection), turning the plug will not help.
Reading your reviews on these chargers is eye opening, I had assumed that they were all just fine, especially from someone like Amazon.
Now I wonder about this one, Amazon.com
