Acebeam K60 XHP70 5000lm mega thrower 124100cd 704m
196 posts / 0 new
zeremefico
zeremefico's picture
Last seen: 9 min 10 sec ago
From their site:
“2015 K60 CREE XHP70 5000LM Throw 700M
The Acebeam K60 employ new signle CREE XHP50 LED emitter supply max 5000lm and bring 704m beam distance”
http://www.acebeam.com/acebeam-k60#.VRnUTpGgHqA
update 31.03.2015
“Features:
LED: Cree XHP70 LED with a lifespan of 10+years of run time
Max 5000lumens output (4× 18650 batteries)
Output (select by magnetic ring): Level 1 : 0.9lm(1200hrs); Level 2 : 300lm(320hrs); Level 3 : 1000lm(35hrs); Level 4 : 2000lm(16hrs); Level 5 : 3400lm(6.9hrs) Level 6 : 5000lm(3.2hrs); Standby : 65uA Strobe : 5000lm;
Working voltage: 10V – 17V;
Max Runtime: 1200 hours;
Max beam distance: 704meters;
Peak beam intensity: 124100lux;
Impact resistant: 2 meters;
Waterproof : IPX-8 Standard (2meters);
Size: 205mm(length) x 88mm(head diameter)*50mm(tube diameter);
Weight: 720g(without batteries);
Aircraft grade aluminum body structure;
Accessories include: 1x user manual; 1x lanyard; 1x holster; 1x Replacement O – ring and Tailcapgummi;”
Specs updated 28.04.2015
Products specifications
LED Cree XHP70 LED with a lifespan of 10+years of run time
Luminance 5000LM
Beam Throw 124100cd Throw 700M
Waterproof IPX-8 2M
Vihn’s cpf thread
Acebeam has tightened it’s policy (MAP) and no discount coupons are available:-(
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Edited by: zeremefico on 06/29/2015 - 18:42
FlashPilot
FlashPilot's picture
Last seen: 33 min 7 sec ago
Please hold off on purchasing any Acebeam products until they resolve the cell recharge/discharge voltage imbalance problems with their multi-celled flashlights.
It took a huge number of customer complainants and other threats for them to even acknowledge that there was a problem, and that lives might potentially be at risk if a cell vented/exploded. Acebeam still hasnt resolved the problem yet, so we need to wait a good deal longer to see if they correct the problems with the huge number of flashlights they have already sold before buying another expensive dangerous Acebeam flashlight.
Please DO NOT BUY ANY ACEBEAM PRODUCTS until they have resolved this problem!
Bella, dozens of very angry Acebeam/Supbeam owners are still waiting for your reply in the X60 GB sales thread. Read post 682 forward. When will we be receiving the revised cell carriers for our flashlights?? Please reply.
DayLighter
DayLighter's picture
Last seen: 5 years 6 months ago
For Heaven’s sake.. some of us still believe charging the old fashioned way .. which is charging outside the light.
are we supposed to pass a good light if they offered it at a good price because some people are so adamant about charging the batteries inside the light?
Flat Stare
The only way to do a great work is to love what you do.
FlashPilot
are we supposed to pass a good light if they offered it at a good price because some people are so adamant about charging the batteries inside the light? Flat Stare
Not true! The problem effects recharging and discharging. Several members have reported using an external charger to recharge their cells, only to note large cell voltage differences after discharge, thanks to a very poorly designed cell carrier.
Folks, please DO NOT BUY Acebeam flashlights until the manufacturer has definitively resolved the problem. I will keep everyone updated with test results of the newly designed battery carriers, assuming Acebeam makes good on its word and produces them. Until then, there are many other lights to satisfy the techno lumen junkie.
DanielM
DanielM's picture
Last seen: 1 month 16 hours ago
This light does not include in-light charging, does it? Looks good.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
D10ten
D10ten's picture
Last seen: 5 days 6 hours ago
Doesn’t seem like it has in-light charging, but I wish the mode spacing was a bit more like this.
Level 1 : 0.9 to 0.9
Level 2 : 300 to 50
Level 3 : 1000 to 250
Level 4 : 2000 to 1000
Level 5 : 3400 to 2500
Level 6 : 5000 to 5000
MarkoZimmer
Last seen: 7 years 8 months ago
LED: Cree XHP70-LED mit einer Lebensdauer von über 10 Jahren Laufzeit
Max-5000lumens-Ausgang (4 × 18650 Akkus)
Ausgang (nach Magnetring auswählen):
Stufe 1: 0.9lm(1200hrs);
Stufe 2: 300lm(320hrs);
Stufe 3: 1000lm(35hrs);
Stufe 4: 2000lm(16hrs);
Stufe 5: 3400lm(6.9hrs)
Stufe 6: 5000lm(3.2hrs);
Standby: 65uA
Strobe: 5000lm;
Betriebsspannung: 10V – 17V;
Max Runtime: 1200 Stunden;
Max Strahlabstand: 704meters;
Spitzenintensität-Beam/Ausleuchtzone: 124100 Lux;
Schlagfest: 2 Meter;
Wasserdicht: IPX-8 Standard (2meters);
Größe: 205mm(length) X 88 Mm(head diameter) * 50 mm (Rohrdurchmesser);
Gewicht: 720g (ohne Batterien);
Aircraft Grade Aluminium Karosseriestruktur;
Zubehör gehören:
1 x Bedienungsanleitung;
1 X Halsband;
1 X Halfter;
1 x Ersatz O – Ring und Tailcapgummi;
I
will34
will34's picture
Last seen: 3 hours 55 min ago
I never charge my batteries inside the flashlight, but I know that a lot people will find that more convenient. If it doesn’t work correctly, it’s better not to have it at all.
Good heads up Flashpilot but I think this model doesn’t come with built in charger…
FlashPilot
It apparently affects all of their flashlights with cell carriers. Several BLF members have reported Supbeam/Acebeam flashlights without in-light chargers to show large cell voltage variances after discharge. So its not just the lights with in-light charging that are of concern.
So if you have one with a cell carrier, check your beginning and ending voltages before assuming your flashlight is safe to use.
DanielM
DanielM's picture
Isn’t the battery carrier in the “non in-light charging” category just a bunch of connections basically, without any IC? How would that discharge cells differently? I just have a K40M, haven’t checked the cells yet.
FlashPilot
That would seem logical to me. :bigsmile: There are now literally thousands of BLF posts spread out across several Supbeam/Acebeam threads. I only own the X50 and X60, both of which have the charging problem I described (with in-light charging).
Since the manufacturer has seriously dragged its feet for a long time while attempted to convince me that their faulty design was acceptable, I hope everyone will wait to see if they will do as promised before buying any more of their products. Also, you might want to reference the K50 GB and X60 GB discussion threads for a better perspective of what you are considering buying, along with the later discoveries of some of their inherent faults.
Sirius9
Sirius9's picture
Last seen: 5 days 13 hours ago
O come on people, let’s spread some love instead Silly
I like new T25, I will apply for review Big Smile
Adoby
Adoby's picture
Last seen: 4 years 9 months ago
DanielM wrote:
Isn't the battery carrier in the "non in-light charging" category just a bunch of connections basically, without any IC? How would that discharge cells differently? I just have a K40M, haven't checked the cells yet.
For cells in series it is important that they are identical. Otherwise it is possible that one cell that discharge faster may be "reveres charged" and be damaged/vent. But that also depends on the driver, if it has low voltage shut off, and if the cells are protected.
And the same cells (brand/model) with different ages may have been used/abused differently and may have different internal resistance and capacity. So when charging cells that are intended to be used in series it is good to have a charger that can test the internal resitance and capacity so you can verify that it still is the same, or very similar, for all of the cells. If you can't test the the cells, it is safer to only use protected cells.
DanielM
DanielM's picture
Of course Adoby, I was assuming all cells were exactly identical. I guess I should have wrote it, seemed common sense to me.
Adoby
Adoby's picture
Yes, but without actually checking your assumption may very well be wrong. And you actually said that you haven't checked the cells you use in your K40M.
Sirius9
Sirius9's picture
It is commonly implied at BLF that it is good practice to use same cells (same manufacturer, same capacity, same age and preferably same batch) especially if they are in serial connection.
I think what DanielM meant is that he didn’t checked cells at what voltage level is every individual cell after discharging in his flashlight:
DanielM
DanielM's picture
Exactly Sirius9, and I don’t see any reason why the cells in a dumb carrier would be discharged differently. I will check when I get home to add already existing data.
M4D M4X
M4D M4X's picture
Last seen: 1 year 3 months ago
hopefully available as a flash deal like the K40M was…
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
marcl
Last seen: 1 year 11 months ago
@flashpilot. After reading this I checked the cells on my K40. All brand new Panasonics, I get 4.06, 4.07 and 4.07. I know they are not very discharged but it does not seem too much of s problem for me so far.
What kind of voltages are you getting on yours?
Marc
Eagles may soar, but weasels don't get sucked into jet engines!
Omega_17
Last seen: 14 hours 28 min ago
The performance are very impressive ! Shocked
3400 more lumens than K50 with similar runtime (3.2h) but with a little less trow : 124klux vs 140klux. The design look like a prototype though.
marcl
Four cells though.
Marc
DanielM
DanielM's picture
In my K40M I’m getting exactly 3.83V on all three brand new same batch Panasonic PF’s.
Ejected Filament
Ejected Filament's picture
Last seen: 1 year 9 months ago
Its about community. So far Acebeam has not met its burden as far as the community is concerned. It would be foolish as a community, to continue to buy Acebeam/Supbeam products from this forum. It says we dont care what they do, the next product just has to capture attention and the past will not matter. You might want to consider if thats what you want them to take from this.
ie: Sell us any shit, at any price, and we will still buy your next over priced release. And it is over priced, these arent $30 lights. At their price point, there should be no design flaws. And righting the wrong of the earlier models does matter.
The forum is a community, and right now the community is in process of trying to get Acebeam to correct an error, one they are already dragging their feet on. Are you part of that community? <rhetorical question.
dw911
Well put.
These lights are a sizeable £ outlay, even with a discount, so they should work as advertised, even if people choose not to use all the features, that’s up to them, but we paid well for those features so they should all work correctly
RMM
RMM's picture
Last seen: 2 years 9 months ago
How much voltage difference are most people seeing after discharge?  Have they tested those same batteries in a different light, without a carrier?
Mountain Electronics : batteries, Noctigon, and much more! What's new?
DayLighter
As much as they want to fix it right away..it’s not going to happen over night.
Rhetorical question? yeah it is.. what kind of community are we talking about? lynching community?
Are we trying to lynch them because they can’t fix the problem over night?
Do you really believe they want to drag on their feet fixing this issue so they can ruin their reputation?
I’m pretty sure everyone here is aware charging batteries is series is always challenging not too mention dangerous.
That’s why I never want to charge my batteries inside the light unless I’m absolutely has no other choice or means of charging my batteries outside the light, even in the event of emergency, then I probably just going to charge it for few hours just so I can use them again.
Even if you have the same batteries from the same batch, sooner or later one of them will discharge more than the others.
So I’m not really sure this “lynching” style of fix this issue or we won’t buy it from you again is really motivation for other company to offer GB of good light at a good price in the future.
What happened to the free will? I’m pretty sure by this time a lot of people are aware about the charging inside the light issue, so if they want to buy Acebeam’s other product, they will do so at their own risk, so what’s the problem? it’s their money..
BLF community is all about sharing information, Regarding how others use the information is irrelevant.
But telling others to boycott the company because their light is not perfect it’s just…“Neanderthal”.
To be honest, there’s no such thing as a perfect light, every other company has their own flaws in their designs.
Are supposed to boycott Fenix for having plastic reflector in their premium priced lights?
But boycotting the company for not fixing the problem a lot sooner is the same idiotic scheme as blaming the guy who overly excited to introduce the GB in the first place ( at times makes me wonder..)
And are we suppose to lynch him too for not finding this problem sooner before he started the GB?
Anytime you buy any light.. you’re at your own risk, it’s that plain and simple.
If you’re afraid to get burn, then stop playing with the torch ( pun intended J) )
Well.. that’s just my $.02 :bigsmile:
M4D M4X
M4D M4X's picture
amen bro!
would be better to get rid of all that younameit-fire crap…
that cheap stuff is bought by so many non knowing people!
I am sure if one buys a high priced product he goggles at least to find some info.
PLEASE NOTE
DanielM
DanielM's picture
I think Flashpilot posting warnings in bold text in the GB threads is a good thing. Let me explain.
We are flashaholics. We know our cells and our lights. We know the risks and rewards. We may find FP’s warnings annoying and radical because, let’s face it, most of us charge our cells in our chargers where we can watch them. But…
This group buy is not secret, anybody with an internet connection can google Acebeam and come here shopping. They may not have read the battery university articles. They may not have dreamchargers and battery analizers. They just want a cool flashlight that simply charges like a cell phone. Think about it, the group buy is started by Flashpilot, I think he feels a little concerned about it to say the least. I know I would lose sleep about it for sure.
To conclude, I think we can tolerate a little warning once in a while if that prevents god knows what problems may happen when 6 cells overcharge or overdischarge in a closed metallic tube.
Ejected Filament
If you’re afraid to get burn, then stop playing with the torch ( pun intended Crazy )
Well.. that’s just my $.02 Big smile
Theres no lynching. FP is talking quite openly and calmly with Bella in that other thread. I dont usually agree with Flashpilot, in fact on a very similar issue Ive had my moment with him. I dont know that he has the only solution, I dont know that there is a severe issue. But Bella seems to think there is, Acebeam is doing something about it, which they wouldnt if there was no problem at all.
Its far from overnight, its been months already. And that is a significant amount of time.
Reputation? Ruin? Umm, its not abnormal to drop quality and trade on reputation.
There is an included charger, it must work. I can not understand how this is even a question. Its there, people will use it even if you wont. Moreover, it was a selling point, its partly what people paid for, now youre saying they shouldnt expect it?
As you say there are inherent problems with the batteries themselves. That multiplies the issues inherent in the charging system it does not negate them. Its a bit like saying the cars brakes arent that great so it doesnt matter if we dont fix them when they work less well than standard, or the steering is stuffed but who cares as the brakes dont work either.
How is telling them they can sell any piece of shit, at high prices helping us? We end up with more companies selling us junk. People paid for a torch, and charger. Why should they be happy with just a torch.
Their money? No one said it wasnt. But clearly the comments regarding community were lost on you if thats your avenue of discussion.
FP brang a group buy, on a light from a maker that had a reputation of quality. Thats shows that FP took them at face value, not that he is lurking looking for victims. Unfortunately an issue has arisen, and he has taken it on.
Actually boycotting the company tells them to lift their game. When a group of people as knowledgeable as this community is regarding the good and bad of lights, it has an effect. In general companies dont fix things if there is no consequence to their lack of action. Have you got any idea how hard it is to get companies to perform a recall? It takes laws, and threats of lawsuits to fire them up. And even then the decision they make is based on a discussion between accountants and lawyers re: the cheapest option. And that at times means a few deaths are even worth the risk. Its fnny, why is it even a discussion. There is a fault you SHOULD fix it. You might discuss how to fix it, sure, but not whether or not you bother.
There is a huge difference between perfectly functional plastic bits such as a reflector, and flaws that make the light a potential pipe bomb. If we dont care how the features of the light interact with safety, then why do we ever discuss the dangers of charging in series and benefits of balance charging at all?
No, if I pay $3.99 for an item that suggests $3.99 is way too cheap I take a risk. When I pay a reasonably significant sum, I can expect it to work. And if there is a fault, I expect it to be corrected properly. After all, I paid a premium for quality. Same reason I wouldnt buy a $0.99 light, I dont expect it to worth the box it comes in.
Sirius9
Sirius9's picture
If I remember correctly when first group buy for K40L2 was organised they were sold overnight, all three batches they offered, well over 100 lights, no one complained how expensive they are because we were getting 95% of TN31 for less than 50% of the price, people were grabbing for K50 when it was on GB, again, no one complained about the price. Considering how expensive X60 was I was really surprised how many members were interested and actually bought one (if it isn’t more than my monthly salary I would get one also) and now, all of a sudden people are talking how they are selling “overpriced shit” (not my words)!!!
WTF?
I don’t remember so much bashing threads and souch invasion of sales (group buy) threads before. At least one GB thread appears every day, many of them are organised before actual light that is subject of the thread is even made or available anywhere like Sunwayman C22C, no one actually tested that flashlight or saw it in person but we all want to be among exclusive 50 to have it first! So now the manufacturer is under pressure, they want to satisfy hungry BLFers but what happens if at some point later someone discovers some flaw, speck of dust under the reflector, should we start sharpening guillotine right away! I don’t remember anyone flamed this much Sunwayman over a switch cover on D40A which is falling apart after intensive use…
Anyway, I like many of their lights, I like new T25 and if I get the chance to buy one for a good price why I wouldn’t do so…
Ejected Filament
Sirius9 wrote:
If I remember correctly when first group by for K40L2 was organised they were sold overnight, all three batches they offered, well over 100 light, no one complained how expensive they are because we were getting 95% of TN31 for less than 50% of the price, people were grabbing for K50 when it was on GB, again, no one complained about the price. Considering how expensive X60 was I was really surprised how many members were interested and actually bought one (if it isn’t more than my monthly salary I would get one also) and now, all of a sudden people are talking how they are selling “overpriced shit” (not my words)!!!
WTF?
I don’t remember so much bashing threads and souch invasion of sales (group buy) threads. At least one GB thread appears every day, many of them are organised before actual light that is subject of the thread is even made or available anywhere like Sunwayman C22C, no one actually tested that flashlight or saw it in person but we all want to be among exclusive 50 to have it first! So now the manufacturer is under pressure, they want to satisfy hungry BUFers but what happens if at some point later someone discovers some flaw, should we start sharpening guillotine right away!
The light as a light has X value.
The light with included charging capability is worth X plus Y.
If you use said function Y, you are at personal risk. Id call that a piece of crap. How many people, and lets not carry on like they only sell to flashaholics, are aware that there is potential that their flashlight will blow up resulting in significant damage potential? For Chrsits sake, most people hand torches to kids to run around with. They think its a torch, what could possibly go wrong, its not mains powered or anything, these are just batteries after all.
Again, this isnt over night, or straight away, its been quite some time that BLF has been patiently waiting. Its funny, you question accusing Acebeam of things they are and have done, but youre quite fine to accuse members here of doing things they neither have nor are doing. Oh the irony.
To clarify.
- Its not overnight.
- Its not one problem and everyone immediately took up pitch forks.
- They have the chance to fix it,
- theyve had plenty of time to get it done
- FP is suggesting as a community we stand together as it has taken so long.
- There is a history of promises, never coming to fruition.
- The fact we wanted lights, does not somehow translate to consent to be sold duds, and not complain.
As you say, more than your monthly salary, so not an insignificant price then?
