Acebeam K60 XHP70 5000lm mega thrower 124100cd 704m
From their site:
“2015 K60 CREE XHP70 5000LM Throw 700M
The Acebeam K60 employ new signle CREE XHP50 LED emitter supply max 5000lm and bring 704m beam distance”
update 31.03.2015
“Features:
LED: Cree XHP70 LED with a lifespan of 10+years of run time
Max 5000lumens output (4x 18650 batteries)
Output (select by magnetic ring):
Level 1 : 0.9lm(1200hrs);
Level 2 : 300lm(320hrs);
Level 3 : 1000lm(35hrs);
Level 4 : 2000lm(16hrs);
Level 5 : 3400lm(6.9hrs)
Level 6 : 5000lm(3.2hrs);
Standby : 65uA
Strobe : 5000lm;
Working voltage: 10V - 17V;
Max Runtime: 1200 hours;
Max beam distance: 704meters;
Peak beam intensity: 124100lux;
Impact resistant: 2 meters;
Waterproof : IPX-8 Standard (2meters);
Size: 205mm(length) x 88mm(head diameter)*50mm(tube diameter);
Weight: 720g(without batteries);
Aircraft grade aluminum body structure;
Accessories include:
1x user manual;
1x lanyard;
1x holster;
1x Replacement O - ring and Tailcapgummi;”
Specs updated 28.04.2015
Products specifications
LED Cree XHP70 LED with a lifespan of 10+years of run time
Luminance 5000LM
Beam Throw 124100cd Throw 700M
Waterproof IPX-8 2M
Vihn’s cpf thread
Acebeam has tightened it’s policy (MAP) and no discount coupons are available:-(
Please hold off on purchasing any Acebeam products until they resolve the cell recharge/discharge voltage imbalance problems with their multi-celled flashlights.
It took a huge number of customer complainants and other threats for them to even acknowledge that there was a problem, and that lives might potentially be at risk if a cell vented/exploded. Acebeam still hasnt resolved the problem yet, so we need to wait a good deal longer to see if they correct the problems with the huge number of flashlights they have already sold before buying another expensive dangerous Acebeam flashlight.
Please DO NOT BUY ANY ACEBEAM PRODUCTS until they have resolved this problem!
Bella, dozens of very angry Acebeam/Supbeam owners are still waiting for your reply in the X60 GB sales thread. Read post 682 forward. When will we be receiving the revised cell carriers for our flashlights?? Please reply.
For Heaven’s sake… some of us still believe charging the old fashioned way … which is charging outside the light.
are we supposed to pass a good light if they offered it at a good price because some people are so adamant about charging the batteries inside the light?
:neutral_face:
Not true! The problem effects recharging and discharging. Several members have reported using an external charger to recharge their cells, only to note large cell voltage differences after discharge, thanks to a very poorly designed cell carrier.
Folks, please DO NOT BUY Acebeam flashlights until the manufacturer has definitively resolved the problem. I will keep everyone updated with test results of the newly designed battery carriers, assuming Acebeam makes good on its word and produces them. Until then, there are many other lights to satisfy the techno lumen junkie.
This light does not include in-light charging, does it? Looks good.
Doesn’t seem like it has in-light charging, but I wish the mode spacing was a bit more like this.
Level 1 : 0.9 to 0.9
Level 2 : 300 to 50
Level 3 : 1000 to 250
Level 4 : 2000 to 1000
Level 5 : 3400 to 2500
Level 6 : 5000 to 5000
LED: Cree XHP70-LED mit einer Lebensdauer von über 10 Jahren Laufzeit
Max-5000lumens-Ausgang (4 x 18650 Akkus)
Ausgang (nach Magnetring auswählen):
Stufe 1: 0.9lm(1200hrs);
Stufe 2: 300lm(320hrs);
Stufe 3: 1000lm(35hrs);
Stufe 4: 2000lm(16hrs);
Stufe 5: 3400lm(6.9hrs)
Stufe 6: 5000lm(3.2hrs);
Standby: 65uA
Strobe: 5000lm;
Betriebsspannung: 10V - 17V;
Max Runtime: 1200 Stunden;
Max Strahlabstand: 704meters;
Spitzenintensität-Beam/Ausleuchtzone: 124100 Lux;
Schlagfest: 2 Meter;
Wasserdicht: IPX-8 Standard (2meters);
Größe: 205mm(length) X 88 Mm(head diameter) * 50 mm (Rohrdurchmesser);
Gewicht: 720g (ohne Batterien);
Aircraft Grade Aluminium Karosseriestruktur;
Zubehör gehören:
1 x Bedienungsanleitung;
1 X Halsband;
1 X Halfter;
1 x Ersatz O - Ring und Tailcapgummi;
I
I never charge my batteries inside the flashlight, but I know that a lot people will find that more convenient. If it doesn’t work correctly, it’s better not to have it at all.
Good heads up Flashpilot but I think this model doesn’t come with built in charger…
It apparently affects all of their flashlights with cell carriers. Several BLF members have reported Supbeam/Acebeam flashlights without in-light chargers to show large cell voltage variances after discharge. So its not just the lights with in-light charging that are of concern.
So if you have one with a cell carrier, check your beginning and ending voltages before assuming your flashlight is safe to use.
Isn’t the battery carrier in the “non in-light charging” category just a bunch of connections basically, without any IC? How would that discharge cells differently? I just have a K40M, haven’t checked the cells yet.
That would seem logical to me. :bigsmile: There are now literally thousands of BLF posts spread out across several Supbeam/Acebeam threads. I only own the X50 and X60, both of which have the charging problem I described (with in-light charging).
Since the manufacturer has seriously dragged its feet for a long time while attempted to convince me that their faulty design was acceptable, I hope everyone will wait to see if they will do as promised before buying any more of their products. Also, you might want to reference the K50 GB and X60 GB discussion threads for a better perspective of what you are considering buying, along with the later discoveries of some of their inherent faults.
O come on people, let’s spread some love instead :stuck_out_tongue:
I like new T25, I will apply for review :smiley:
For cells in series it is important that they are identical. Otherwise it is possible that one cell that discharge faster may be "reveres charged" and be damaged/vent. But that also depends on the driver, if it has low voltage shut off, and if the cells are protected.
And the same cells (brand/model) with different ages may have been used/abused differently and may have different internal resistance and capacity. So when charging cells that are intended to be used in series it is good to have a charger that can test the internal resitance and capacity so you can verify that it still is the same, or very similar, for all of the cells. If you can't test the the cells, it is safer to only use protected cells.
Of course Adoby, I was assuming all cells were exactly identical. I guess I should have wrote it, seemed common sense to me.
Yes, but without actually checking your assumption may very well be wrong. And you actually said that you haven't checked the cells you use in your K40M.
It is commonly implied at BLF that it is good practice to use same cells (same manufacturer, same capacity, same age and preferably same batch) especially if they are in serial connection.
I think what DanielM meant is that he didn’t checked cells at what voltage level is every individual cell after discharging in his flashlight:
Exactly Sirius9, and I don’t see any reason why the cells in a dumb carrier would be discharged differently. I will check when I get home to add already existing data.
hopefully available as a flash deal like the K40M was…
@flashpilot. After reading this I checked the cells on my K40. All brand new Panasonics, I get 4.06, 4.07 and 4.07. I know they are not very discharged but it does not seem too much of s problem for me so far.
What kind of voltages are you getting on yours?
Marc
The performance are very impressive ! :open_mouth:
3400 more lumens than K50 with similar runtime (3.2h) but with a little less trow : 124klux vs 140klux. The design look like a prototype though.
