17mm/22mm MTN-MAXlp - Low-Profile 1A-4A Programmable Buck Driver + 22mm MTN-MAX
227 posts / 0 new
ImA4Wheelr
Last seen: 1 month 4 days ago
A small, high-current buck has been a bit of an elusive holy grail for some time now.  If anyone can pull it off, RMM will likely be the person.
RMM
RMM's picture
n10sivern wrote:
I believe he is designing 17mm low and high current drivers. It shouldn't take much to extend the borders for the OshPark boards so he will probably release 20mm as well, but the goal is the 17mm boards as there is more of a need for them.
Your first mistake is believing that even I have any idea what I'm going to be working or releasing. Surprised
For 20mm/22mm there's enough room for a decent sized inductor, so there's no need for two boards with the 20mm and 22mm.  My early attempts were to "have it all" in a single 17mm design, and those didn't work out very well.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
n10sivern
n10sivern's picture
Last seen: 2 days 39 min ago
RMM wrote:
n10sivern wrote:
I believe he is designing 17mm low and high current drivers. It shouldn’t take much to extend the borders for the OshPark boards so he will probably release 20mm as well, but the goal is the 17mm boards as there is more of a need for them.
Your first mistake is believing that even I have any idea what I’m going to be working or releasing. Surprised
For 20mm/22mm there’s enough room for a decent sized inductor, so there’s no need for two boards with the 20mm and 22mm.  My early attempts were to “have it all” in a single 17mm design, and those didn’t work out very well.
I wasn’t trying to put words in your mouth. The OP is about a low profile 17mm buck driver and you mentioned a taller 6a+ Version. I apologize if I wrongly guessed you would release a 20mm version once you were able to get the 17mm worked out. Ultimately, we are all just sitting back in anticipation of what you are able to come up with.
Three tomatoes are walking down the street- a poppa tomato, a momma tomato, and a little baby tomato. Baby tomato starts lagging behind. Poppa tomato gets angry, goes over to the baby tomato, and smooches him… and says, Catch up.
RMM
RMM's picture
Just to clarify, here's my current roadmap:
17mm, 2 boards:
i. MTN-MAXlp: 4A max, low-profile, small SMD inductor. [RELEASED]
ii. MTN-MAX: 6A+ max, larger external inductor. [IN TESTING]
20mm, 1 board: MTN-MAX: 6A+ max, either a larger SMD inductor or external inductor. [IN TESTING]
22mm, 1 board: MTN-MAX: 6A+ max, single sided, either larger SMD inductor or external inductor. [IN TESTING]
Plus some other larger boards down the line, with the same basic layout but improved efficiency due to the availability of space for a larger inductor.
Tom E
Tom E's picture
Last seen: 2 hours 55 min ago
Wow - this is great to have a true programmable buck driver! Thanx again Richard!
Question: I'm sure I missed this somewhere, but how do you program one of those MCU's in that form factor? Can it be programmed on-board?
I think I saw these listed on your site but didn't know what they went with. Can't navigate Mtn-E now to explore...
seasam
Last seen: 5 years 3 months ago
Tom E wrote:
Wow – this is great to have a true programmable buck driver! Thanx again Richard!
Question: I’m sure I missed this somewhere, but how do you program one of those MCU’s in that form factor? Can it be programmed on-board?
I think I saw these listed on your site but didn’t know what they went with. Can’t navigate Mtn-E now to explore…
there’s a mmu programming board in the oshparks thread:
https://oshpark.com/shared_projects/uyjO7GgP
Tom E
Tom E's picture
Does this mean no option for doing on-board re-programming with this MCU?
RMM
RMM's picture
Yes.  You're gonna have to pick a firmware and stick with it for a while, which I know will be hard for you to do! Wink
I played around with adding some breakout traces to solder wires to, but that's more of a pain than just reflowing the dang thing and it makes a mess on the battery side.
Edit:  If you were really determined, you could get away with just two breakout traces for RST and MOSI, then solder the other wires to the existing components that are used for the other signals, but that I think that may be more trouble than it's worth.
Tom E
Tom E's picture
Ok - may be a challenge when tweaking LVP, timing checks, etc - those are more of the reasons for me vs. changing mode selections later on. May be a good bench setup could be done for doing those kind of tests/tweaks?
Couple of reflows of the MCU would probably be dicey for me... Dunno...
RMM
RMM's picture
Just use the standard 130 off time value. No need to tweak. All that I've built have been pretty consistent.
Tom E
Tom E's picture
Ahhh - so one value for any # of cells (of course parts are different for different # of cells as stated)? That would be real nice... I'm think'n my need is 2 cells right now.
RMM
RMM's picture
Oh, no.  Read that on my phone and missed the LVP part.  Right now it's set it for one set of cells and go, but I was going to get around to adding some logic that would let it work with 2S-3S without changing anything in the firmware.
pilotdog68
pilotdog68's picture
^^^Cool stuff. No wonder you’re such a busy guy Wink
Ronin42
Ronin42's picture
Last seen: 1 year 11 months ago
n10sivern wrote:
Ronin42 wrote:
Richard, thanks.
Let us know when (we the build challanged) can buy this/these from your store?
I have three s7 hosts which I want to get drivers for along with incidentals.
  1. a triple using the XP-E 660nm Photo Red emitters (probably a different driver)
  2. a MT-G2 with 2× 18350 (this driver)
  3. a (other)
You shouldn’t need this buck driver for #2. MT-G2 runs off 6V which you have with the 2 18350 batteries. Any of the Zener modded drivers should suffice for that. This buck is going to drop the voltage of multiple cells down to 3v so that you could run something like a XM-L2 off multiple cells in series.
From what little research I have done the zener mods are inefficent at low power, thus I have been waiting on a (less then 4 amp is fine) 6V buck to run the 6V emitters but with out spilling the difference into heat. I am no expert and I might have gotten somting reversed but it seems that for other then DD way hot short run lights a more sophisticated driver is needed.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
jhalb
jhalb's picture
Last seen: 4 years 6 months ago
How are you controlling the amperage of these drivers? I see 4 amp and 6 amp listed. Is it a function of what the battery has available? If it is then other than the components used, isn’t it DD?
RMM
RMM's picture
jhalb wrote:
How are you controlling the amperage of these drivers? I see 4 amp and 6 amp listed. Is it a function of what the battery has available? If it is then other than the components used, isn't it DD?
Look up "buck converter".
jhalb
jhalb's picture
Yea, well that is beyond me. I don’t get it. I’m reading more…
I really wish I could understand what exactly different size inductors do. I’m going to start studying it..
BTW, I need another M6, when are you opening back up? :bigsmile:
MRsDNF
MRsDNF's picture
Last seen: 2 months 3 days ago
Richard. Be a nice boy now and get back in that nursery and look after the good wife before I come around and spank you. This forum will survive without you for a few days. Saying that, will you survive without us for a few days?Laughing
RMM
RMM's picture
Ronin42 wrote:
n10sivern wrote:
Ronin42 wrote:
Richard, thanks. Let us know when (we the build challanged) can buy this/these from your store? I have three s7 hosts which I want to get drivers for along with incidentals. #1 a triple using the XP-E 660nm Photo Red emitters (probably a different driver) #2 a MT-G2 with 2x 18350 (this driver) #3 a (other)
You shouldn't need this buck driver for #2. MT-G2 runs off 6V which you have with the 2 18350 batteries. Any of the Zener modded drivers should suffice for that. This buck is going to drop the voltage of multiple cells down to 3v so that you could run something like a XM-L2 off multiple cells in series.
This may be less efficient running an MT-G2 off of two 18350s, depending on what current level you set it at.  I suspect that at 3A or more the 7135 driver will be on average more efficient over the full discharge of the batteries.  If you wanted to run an MT-G2 at something silly like 1.5A or 2A the buck driver would probably be more efficient.
Linear regulators, like the AMC7135, are pretty efficient where the input voltage is close to where the output voltage is needed to maintain a certain output, with all extra being turned into heat.  With 18350s at 3A and above there is enough voltage sag that you're not staying very far above what is needed for very long.
With a buck regulator, you generally have more switching losses, and you are also always running all of the LED current through a sense resistor, which burns off power, and through an inductor, which also burns off some power (especially smaller inductors).  So, when input and output drop to the even, or almost even point, the efficiency of the small buck driver will be worse than what you would have gotten out of a 7135 based driver.
Now, remember that this may not hold true for 2x26650 or 2x18650 running an MT-G2 at lower amps, but an MT-G2 with 2x18350s at 3A+ I think that the 7135s are actually doing a pretty good job efficiency-wise.
RMM
RMM's picture
Has anyone received their boards yet?  Anyone built one yet?  I've built several of these now in different configurations and have them in different lights, and I feel very confident that they work and work well.
A few more thoughts and tips:
1. Absolutely do not try to solder this by hand.  You need to reflow to get these done right, especially since the thermal pad under the buck IC is critical to proper performance.
2. Make sure you get enough solder underneath the Buck IC's thermal pad.  The thermal vias tend to wick up some of the solder, so you need a bit more than you would think.
3. Space your low and critical levels a bit farther apart than you normally would.  For example, if you normally use 160 and 145 for your low and critical values, use 170 and 145 instead.  The way that the buck driver loads the batteries is different than with a DD or linear driver single-cell setup, because the current draw actually increases on each cell as they drain instead of decreasing, so having values that are too close together leads to an immediate shutoff after the LVP is activated with no or very little "in between" time.
n10sivern
n10sivern's picture
OshPark expects my boards to be back around 4-19. The OP was 4-5 and I ordered 4-7. That being said I don’t even have all the stuff to attempt this build yet, nor am I confident enough that I won’t screw it up.
RMM
RMM's picture
Sometimes part of learning is failing, although I try to avoid that part if possible! Smile
n10sivern
n10sivern's picture
Oh I’m well aware of that. Like you, I just hate failing.
pilotdog68
Parts kit coming at mtn?
RMM
RMM's picture
Is there interest? You're the first one who's asked for one.  If there's a few more I'll put one up.
pilotdog68
Oh.. I just assumed. I don’t plan on making enough of these to make a larger order from mouser worth it. How many parts will be shared between this one and the 20mm?
RMM
RMM's picture
Preliminarily it is all the same except for the flyback diode and sense resistor, although maybe I'll end up with two different 20mm boards so that those who have parts for the 17mm and don't need more than 3.5A-4A can use the same parts.
bibihang
bibihang's picture
Last seen: 8 hours 33 min ago
RMM wrote:
Is there interest? You’re the first one who’s asked for one.  If there’s a few more I’ll put one up.
I’m actually interested in complete driver, do you offer them now or in the near future?
RMM
RMM's picture
I probably won't be offering them complete for a while because I just don't have time to build them right now.  I have built a few for a customer who asked about them a few months ago, but besides that I've only built them for myself.
That said, I have two of them complete right now that I've built that are just sitting on the shelf I could sell.  I will list them on the garage sale page.
I will get a parts kit up tomorrow.
n10sivern
n10sivern's picture
Richard, do you already have enough spares for a parts kit now or would you have to order? Reason I ask is I already have a order with you that I’m sure you haven’t had time to complete. If you already have the stuff then I’d like to purchase a couple kits and have it shipped with the other order. If you would have to order it, I’d probably just place another order with mouser. I can always find more stuff to buy I don’t really need, just like shipping with you! I have a 2S UF-1405 that I had planned on putting an E2 Torch in and using a low current buck, but I’d rather push a G2 at 4a.
