Unfortunately currently do not own a good camera, pictures are taken with a cheap Olympus VR 340, and I bet it would look 5 times better that I took pictures with some better camera. weather conditions were not ideal, because of the low cloud cover and weak drizzle. Also street lighting reduces the effective range of a flashlight.
This is a well known resistor removed mode , I am using 20 AWG silicone wires,all springs are bridged,and my own made
copper pill is inside. Dedomed XM-L2 U3 1A on 20mm Noctigon with fully charged 3 x Panasonic 18650PF 2900mAh is pushed to 5 Amps. Also there is no moon mode like other members did have. Main reason this is happening because -(minus ) wire is touching
something it should not !!
Here are some photos …
Enjoy ….
Copper pill
OLD vs NEW
Tail wires bridged
And the actual flashlight finished ………
Control shot daylight, old and closed Hotel Jugoslavia is in a far distance
10 x ZOOM
And Google Earth say 1100 + meters
This is the closest building,and to the roof there is 120 meters
Some shot in cloudy sky
120 meter shot
Night shoot control
Same with light on
10 x zoomed complete darkness
10 X ZOOM AND 1100 METER SHOT , YOU CAN CLEARLY SEE THE ROOMS ON HOTEL
THIS IS THE GREAT AND EASY TO BUILD THROWER, AND IF YOU WANT SOMETHING LIKE THIS, BEST PRICE IS AT GEARBEST.
FOR COPPER PILL YOU CAN CONTACT ME ON PM.
HOPE YOU LIKE IT !
Good mod!
Sure you are above 300kcd! 8)
thanks for sharing
Sorry for my bad English…
Awesome!.. pm sent for copper pill
The only way to do a great work is to love what you do.
Wow. Good job!
Joeholmanonline.com
300+ kcd FOR SURE !
Can’t see the pics
Nice work, putting that copper to good use!
Complete conversion of BTU shocker: 3x Mt-g2, Handle, Battery Pack. >9000Lumens ~150W
Courui "Even Bigger Head" D01
Stock driver?
Yes STOCK
only R200 resistor removed
I gotta get me one of these. Why didn’t you use an XP-L rather than an XM-L?
I dont think there would be much improvement with XP-L, and its much harder to focus, XM-L2 U3 bin is bright enough for me.
But why not give it a try !!
I always enjoy this kind of long-range beamshots, thank you! You did a great job on the mod and the photography as well.
great pictures!
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Can you explain why you have bridged the tail wires and what have you done with the solder and wire over the 2 screws?
Have you still added braid/wire to the springs?
Thanks for the info.
fireball
Well the screws are very poor quality so I have inserted peace of same wire used for springs into the screw holes,tighten them down and put some solder over the top. Every contact on the tail is bridged and now reacts as a solid body. I did this to the driver
also for the better contact with the head….. 8)
