New version SK68 with Rotate Zoom?
11 posts / 0 new
beam0
beam0's picture
Last seen: 5 hours 57 min ago
Has anyone seen or have one of these? Looks like an SK68 with threaded rotating zoom ring instead of push/pull.
mini led lithium ion Rotate zoom torch flashlight 14500
Q5 5W 300LM
Plus it has the added HOLE SAW BEZEL feature to “cut” through the night! Wink
Edited by: beam0 on 04/12/2015 - 01:59
light junkie
light junkie's picture
Last seen: 1 month 1 week ago
Good catch I’m always looking for new zoomies :bigsmile:
Lj
sedstar
Last seen: 3 weeks 4 days ago
geez louise…
i about need a small table top metal lathe, just to cut off all the danged weird crenallations they keep coming up with, lol… THAT bezel looks like its just waiting to rip up the pockets of my expensive winter coats, lol…
who ever first came up with the word “tactical” about needs their @$$ removed, lol…
that aside? if it focuses up to a sharp emitter?? i think its cool…
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 3 months ago
Is it actually a rotateable zoom, or is it just a knurled ring on the back of the screw in part of the head?
If it is rotatable I will be getting them (just hope the price drops)!
Antenne
Antenne's picture
Last seen: 1 day 2 hours ago
A few days ago I got this AA light from Tmart: http://www.tmart.com/Mini-CREE-Q3-3W-120LM-3-Mode-Focusing-Flashlight-Black_p135869.html (The description is wrong, it’s an AA light)
Compared to the SK68-clones it is rather disappointing. The main negative points:
- rather dim
- moving small pill >> bad heat dissipation
- narrow bezel and small lens limit the flood angle
- old XR-E Emitter
- if you screw down the head the focus ring won’t move
Most of my other zoomies (18650 or AA/14500) aren’t that bright either, so I think I’m done buying them anymore. There was a nice BLF thread about the losses you get with the simple optics of most of those zoomies, I think it’s not worth the hassle.
The SK68 might be ok, but even the two I’ve got (one “Ultrafire” and one “Thorfire”) have very different lenses (diameter..) and beams, the Ultrafire one is ok but the Thorfire ringy and narrow.
beam0
beam0's picture
War, on the listing for it if you scroll down there are some photos of the light with the bezel off. From what I can tell it appears to be a legitimate rotatable zoom.
Looks like the LED stays stationary and the ring is on threads and moves only the lens in and out. (there is a slot where what appears to be an extended part of the lens rides in for actuation of the zoom)
Also appears the hole saw bezel is maybe a light press fit and slips on over the shouldered part of the zoom control ring.
If I am correct then I like this arrangement, like a completely re engineered zooming system on an sk68.
I’m not the expert on zoomies but take a look and see if you’re seeing what I am.
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 2 years 10 months ago
There is a Smiling Shark moving pill AA zoomy that has reasonable cooling, but usually that configuration is not good for high power, and I don’t really see any advantage to it.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
beam0
beam0's picture
sedstar wrote:
geez louise…
Yeah, I was already thinking to smooth those off, my belt sander is on standby for this one!
Agreed, this one is ridicules, what are we suppose to do, saw a hole in an attacker? I hate all of these so called “attack bezels” I like just a smooth (preferably stainless) bezel. I couldn’t see trying to push the bezel of my flashlight into someone for self defense. I have better weapons for that. Wink
But, …If your gonna do it, …might as well go all out and do it right,
…like this one Evil :
(The infamous “Kilngon” Bezel)
beam0
beam0's picture
Agreed. From what I understand moving the pill instead of moving the lens makes for much worse cooling due to less solid contact to the body for heat dissipation?
That’s why I like this setup with what appears to be a stationary pill.
I’m sure there are a lot of other AA zoomies out there with rotating zoom, I just like this one because it’s based on the renowned sk68.
CyrusAM
Last seen: 3 years 3 months ago
I’ve never had good luck with cheap rotating zoomies, somehow they always find a way to get stuck. Might be better for people using them on bikes since they are less likely to slide on their own (apparently it’s a common problem).
The light on my shotgun is tactical. My 5.11 boots are tactical. My plate carrier and chest rig where tactical. Crenelations on a small light are not. Stop calling this cheap useless crap tactical, all it does is make mall cops more likely to buy it.
Socorro Search and RescueI wear my sunglasses at night
hank
hank's picture
Last seen: 9 hours 7 min ago
> hole saw bezel
What’ll they think of next …
Hey, I know — apply that little motor used to zoom camera lenses and some flashlights to rotate the hole saw bezel!
Tactical assault bezel fu!
