FS : LED centering rings / positioning / insulating – made to your specs (CLOSED)
124 posts / 0 new
Hoop
Hoop's picture
Last seen: 44 min 2 sec ago
My hunch is that simply punching the stars may not create a sharp enough edge to prevent shorts, but it may be ok with a little bit of cleanup. I think you could punch them close to 16mm but oversize, then use a sander to finish the job. This would save time over only using the sander. The sander method has been successful.
I have however been re-machining XHP-70 boards from 20mm to 16mm, and they do not short. The star gets chamfered on both sides. I can also do this with the LED’s pre-soldered on the star without damaging the LED. These and the colored stars will be available shortly. I really had expected the star manufacturers to offer these by now but since they aren’t, it’s about to time to fill the void.
Hoop
Hoop's picture
In regards to relief for the excess solder, I could do it a couple ways. The version pictured on the left is easiest, and I can complete those in a single operation. The partial relief on the right would require a fixture to be built for the secondary operation. For one off’s I’d have to stick with the left side version, but if a particular star becomes more of a standard offering, I could do the other style. Thoughts?
LinusHofmann
LinusHofmann's picture
Last seen: 2 years 3 months ago
No preference for me regarding the cutouts for solder balls, so whatever is quickest/easiest. Personally I’ll just cut a bevel or cutout if needed with an xacto blade.
So my request would be for the following:
XHP70 led to fit an SSC-P7 C8 reflector. (either white or black is fine for these)
Quantity: x6
Led Cutout: 7mmx7mm (whatever is your standard for XHP70s)
OD: 12.5mm
Reflector Hole Diameter: 9.25mm
Thickness: 2mm base + ~1mm lip
Notes: Non-continuous lip as shown in your examples. No cutouts for solder balls required, no fancy outer shape, circular is fine.
SBT-70 led to fit KD 86mm reflector (would love it if these could be black if possible)
Quantity: x2
Led Cutout: 11mm x 10mm (rectangular but centered)
OD: 26mm
Reflector Hole Diameter: 19.5mm
Thickness: 1mm base + ~2mm lip
Notes: Continuous circular lip. No cutouts for solder balls required, no fancy outer shape, circular is fine.
XML2 led to fit KD 86mm reflector (again black if possible)
Quantity: x2
Led Cutout: 5mmx5mm (XM-L2 standard)
OD: 26mm
Hope that’s enough info, if you need clarification on anything let me know.
Cheers and thanks again for offering this, very cool!
Linus
EDIT: Changed lip to 2mm on 86mm rings
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 5 days ago
It seems like every time I have to use a butterfly spacer I have to cut more off because the solder pads are under the tabs. A design with the square cut at 45 to the tabs would fill a missing nitch. The 16 mm Sinkpads are my source of angst.
Scott
Hoop
Hoop's picture
Linus, for your C8 gasket, some of the light will be blocked due to the height and the 120* LED emission angle. I think the best I could do to correct this is use 1/32” stainless steel dowel pins and also put a heavy chamfer on the square pocket. Let me know what you think:
I haven’t modeled the other ones yet.
LinusHofmann
I made the base extra thick to give me a bit of adjustment room regarding focusing of the led. i.e Gives me some leeway in terms of pulling the emitter out of the reflector some ways, I intend to sand them down to a minimum once I’m happy I’ve found a decent compromise between minimizing the donutyness of the hotspot and maximizing output on these particular reflectors. Smile
I wish I could give you some more exact dimensions to fully take advantage of your great service but this will have to do for now.
The dowels are a cool idea but I’m happy just to go with something standard like these
Cheers
Linus
Hoop
Hoop's picture
Added LinusHofmann’s rings to OP.
Sirius9 wrote:
How about centering rings for Convoy C8 reflector and XP-G2/XP-E2 leds!
Added XP / Nichia c-ring for new style SMO C8 to OP. Also for Convoy S2+.
MG
Last seen: 4 months 4 weeks ago
I would like a Convoy S2+ xp/nichia c-ring;
xhp-70 C8 ring;
and a 16mm xhp-70 board if/when you decide to do these.
Thanks for doing this.
LinusHofmann
Awesome thanks!
Hoop
Hoop's picture
Test cut a couple of the S2+ xp series rings. It seems the process is more forgiving than I thought it would be so I will probably be able to make these out of black acetal (delrin) rather than nylon. :bigsmile: Acetal machines a lot nicer than nylon and should require less deburring effort. I will test the process with acetal shortly.
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 10 months ago
Very nice looking! For me, I don't give a hoot about color, so anything will be ok for me.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
MRsDNF
MRsDNF's picture
Nice work hoop.
prisma
I would like to have one of the XML to KD 86mm reflector please.
shrick
shrick's picture
Last seen: 3 years 2 months ago
Hi Hoop
I’m in the process of getting a mini lathe & -mill. I’m very much still a newbie related to fabrication of parts & the 2 machines mentioned.
Would it be possible to do the round center rings with a mini lathe/-mill combination? It would be great if I can make my own, on small scale?
I’m thinking of the following steps…
  1. Starting with a solid peace of nylon tubing.
  2. Turning the ring to size.
  3. Turning the extruded centering part to size.
  4. Then milling out the center square. I’m not sure if one gets such a small milling bit though?
  5. Then when all is done, cutting the final ‘disc’ to the correct thickness from the piece of solid nylon.
Hope it makes sense? Will this be possible to do?
Thanks a lot.
D10ten
D10ten's picture
Last seen: 2 weeks 2 days ago
This is awesome, I would definitely want some XP/Nichia to C8 ring.
shrick
shrick's picture
Sirius9 wrote:
RMM wrote:
Just use the XM ring and let the reflector twist and center the LED.
I am doing exactly that and it sucks balls how precise it is…
Hi Sirius9. Can you maybe post a photo of how the XML centering ring is used here? I can’t 100% picture what you guys are describing. Thanks.
Sirius9
Sirius9's picture
Last seen: 1 week 5 days ago
I usually sand down the centering ring bottom side and then use superglue to prevent it from rotating when tightening reflector/bezel. I also put a tiny-tiny bit of grease on the top edge/lip of centering ring where reflector will sit so that it could slide more easily when I tighten everything up
shrick
shrick's picture
Sirius9 wrote:
OK, will do that in hour or so…
Thanks, appreciated.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 day 14 hours ago
Wow, just noticed Hoop hasn’t been around for – 3 weeks?
KB1428 “Live Life WOT
shrick
shrick's picture
Thanks for the effort Sirius9. Im gonna to give it a try,
Hoop
Hoop's picture
Hi fellas. I got into a rather large machining job which I had to prioritize and haven’t had time for anything else. I see the light at the end of the tunnel though and will be able to get back to my fun/hobby projects soon. I will update when I cut some of these these from black acetal.
shrick, I’d recommend using acetal (delrin) if you make them manually. It’s doable but not the easiest project for a novice and it will probably take more effort than it’s worth. As for the tiny end mills, you can use a 1/32” 2fl which shouldn’t give you any trouble in acetal. In the square pocket, machine a relief past the corners in one axis to provide clearance, at least the radius of the cutter in length.
shrick
shrick's picture
Hi Hoop. Welcome Back Smile Thanks for your feedback, appreciated. I’m going to find out if I can get my hands on acetal/delrin and what it costs.
nofearek9
nofearek9's picture
Last seen: 4 hours 34 min ago
hoop do you still make those ?
Quantity: x2
OD: 26mm
i would like similar ,BUT for XP-G2 led.
LSX
LSX's picture
Last seen: 3 days 4 hours ago
Are these still available for order?
DavidEF
DavidEF's picture
Last seen: 2 weeks 6 days ago
LSX, the last post from Hoop was quite a while back (05-25-2015), in which he said:
Maybe you could PM him and see if he answers?
- The YKK Philosophy
bibihang
bibihang's picture
Last seen: 1 hour 25 min ago
I just notice this thread, but Hoop doesn’t seem to online very often. I would like to order a few pieces of XP-G2 size to new Convoy C8 XM-L2 reflector, is this offer still going on?
Kenjii
Kenjii's picture
Last seen: 7 months 2 weeks ago
Hi,
would such an XP2XM-Adapter be possible? Outer diameter of XM-Footprint and inner Diameter of the XP-Footprint so they could fit the original centering adapters. I often swap XM-L2 against XP-L or XP-G2. At the moment i make these by hand with a file from an XP-centering adapter …
Greetings
Kenjii
LSX
LSX's picture
I would buy like 20-30 of those if I could get some. It frustrates me to no end that I can’t get an XM centering ring just with an XP internal dimension. It seems soo simple and yet no one has them and the fasttech ones suck, have already tried them.
allthumbs
Last seen: 5 years 2 months ago
Could this be done on a 3D printer?
DavidEF
DavidEF's picture
Well, technically, it could, except that the plastic used for 3D printing is made to melt at a low-ish temp, and these LEDs create quite a bit of heat when run hard. Of course, the solution is to not run your LED very hard. :_(
