Test/Review of Samsung ICR18650-30B 3000mAh (Green)
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 23 hours ago
DSC_8184
Official specifications:
  • Nominal Capacity: 2950mAh (0.2C, 2.75V discharge)
  • Minimum Capacity: 2850mAh(0.2C, 2.75V discharge)
  • Charging Voltage: 4.35 ±0.03 V
  • Nominal Voltage: 3.78V
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1475mA, Rapid charge : 2950mA
  • Charging Time: Standard charge : 3hours, Rapid charge : 2.5hours
  • Max. Charge Current: 2950mA (ambient temperature 25°C)
  • Max. Discharge Current: 5900mA (ambient temperature 25°C)
  • Discharge Cut-off Voltage: 2.75V
  • Cycle life: 299 cycles to 70%
  • Cell Weight: 48.0g max
  • Cell Dimension: Height : 65.00mm max, Diameter : 18.40mm max
  • Operating Temperature: Charge : 0 to 45°C, Discharge: -20 to 60°C,
  • Storage Temperature: 1 year: -20~25°C, 3 months: -20~45°C, 1 month: -20~50°C
Note the charge voltage, it is +/-0.03 volt tolerance, not the usual +/-0.05 volt.
Test with 4.35 volt charging
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.35V-info
These cells are high capacity cells with moderate current capability. The higher voltage means more energy.
DSC_8183
DSC_8185 DSC_8186
DSC_8187
DSC_8188
DSC_8189
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.35V-Capacity
The discharge curves looks nice, good tracking and nearly constant capacity. The cell has a little trouble with the 7A track, it heats up a bit and this improves the performance.
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.35V-CapacityTimeHours
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.35V-Energy
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.35V-PowerLoadTime
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.35V-TripCurrent
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.35V-Charge
Test with 4.3 volt charging
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.3V-info
Reducing the charge voltage to 4.30 volt means losing about 100-150mAh.
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.3V-Capacity
The slightly lower voltage makes the discharge curve be more load independent.
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.3V-CapacityTimeHours
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.3V-Energy
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.3V-PowerLoadTime
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.3V-TripCurrent
Samsung%20ICR18650-30B%203000mAh%20(Green)%204.3V-Charge
Test with 4.20 volt charging
Samsung%20ICR18650-30B%203000mAh%20(Green)-info
At 4.2 volt charging the loss is about 400mAh compared to 4.35 volt.
Samsung%20ICR18650-30B%203000mAh%20(Green)-Capacity
The independence of load is also present at 4.2 volt.
Samsung%20ICR18650-30B%203000mAh%20(Green)-CapacityTimeHours
Samsung%20ICR18650-30B%203000mAh%20(Green)-Energy
Samsung%20ICR18650-30B%203000mAh%20(Green)-PowerLoadTime
Samsung%20ICR18650-30B%203000mAh%20(Green)-TripCurrent
Samsung%20ICR18650-30B%203000mAh%20(Green)-Charge
Conclusion
This cell has a more flat discharge curve than some high capacity cells, this means higher voltage at the last part of the discharge at any charge voltage. The initial part of the discharge will be higher when charged from 4.35 volt (only at low loads).
It is a very good cell, but requires a 4.35V charger for best performance.
Notes and links
For 4.35 volt chargers check my chargers reviews, Xtar has a some: WP2h, VP2, SP1.
Compare to 18650 and other batteries
JaredM
JaredM's picture
Last seen: 8 hours 56 min ago
Thank you for the review. Appreciated as always! (I check you site at least twice a day and just can’t get enough of your reviews.. sad I know Silly )
pilotdog68
pilotdog68's picture
Last seen: 7 months 2 weeks ago
I’ve been using 30B’s for a while now, I’m glad they tested well.
lagman
lagman's picture
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
lagman
lagman's picture
cycle life is only 299. That’s the only downside I see to this battery so far.
Rod911
Last seen: 10 months 1 week ago
pilotdog68 wrote:
I've been using 30B's for a while now, I'm glad they tested well.
Same, but the protected versions.  They were meant to be used for my lower amp draw (ie. less than 3A) lights.  It's nice to see they hold their own in the 5A area, even up against a high drain cell like the NCR18650PF.
logindetails
logindetails's picture
Last seen: 4 years 2 months ago
Yep – I’ve been using the button top unprotected version for a while and have been very happy with them especially as I can get them relatively cheaply (for the UK) locally at aprox $12 a pair including plastic storage box – and no waiting for the slow boat from China to arrive.
my9221
Last seen: 5 hours 29 min ago
HKJ, thanks for your lengthy review as well as the graphs. I hope you can review more protected rather than unprotected batteries!
HKJ
HKJ's picture
For comparison it is very nice to have both.
At the current time it will mostly be unprotected batteries, I just got a batch of them.
I guess the reason for the many unprotected reviews is e-cigs, many brands makes high current unprotected for that purpose and some of them send batteries to me for test/review.
