KronoReview: Eagle Eye X6R
254 posts / 0 new
Tom E
Tom E's picture
Last seen: 20 min 53 sec ago
Dang - brought in my new stock X6R to work today, and it's gone, sold! I threw in a battery and holster - I miss it already Frown. Now I have to order more.
You know - more I think bout it, the better your custom board looks - it would make it sooo much easier to mod this light, plus with the support for the 45/85 footprint. On your post #135, I think the math all looks good, though I'm not experienced at all in PC board layouts. Just hope you got in your X6R to verify my #'s - now I'm worried if you are posting/ordering from OSHPark based on just my #'s.
Let me know when you feel confident enough to order the boards, or maybe you did already...
pilotdog68
pilotdog68's picture
Last seen: 7 months 1 week ago
haha yep! we were going just off your numbers!
I’m actually going to use a different driver in mine (but still the same pin locations), though pyro ordered 2 or 3 days ago i think.
I did a quick check when I got my X6R, and everything was matching up with your numbers, so I’m not too worried.
edit: I just realized my through-hole for Pin3 isn’t in the optimal place, it’ll be very close to the USB connector, but with thin enough wire I think it should be fine.
pyro1son
pyro1son's picture
We’ll see how they go! Smile
Pastebin                                      &nbs
Tom E
Tom E's picture
K, just ordered qty 3. For $3.05, small price to pay for a little risk.
pyro1son
pyro1son's picture
Any updates? I’m still waiting for parts to turn up to get mine modded.
Pastebin                                      &nbs
pilotdog68
I think we’re all waiting for Oshpark. You should be the first to get your pcb’s since they upgraded your order
pyro1son
pyro1son's picture
Mine have been dispatched but I’m going to be waiting for other parts before I can get everything built and tested.
Pastebin                                      &nbs
Tom E
Tom E's picture
Yep - wait'n on the X6R and boards. X6R is close, should have it in next day or so.
pilotdog68
Cool.
When you do get your boards, could you just check to make sure the pins line up? That’s the only thing I’m somewhat worried about.
pyro1son
pyro1son's picture
Yeh sure.
Pastebin                                      &nbs
presterjohn
Last seen: 4 years 5 months ago
Such a shame they don’t have a UK distributer. The rechargeable lights that new staff are issued with at my place of work are double the price of those and have a quarter of the ability. I showed my BLF version to the boss and he was knocked out by the quality and price but the department that deals in purchasing are not set up to deal with the likes of Banggood etc. This model would have been a shoe in for replacing the rubbish we area currently lumbered with (and that I have never even bothered to request for myself).
pyro1son
pyro1son's picture
Good news chaps! My OSH Park boards have just turned up, sadly they have changed their packaging from the nice purple to a boring white with some purple circuitry.
But the best news of all is that the boards fit over the pins perfectly couldn’t have been any better!
Only thing to add is that the silk screen is unreadable, but we can work with out it.
Pastebin                                      &nbs
pilotdog68
Excellent. Pin spacing does look perfect.
As I feared, the pin 3 via is very close to the USB connector, which is ground. So you might need to use really small wire for pin3, or tape over it and run the wire up through the Led+ via or around the side.
Yeah I realized when I got the first of my boards that I was using too small of font. At least it’s visible in the pictures.
pyro1son
pyro1son's picture
Yeh, it’s great. I’m going to use 28AWG so i should be ok for pin 3.
I’ve stared at the images of this driver long enough to know where everything goes.
Pastebin                                      &nbs
Tom E
Tom E's picture
My boards just shipped out to me from OSHPark - should be a few days.
Rusty Joe
Rusty Joe's picture
Last seen: 4 days 17 hours ago
If only this version came in XP-L HI.
Tom E
Tom E's picture
Plan on using an XPL HI V3 2B on the one I'll build up with PD68's new board, using an 85. I just used the same XPL HI in BLF X6 that got 1500 lumens and ~70 kcd throw (529 meters) - nice tint too. Expected I'd get the same here - maybe a little less based on the piggyback setup because might loose a little more amps - I'll see.
 Want to add more features to the firmware since I got gobs of space now. Want to get some mode set choices in there, battery check, mode memory option, beacon, etc.
pyro1son
pyro1son's picture
Boards? – Check
Host? – Check
Firmware? – Check
Attiny 25? – Still waiting Sad
Pastebin                                      &nbs
Tom E
Tom E's picture
Just fyi... I'm working on enhancing my version of the e-switch/OFF time (e-switch and power switch support) firmware with configurable modes, a lock-out method, maybe couple more things. It will requires a 25/45/85. There will be 8 choices of mode sets, and mode memory ON/OFF, and option to go from lo->hi or hi->lo. So it's 32 combos all together.
pyro1son
pyro1son's picture
Very nice. I’ve just been working on getting the light to switch off when the charging cable is connected as you have to have the tail switch on for it to charge. I’ve used a version of STAR_momentary which had temp monitoring on Pin3 which I’ve set to turn the light off when it detects the charger. I’ve also added a Beacon mode just because I like them. Extra long hold to activate. Currently working on an Attiny13A but which many other features disabled, I plan on using an Attiny25 for this light, giving me the extra space.
Pastebin                                      &nbs
woolfam
Ordered mine 9 days ago using ahirshy’s code and paid for faster shipping. Came today. Very nice little light. If you get one, remember to turn it on with tail switch, and then off with electronic switch, BEFORE plugging in the charging cable.
pyro1son
pyro1son's picture
I’ve just made another order of boards with a slight tweek. Removed the 7135 chip and added batt indicator LED in its place.
I just feel that I should make it available and that all credit belongs to PD68
Pastebin                                      &nbs
pilotdog68
Looks good to me. I’m glad you had the foresight to put the LED on the bottom. I see your cam has tplace added to the silk. With my brd’s, you may find I have stuff on weird layers sometimes
pyro1son
pyro1son's picture
Yeh didn’t really notice. Oh well I’ve already ordered them well see how they turn out.
Pastebin                                      &nbs
Lazy-R-us
Last seen: 6 months 4 weeks ago
I’m looking around for a current link for this but can’t find any. The link in the review comes up 404 error, and Amazon claims “currently unavailable”. Searches on GearBest and BangGood yield no results. Was this a limited time offer?
Lazy-R-us
Lazy-R-us
Tom E
Tom E's picture
Look'n bad.... I ordered 3 of these from BangGood between July and Sep in 3 different orders, last one ordered Sep 4th, got it Sep 14th.
This is really, really sad if they stopped making/selling this light - almost perfect. Couple of friends bought them too. I really thought of it as an improved X6.
pyro1son
pyro1son's picture
God I hope they haven’s stopped I was after at least another 4 by the end of the month.
Pastebin                                      &nbs
Tom E
Tom E's picture
I just pm'ed Krono to see if he could contact Neal about this. I also pm'ed the "BangGood" BLF acct id - hope to find out somethig soon...
pyro1son
pyro1son's picture
Pastebin                                      &nbs
Tom E
Tom E's picture
Yes - http://www.aliexpress.com/store/product/Eagle-Eyes-X6R-CREE-XM-L2-U2-1000LM-USB-Rechargeable-LED-Flashlight-self-defense-camping-light/1735126_32301365158.html. This Ali store was mentioned earlier - best deal around on them. I paid $24 at BangGood with a discount....
Hhhmmm, maybe I better order 1-2 now. Ali store says 992 available but I can't believe that - they sell one's, two's at a time, and total of 11 orders in the last 6 months. They must be quoting stock from the source (factory - or distributor), and who knows if that's legit and current.
