Courui D01 Fitted with 86mm kaidomain reflector. (No lathe required, mostly off the shelf parts)
57 posts / 0 new
LinusHofmann
LinusHofmann's picture
Last seen: 3 years 4 months ago
I was posting some of this over in the general Courui D01 thread but thought I’d put up a new thread here with more of the details.
The idea was to pair up the Courui D01 with the very large and deep 86mm reflector from kaidomain.
Obviously there aren’t many cheap hosts out there that will house a reflector this large so something needed to be built/modded.
Option A: Own a lathe or have a talented machinist make something custom.
Option B: Try to extend an existing host using (preferably 100%) off the shelf parts and lego together the whole thing. Minimal manual work would be a bonus.
So this is my attempt at Option B. For a very successful build involving Option A have a look at Pinkpanda3310s TK61 mod thread .
Current Parts List: (may change as I work on the light)
  • Kaidomain 86mm x 84mm Reflector SMO Buy Here
  • Custom Copper pill courtesy of NikolaS (not essential, stock pill shelf will work but not ideal for high wattage emitters, sbt-70, mt-g2 etc)
  • 77mm Fotga wide angle lens hood (77mm male to 82mm female filter threads, 25mm height) Ebay various / Dealextreme
  • 82mm Fotga wide angle lens hood (82mm male to 86mm female filter threads, 25mm height) Ebay various
  • 86mm Fotga UV filter (any 86mm lens filter will do) Ebay
  • Custom Led centering ring made by Hoop Here
Reflector size comparisons. Kd 86mm vs Stock Courui D01
All the lens parts screw together with the 77mm hood snuggly sliding onto (but not threading into) the threaded lip on the head of the courui.
The stock bezel can be cut down and repurposed as a retaining ring to firmly mount this first hood from the inside or it can simply be epoxied into place.
Unfortunately the lip on the reflector is a little bit too wide (about 0.5-1mm all around) to fit into the 82-86mm lens hood. Basically you need to reduce the max OD of the reflector down to below 85mm.
This is the main part of the mod that will require some machining/filing/sanding.
I used a portable belt sander to bring this down to size but an hour or so with a hand file should also do the trick, I wish this wasn’t needed but for this particular plan it’s unavoidable. Just make sure to protect the reflector from dust by covering the openings during this step and it shouldn’t be too bad. I stuck a piece of plastic/acrylic over the opening of the reflector with double sided sticky tape to keep out the dust during sanding.
I’ll update this post with more details as I work on the light. Below is some random progress stuff from the Courui thread.
Update: 27/4/15
Did some work on the light today removing some material from the reflector to make it fit into the compact configuration (2x hoods + uv filter lens)
Here’s after the first assembly.
The reflector is a beast, though it doesn’t have the most perfectly smooth mirror finish. A very slight OP surface can be seen here.
I have yet to see how it performs in this config but this feature/flaw may make it a good option for an mt-g2 or similar just to help smooth over the honeycomb artefacts slightly. Just a thought, I’m sure it will also produce a very respectable beam with a normal die.
The UV filter and lens on the front: This is a really cheap UV filter but has what it claims is a multiband AR coating. Multiband? Hmm, probably not. But it definitely knocks down the reflections and the unusual green bias has the added benefit of counteracting the green tint shift seen from a dedomed cree led. So this may not be a bad option at all.
Still waiting on some parts to do a working assembly of the full light (led will be an sbt-70), but so far everything is lining up nicely. I like! Smile
Next to my original BigHead with UCLp lens.
Update: 01/5/15
A few more photos of the parts and assembly.
This is the diameter you’ll have to reduce the rim of the reflector down to in order for it to fit inside. It requires removing about 0.5mm all around so it’s not too bad. Again, some kind of a power sander is going to help a lot here.
50mm OD ~3mm Oring to allow the head of the light to be unscrewed a couple of millimeters and give enough clearance inside to fit a mcpcb and led in between pill and reflector. Not sure how much extra gap is required here until I get the led centering gasket and have a go at focusing up the reflector, the oring may not be needed or a thinner one could be used in it’s place. But in any case this is an decent approach to give extra clearance if needed.
This is how the bezel screws back onto the original thread, clamping the first hood into place. Depending on your particular courui and the machining tolerances, you may need to apply some electrical tape to make the hood/head interface a tight fit.
You’ll also see why the crenelations need to be removed from the bezel ring to allow the reflector to fit in the full assembly.
Edited by: LinusHofmann on 05/01/2015 - 10:17
ChibiM
ChibiM's picture
Last seen: 2 days 10 hours ago
Interesting !!
pilotdog68
pilotdog68's picture
Last seen: 3 weeks 3 days ago
It looks like it came that way! I’ll be very interested in your progress.
MRsDNF
MRsDNF's picture
Last seen: 4 months 5 days ago
That looks so much better than what I could come up with and would weigh a lot less as well. I love these types of builds. Looking forward to the beam shots. The problem I believe with Pp reflector was the lack of shine on the reflector itself, like a slight smokey finish to it instead of a highly polished finish.
LinusHofmann
Ah sure, but you’d be able to do a proper job with orings and everything. This type of build will only ever be splash proof at best without glueing everything permanently.
It is very nicely balanced with this setup, in stock form the courui was always a bit tail heavy, with the extension and heavy reflector it’s great!
Yes I remember you mentioning that about the reflector finish.
I’ve only see one of these and my particular sample is perfectly polished, but it does have a very slight OP patterning overall. It’s very slight but compared to the average D01 reflector it’s not quite producing as clear and crisp a reflection.
I’ve seen similar surfaces on other high end lights so I’m sure it won’t really affect the performance as much as strange matte look of the one you’re talking about.
Hopefully it’s a rare exception, cause I really like this beast and will surely make use of it in other lights going forward if this works out well.
AlexGT
AlexGT's picture
Last seen: 3 hours 14 min ago
Love your ingenuity! Beer I have been wanting to do that to another light, do you have a pic of the parts disassembled? Do you have a direct link to the ebay sellers you used for each of your parts?
Thanks! Can’t wait to see those beam shots!
LinusHofmann
Thanks.
I’ll take a pic of all the dissasembled parts when I’m working on the light next. Apart from the reflector OD alteration they really do lego together perfectly.
I’ve included ebay and sources for the parts that I can verify are going to be correct. I ordered the lens hoods a while ago so those listing are no longer there.
There’s loads of sources usually for these parts and they are standardized in terms of filter sizes and threads. I won’t guarantee that they will match 100% to what I have but I don’t think you can go too far wrong with something like these.
77mm Hood
82mm Hood
I can tell you that both of mine say “Fotga” on the inside and share the same matt anodizing finish on the outside. Those aren’t details things usually listed on ebay though.
I suspect all the cheapest hoods on ebay in these standard sizes are going to be from the same source but I could be wrong.
AlexGT
AlexGT's picture
This is what I was thinking to fit a bigger reflector to a smaller flashlight bezel, something similar to what you did
IIRC CPF member Download made a Stainless steel camera adaptor for the Mag a few years ago here is the link
http://www.candlepowerforums.com/vb/showthread.php?201610-55mm-Lens-SS-B...
LinusHofmann
Sure, if you combine filter adapters with hoods and filters they’re almost endlessly flexible. There’s also various hoods of different depths and types of flare. The fact that you usually have a known thread at the end of each part is very useful. Biggest problem is the vague ebay descriptions and of course the damn white writing that’s on most of the parts! Wink
cfy7
Last seen: 5 years 8 months ago
Great work, looks amazing. What would you say the total cost is without driver and led?
LinusHofmann
I think parts cost for everything (no led or driver) is under $100 including the copper pill.
johny723
Last seen: 1 week 6 days ago
how strong is this setup? I mean mechanical strength, durability, toughness, sturdiness, whatever you call it. It has a few new connections, a big reflector and the flashlight is quite heavy. How is the reflector secured and how is the 77mm hood attached to the flashlight? Can it survive a small fall or a hit?
BTW, what would be the throw with a dedomed xp-g2 running at 5 amps???
LinusHofmann
The first hood is going to be anchored by threading on the cut down bezel of the original light back onto it’s original thread. Thereby clamping the first hood firmly into place. That’s pretty bullet proof.
The rest and how it deals with a fall I wouldn’t like to say. The hoods are certainly very rigid/hard aluminium but still fairly thin. The reflector is going to be tightly held inside and pressed between the uv filter ring and the pill. I actually planned to use an o-ring in between the lens and the reflector rim but I don’t think I have the clearance spare now that it’s together.
The weakest part is probably the front lens element, it’s pretty thin glass held in a thin rigid metal ring. Any major impact there I suspect the glass is going to shatter.
In general it feels very sturdy in the hand and I’m confident it’s going to handle a few decent knocks. But I’m not going to do any drop tests on it Wink
No idea on the throw, I may test a few different emitters before I stick the sbt-70 in there.
cajampa
Last seen: 6 years 4 months ago
Yes please test some cree emitters for max throw in it, before you finalise it with the sbt-70, like DD a dedomed xp-g2 or a xm-l2 class emitter so we can know what kcd performance we can get with cheaper led’s.
I really like the look of it, and it was funny you mentioned that ugly white text on the converter rings, i had been searching ebay for similar part a while ago & all i found was these kind of filter adapters.
I don’t know camera equipment so i didn’t know about these plain black nice cheap lens hoods.
scottyhazzard
scottyhazzard's picture
Last seen: 3 years 5 months ago
I was pleased as punch to see these lens hood adapters all listed out until I started searching for them on eBay. Dude, vague descriptions is a super understatement. You wouldn’t happen to remember from which venders you purchased would you, Linus?
"Those who hammer their guns into plows will plow for those who do not."
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 11 months ago
Looks great. Can't wait to see beam shots.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
cajampa
Is these 86mm reflector the biggest out there for cheap or at all? Or is there something even larger hiding somewhere for reasonable money,
If we can find larger reflectors, this concept should be able to accommodate it with progressively larger lens hoods.
southland
southland's picture
My favorite flashlight modder strikes again, great as always.
FmC
FmC's picture
Last seen: 1 year 9 months ago
This looks very interesting….
I’ve modded several Courui’s for friends, & I’m sure some of them will want this treatment done to theirs when they see it.
I’m off to fleabay to get me some camera parts!
Beer Beer
- edit -
I managed to locate all of the camera parts, including a snap-on lens cover, from the same seller, for AU$22.75.
johny723
2 more questions:
1. The bezel has to be cut down- could you take a photo of what and how had to be cut?
2. The lens- is it possible to use some non- glass lens that does not shatter so easily? An acrylic lens or so should not be so fragile as a glass one right?
LinusHofmann
2 more questions:
The bezel of the courui has a single groove on the outside, you can use that as a guide for where I suggest cutting it to remove the front crenelations. A messy hacksaw job is fine as it will be hidden, just needs to leave a threaded retaining ring. A couple slots to help tighten it down will also be a good idea.
On the lens. Sure, you could try a number of other things. A second option I have been playing with is to stick a third hood stage on and use a 95mm filter step down ring to retain a matching piece of UCLp acrylic flashlight lens. That combination would be more sturdy (and doesn’t require machining the reflector OD) but it makes the light a bit bigger and longer than it needs to be. It also requires raising the emitter on a pedestal to make up the gap to the pill. Not ideal.
That’s without the filter ring adapter in place
The 2 hood setup is more elegant and compact so I’m going to try and make that work for myself. The tolerances are too tight to fit a thicker lens though, unless you extend the front with something slightly.
I look forward to seeing people come up with other cool approaches to this kind of thing.
johny723
how about using a custom cut AR UCLp lens from the flashightlens.com ? Cut to fit your flashlight. They say “ ALL ACRYLIC MATERIAL (IR, Acrylite, Hardcoat, and AR Acrylic) CAN BE CUSTOM CUT TO ANY SIZE OR SHAPE!! “ so it is worth a try! It would be tougher ( since this material does not shatter like glass) and you would not have to mount an extra hood to attach it.
LinusHofmann
Sure, just be aware that with the parts I listed…
LinusHofmann wrote:
The tolerances are too tight to fit a thicker lens, unless you extend the front with something slightly.
Clearance required by the reflector between the lens and the top of the pcb surface (provided you’re using the stock shelf or your custom pill matches the stock shelf in elevation, which mine does) is pretty tight already so a thicker lens and the required adapter ring may not work. I’m happy with the thin UV filter configuration personally so you’d have to try something else yourself and see what works.
Even with what I’m doing I’ll probably have to keep the head of the courui unscrewed a little (clamping a larger o-ring into the gap to keep things sealed and rigid) to give me the clearance needed to focus the reflector properly, it’s a tight fit! That has benefits in that it makes the whole package look really compact and like it’s intentionally designed that way. But also makes things a bit tricky as well. I won’t know if things really line up properly until I get the centering gaskets in place and have a go at focusing up the reflector.
You have to rely on a bit of luck sometimes with this kind of modding, and if that fails you need to have an alternative approach up your sleeve Smile
johny723
I did not know it was such a tiiiight fit… Good luck with that and keep us updated, I am sure this forum has enough ideas to help you make it work!
nofear87
Last seen: 1 year 3 weeks ago
Are there any beamshot of this build? Thank you!
LinusHofmann
Not yet, haven’t installed an led yet. Busy with other builds at the moment Smile
BTW, just update the OP with a link to the 77mm hood available from dealextreme. That’s the same part I have here, provided the photos are correct.
77mm Fotga Hood from Dealextreme
Unfortunately they don’t also have the 82mm hood but I’m sure we’ll be able to track down a reliable source for that one too. This is another option that looks about right.
Fotga 82mm from Amazon
cajampa
If you check out pinkpanda3310’s thread from the OP, you will find some beamshots of the same reflector + a very interesting kcd test Wink
LinusHofmann
A few more pics and details in the OP
johny723
I have an idea( maybe)
How about a custom copper pill by NikolaS that is machined so that the emitter and the star sit deeper? That should enable you to use 2 hoods and even a proper AR lens. The pills he sells are massive, a few millimeters that will be filed down should not cause problems with the heat transfer.
Is it a good idea???
LinusHofmann
johny723 wrote:
I have an idea( maybe) How about a custom copper pill by NikolaS that is machined so that the emitter and the star sit deeper? That should enable you to use 2 hoods and even a proper AR lens. The pills he sells are massive, a few millimeters that will be filed down should not cause problems with the heat transfer. Is it a good idea???
Sure, that would work as well. Though personally I think it would be nicer to have a design that works with a completely stock Courui pill/shelf. Would allow more people to carry out the mod and keep costs lower in general.
But really it’s up to the person doing the modding what preferences or specific requirements they may have, it’s also fun to try and figure out something different.
I haven’t tried it but you could probably find some way to sandwich an AR UCLp lens at the front between two filter rings, that would also give you some extra clearance. Like a step up and then a step down or something like that. May not look too great but it would work, even give the option of having an oring in there and some better sealing.
The options are fairly endless with something like this but until someone tries it and works out the kinks that’s all they are; Options Smile
johny723
A slightly taller 82mm hood is what we need then. The current is 25mm high, so we need at leas a 30mm one. This one is 36mm http://www.ebay.com/itm/82mm-Tele-Metal-Screw-in-Lens-Hood-For-Canon-Nik..., probably too tall, but I havent found anything better. Maybe, with 2 o-rings ( one betwen the reflector and the lens, another betwen the lens and the retaining ring), it can be made to work. This setup should work even with a bone stock pill. I will try something like this when I finally have some time and access to tools.
What I dont like the most is the ultra thin 0,5mm glass your current lens is made of. It is too fragile for a normal use.
