Test/Review of Samsung INR18650-32E 3200mAh (Cyan)
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 7 hours 9 min ago
DSC_9926
Official specifications:
  • Typical Capacity: 3,200mAh (0.2C, 2.50V discharge)
  • Minimum Capacity: 3,100mAh (0.2C, 2.50V discharge)
  • Charging Voltage: 4.2V
  • Nominal Voltage: 3.65V (0.2C discharge)
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current Standard charge: 960mA
  • Charging Time Standard charge: 5hours
  • Max. Charge Current: 3,200mA (not for cycle life)
  • Max. Discharge Current: 6,400mA (for continuous discharge), 9,600mA (not for continuous discharge)
  • Discharge Cut-off Voltage: 2.50V
  • Cycle life: 500 cycles to 70% with 3200mA discharge, 300 cycles with 6200mA discharge.
  • Cell Weight: 50g max
  • Cell Dimension: Height : 65.2mm max, Diameter(max.) : Ø 18.50 mm
  • Operating Temperature (Cell Surface Temperature): Charge : 0 to 45°C, Discharge : -20 to 60°C
  • Storage Temperature: 1 year : -20~25°C, 3 months : -20~45°C, 1 month : -20~60°C
Samsung%20INR18650-32E%203200mAh%20(Cyan)-info
Samsung is increasing the capacity and this time it is a 4.20V cell, not 4.30V or 4.35V cell. The cell is not for high current usage.
DSC_9925
DSC_9927 DSC_9928
DSC_9929
DSC_9930
Samsung%20INR18650-32E%203200mAh%20(Cyan)-Capacity
New quality cells, the two cells match nearly perfect. Capacity do vary slightly with load.
Samsung%20INR18650-32E%203200mAh%20(Cyan)-CapacityTimeHours
Samsung%20INR18650-32E%203200mAh%20(Cyan)-Energy
Samsung%20INR18650-32E%203200mAh%20(Cyan)-PowerLoadTime
Samsung%20INR18650-32E%203200mAh%20(Cyan)-TripCurrent
Samsung%20INR18650-32E%203200mAh%20(Cyan)-Charge
Conclusion
The cells are fairly good at keeping high output voltage, even when loaded.
Being Samsung they are very good cells.
Notes and links
Compare to 18650 and other batteries
HarleyQuin
HarleyQuin's picture
Thanks a lot for another great cell test!
As of today I count 243 tested cells in your 18500/18650/26650 comparator. This is awesome.
Err, you don't happen to have the Samsung INR18650-35E in your pipeline... This should be the direct successor to the 32E, supposedly the same chemistry. I saw the 35E pop up at a shop 2 days ago and am veeeeeeery curious...
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 17 hours ago
HKJ is awesome Smile Thanks.
HKJ
HKJ's picture
It is about 3½ years work.
Not directly, but I am going to test it.
atbglenn
atbglenn's picture
Last seen: 2 years 6 months ago
Love your reviews HKJ!
Boycott Nike
HarleyQuin
Wow.
But it’s really really helpful to tell a spade from a bloody shovel.
Too many dangerous cells out there.
Beer Thx
Oshpark Boards:
will34
will34's picture
Last seen: 1 hour 59 min ago
Thanks for the review, your work is amazing.
Halo...
Halo...'s picture
Last seen: 5 years 5 months ago
Thanks HKJ.
This cell looks very nice. Better than LG MH1 3200, Pana BD 3200 or any other 4.2 cell I’m seeing at normal amps.
Battery Man not...
Hi ,HKJ
Thanks for your test/review
The Samsung INR18650-32E seems the upgrade version of ICR18650-32A with 4.35V charging voltage.Or it come to compete with LG INR18650 MH1 3200mAh ?
Which is better of this two types .Any comparation for them?
18650 battery is the best
Halo...
Halo...'s picture
You can compare any two 18650s that HKJ has tested here http://lygte-info.dk/review/batteries2012/Common18650comparator.php He also has comparators for other sizes.
Battery Man not...
According to the comparation.It seems the INR18650-32E is little bit better than LG MH1.
