Q re charging protected batteries.
8 posts / 0 new
cpf
Last seen: 2 years 8 months ago
I was using Eneloops until now. Just moved up to Li-Ion. I just got :
Universal Smart Quick Charger - http://www.dealextreme.com/details.dx/sku.14885
and
TrustFire Protected 14500 3.7V 900mAh Rechargeable Lithium Batteries - http://www.dealextreme.com/details.dx/sku.26124 .
I started charging the 14500s when I had a doubt - protected batteries have a circuit that prevents over-voltage, any charger would have one too. Won't they sort of 'interfere' with each other ?
Say the battery stops charging at 4.1V while the charger normally stops at 4.2V - the charger will never "see" 4.2V, right ?
alfreddajero
alfreddajero's picture
Last seen: 2 years 3 days ago
The pcb will kick in stopping the charge, you can always put the cell back on the charger but trying to get to 4.2volts might cause the cell to miss terminate or the protection circuit might not kick in causing overcharging of the cell.  An ideal charge would be around the 4.15-4.18 range while the cell never reaches 4.2 the cell will have more longevity.  I have a couple of those cells and there nice, may not fill all the lights you have though because there longer then AA's.
With Darkness, there will always be Light.
alfreddajero
Heres a size comparison........
cpf
I was wondering whether the charger would never indicate "charge completed" ( the LED turns green it seems ).
Last night I started charging just before the England-Slovenia game, the LED had not changed color even after the Ghana-Germany game 7 hours later.
But the batteries were cool. That's when I thought maybe the charger will never indicate "charging stopped".
I wasn't trying to reach 4,2V. Just that I would never know when I can put off the charger.
Edit : The batteries just fit in my UF C3 SS single-mode.
alfreddajero
So you mean to say that when you put a battery in there the light comes but never turns off.......
cpf
The LED is supposed to turn green when fully charged. After 7 hours it was still red/orange, but the battery had cooled down. That's when I began wondering whether the protection in the battery was interferring with the charger.
fishinfool
fishinfool's picture
Last seen: 3 years 2 months ago
If you have a multi-meter you can always check just to make sure.  Better safe than sorry right?
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
alfreddajero
Nope it should'nt, all the circuit does is stop the flow of current when the voltage is reached for the cell, you might want to try another cell and see what it does, if it also does the same with that cell i would recommend you either take the cell out after a couple of hours and check the voltage with a dmm.......the cell should be at or around 4.17-4.18, remember anything voltage over 4.2 is harmful to the cell.
