Test/Review of 30W USB Desktop Charger
Official specifications:
  • 30W AC wall charger with 6 USB port
  • Power switch and LED power indicator
  • High efficiency and low energy consumption
  • Provides standard USB 5V and Max 6A Output
  • Compatible with all the electronic products that get recharged via USB cable, such as all the smartphone, iPhone5/5s/6, Samsung,Galaxy Note 4,Galaxy Edge, HTC, all the tablet PC, iPad,iPod, Power Banks, Rechargeable Bluetooth Speaker etc.
  • USB Port Number: 6
  • Input: AC 100-240V 50/60Hz
  • Output: DC 5V 6A
  • Plug: EU/US Plug
  • Size: 9.2x5x2.4cm (L*W*H)
  • Cable Length: 1.5 m
  • Color: White
I got this charger from ebay dealer: bg27cyf
I got this charger in a retail box.
Measurements
  • Standby power consumption 0.3W when on, 0W when off.
  • The output is two separate power supplies, left and right column are not connected.
  • Output first row is coded as Apple 1A
  • Output second row is coded as Samsung tablet
  • Output third row is coded as USB charger (DCP) and Samsung tablet
  • The led shows that power is present on the left channel, when overloaded the output will be turned off, but repeatedly the charger will try to turn it on again.
Doing a single port or a full column at a time gives the same result. The right outputs can deliver slight above 3A before they shuts down, this is good.
The left columns can deliver considerable more current before they shuts down, i.e. there are fairly large tolerance on the current limiters.
Trying to run the right column at 3A for an hour did not succeed, it closed down within 8 minutes.
Reducing the load to 2.5A worked better, but not perfect.
At 2A it did not have any problems.
Running the left column at 2.5A worked fine.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
2.5A on left column
M1: 56,2°C, M2: 53,0°C, HS1: 74,4°C
M1: 69,6°C, HS1: 74,5°C
M1: 43,2°C, HS1: 71,5°C
Here it is obvious that the heat is only for one side of the charger.
M1: 39,0°C, HS1: 56,5°C
2.5A on right column
M1: 50,7°C, HS1: 52,9°C
M1: 53,9°C, HS1: 82,5°C
M1: 51,7°C, M2: 51,9°C, HS1: 77,4°C
M1: 56,0°C, HS1: 74,1°C
2A on right column
M1: 46,3°C, HS1: 47,5°C
M1: 44,3°C, HS1: 69,2°C
M1: 48,9°C, HS1: 63,2°C
M1: 45,7°C, HS1: 59,2°C
With both channels and a 6A load the noise is 74mVrms and 750mVpp
Reducing the load to 2A reduces the rms noise 48mV rms and 700mVpp.
With 0.5A load the peak noise increases: 42mV rms and 1000mVpp
Tear down
When opened it is obvious that the charger has two separate channels. There are two mains switchers, two transformers and two low voltage circuit.
The input has a fuse.
Here the bridge rectifier can be seen.
The isolation distance between mains and low voltage side is about 1 mm and there is a non-safety capacitor across (Very bad).
The charger passed 2500 volt test, but failed a isolation test with 5000 volt, this makes it doubtful to use with 230VAC mains. When the test failed there was a short between mains and low volt side (Very bad)
Conclusion
The charger is rated for 3A+3A output on the bottom, this is a bit optimistic and also means that it can only charge two devices at full 2A current simultaneous (On in left and on in right column), the full 6A cannot be used.
The safety is bad, stay away from this one.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Another one bites the dust! Thanks for the review HKJ!
Way to many are dangerous and I only do a simple test, not anywhere near the full test suite a approved charger has to pass.
Thanks HKJ!
Please do reviews on Xiaomi (Mi) products :slight_smile:
Such as the Mi Power strip with 3 USB outlet
Ouch. This looks like a really bad one…Thanks for the review!
Please, include some links to where I can get it.
Banggood seems to have a decent price $17.59
Ibuygou $18.99
http://www.ibuygou.com/p-xiaomi-mi-smart-power-strip-plug-adapter-6690.html
Geekbuying $17.59
I have a Xiaomi Powerstrip on the way.
Break it open and put 5000V through it! J)
j/k
I think I’ll go as high as 220v tyvm :bigsmile:
I have ordered one and I will give it 5000 volt!
Awesome!!!
I do not use time on posting links everywhere to my reviews, but I love it when other people do
+1
Well done, as usual.
Thank you very much for your hard work.
Just a little update on the Xiaomi powestrip, only managed to charge a phone from the USB ports on it with 1A, the specs say 3.1A. Other than that it has very good construction and it is tiny.
Interesting, according Xiaomi…
Does your phone support Quick charging?
It looks nice. I thinking of buying one too, if it passes HKJ:s torture session :bigsmile:
I have received it and will get around to it when I am finished with the four multiport I am working on now. Publishing sequence will not necessary be in the same sequence as I test.
Yes, from original Samsung charger it draws 2.1A.
Maybe the port is not coded as Samsung and the phone demands correct code.
