Test/Review of Xtar WallAdapter 2.1A
Xtar WallAdapter 2.1A (model: FJ-SW1260502100UE)
Official specifications:
  • Input: 100V - 240V
  • Output: 5V 2100mA
I got this charger from Xtar.
It was in a cardboard box without much information on.
Measurements
  • Power when unloaded is 0.16 watt
  • Output is coded as Apple 2.1A
The adapter has a very stable output, the voltage is a bit on the high side, but this works very well together with the Xtar chargers.
The overload protection trips at a rather high current, I would have expected it at not more than 2.5A
There was no problem supplying 2.1A for 1 hour.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
M1: 46,4°C, M2: 43,8°C, HS1: 59,7°C
HS1 is the transformer.
M1: 56,4°C, M2: 45,1°C, M3: 44,4°C, HS1: 62,5°C
Here HS1 is the rectifer diode.
M1: 43,3°C, HS1: 56,2°C
M1: 39,2°C, M2: 38,8°C, HS1: 43,6°C
M1: 43,8°C, M2: 50,0°C, HS1: 52,0°C
There is very little noise at 1A load, 3mV rms and 45mVpp
Even at full load the noise is low at 5mV rms and 80mVpp
Tear down
Putting some pressure on the adapter with a vice made it easy to open.
I could put it together again after the photo session.
The adapter has a input fuse (resistor), a common mode coil (good), a large transistor with heatsink to handle the switching.
There is also opto feedback and a inductor on the output (That is probably one of the reasons for the very low noise).
105°C capacitors, a safety capacitor (I suppose) and the common mode coil.
The heatsink and the opto feedback can be seen here.
The blue tape around the transformer is used to improve isolation.
The rectifier diode is "hidden" here (D3).
The distance between mains and low volt side looks good.
Testing the mains input with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This adapter looks good, especially for use with Xtar chargers (due to the slightly high voltage). I would have liked a better overload protection, but everything else is fairly good.
Notes
The charger was supplied by XTAR for a review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Thanks for review, HKJ!
Looks well made, how the slightly higher voltage might affect charging, for example, tablets with it?
They might charge a bit faster, especially the last part of the charge, exactly like the Xtar chargers.
Any long term risks to damage batteries?
Not really, the actual charge is controlled by a chip in the device. The extra headroom allows it to work at full current for slightly more time.
Ok, thanks!
I wonder where I could buy this (specifically the EU version, like you reviewed)?
This time I believe I got the review copy, before they distributes the product to the dealers.
I.e. keep an eye on the usual Xtar dealers and it will probably be available soon.
Does this (or any of these) continue to draw power when plugged into the AC, even if there’s nothing connected on the USB side?
Yes, typically in the range of 0.25 watt. I do list it in all the usb charger reviews.
Really nice review HKJ as always. Your reviews are always very informative and interesting to read. :-)
