Test/Review of Sanyo UR18500F 1700mAh (Red)
Official specifications:
  • Nominal capacity: min 1620mAh
  • Nominal voltage: 3.7V
  • Charcing method: Constant current, constant voltage.
  • Charging voltage: 4.2V
  • Charging current: std. 1620mA
  • Charging time: 2.5 hours
  • Ambient temperature: Charge 0~+40°C, Discharge -20~+60°C, Storage: -20~+50°C
  • Weight (max): 33.5g
A xx500 cell, i.e. 1.5cm shorten than 18650 and much less capacity. This cell is not a high current cell and by todays standard not a high capacity one either.
The marking is added by the dealer, the actual Sanyo marking is present, but very difficult to see (As usual for Sanyo).
Very good match between the two cells and fairly constant capacity with load, at least up to 3A.
Conclusion
The cells is a good quality cell, but as is often the case with any other size than 18650 the chemistry is a few generations old and performance scales faster than size.
Notes and links
The battery was supplied by akkuteile.de for review.
Compare to 18650 and other batteries
