Test/Review of Shockli 18650 2400mAh (Cyan)
Official specifications:
  • Nominal capacity: 2400mAh
  • Nominal voltage: 3.7V
  • Discharge cut-off voltage: 2.75V
  • Standard charge: 4.2V 500mA
  • Maximum charge current: 2000mA
  • Continuous discharge current: 30A
  • Pulse discharge current: 35A
  • Initial impedance max.: 20mOhm
  • Cycle life: 500cycle to 60%
  • Operating temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~60°C
  • Storage temperature: -20°c -35°c
  • Weight: 45g
This is a new brand of batteries, this test is a high current 18650 cell with fairly high capacity.
The matching between the cells is not perfect and they cannot deliver 30A. They do hold their capacity, even at 20A load.
Conclusion
These cells are acceptable, but they do not live up to the 30A rating, they work better at 10A to 15A.
Notes and links
The battery was supplied by shockli.com for review.
Compare to 18650 and other batteries
HKJ
You’re the best tester ever. Thanks a lot!
PS But at $2.8 a piece it looks like an attractive deal (I paid more than 2x for the 18650PF’s)
Their 18350 are exceptionally good:
http://ukvapers.org/Thread-20A-18350
