<span class=“language english the in myself express to way correct the me suggest and phrase” “strange a wrote i where me point wanna you if corrections and suggestions accept I me. with compliant be please so error, grammar of lot a making surely am i english, in write to good so not am i”>
First impressions:
Shipped from: GearBest http://www.gearbest.com/led-flashlights/pp_71429.html
Special Price $25.99 with coupon UF-1405
The first time i saw it, i thought “well how big it is”. It is a really nice flashlight to handle , maybe just a little heavy for a constant use, but it is not an EDC so it’s normal that it’s not so easy to carry on.
The first think that catch the attention is the REALLY BIG aspherical optic, the biggest one found on a flashlight to date (this should be true…).
Rear switch works good on my unit, but I’ve heard some members complaining about the quality of the switch. I am FAR FROM BEING an expert, but for what i can see and test it, the switch does work like should do.
Modes and estimated lumens:
Switch type: MECHANICAL
There are “ 5 ” modes in the following order:
Hi – med – low – strobo - sos
My estimated lumens are 500/600. i expected more……the led is clearly underdriven, so nice mods could be done.
>>LIGHT >>> The angle of refraction:
Weight and dimensions measurements (made myself, not by specs):
This flashlight weighs precisely 524 gr
Height 22,3 cm
Diameter 3 cm
Head diameter 7 cm
Construction quality:
Mine unit arrived without any scratch or external defect. All threads are well made and the overall quality is very high. The good weight of this flashlight make me fink it is really strong and hard-wearing.
Lanyard hole: PRESENT (one)
Threads came PARTIALLY GREASED, but this is not a big con, i used my grease.(mine isn’t an high quality one, but you can buy a top notch if you prefer).
The part that needed grease is the thread of the focus mechanism , that previously was hard to spin.
Led Tint, reflector and lense:
The led tint is a cold white
Reflector made of(JOKE!): there is no reflector! This kind of flashlight does not need it, thanks to the special aspherical lense.
Lense made of : GLASS
Being a zoomable flashlight, you should expect nice performance on long range beamshoot. NATURALLY it is so and you can reach(when the aspherical glass lense is in the furthest point from led) long distances with a nice narrow beam.
No light artifacts in zoom in ,neither in zoom out mode
Outside beamshot at 25 meters, only at FULL power (same place for all my reviews)
Wall beamshot at 250 centimeters, from lower to higher power (same place for all my reviews)
Ceiling bounce test with LUXmeter:
PROS:
- good price (the gearbest price is the lowest i found on google search)
- biggest aspherical lense flashlight
- good construcion for what you pay for
- comfortable to hold, thanks to a “26650 made for” diameter body
CONS:
- slightly heavy
- underdriven led
Final thoughts and why you should buy it:
With a driver/led mod which would drain MORE current, this flashlight accepting two 26650 battery will surely offer a good amount of power to the led.
At stock state, it’s not a monster. But it is a nice piece of original flashlight for the nice price at which it’s sold.
I’ve never modded a flashlight, but this one is too much original and eye catching for not being modded, in a next future!!!
I think everyone should buy this flashlight……just to own the biggest aspherical lense flashlight, and try to mod it.
At the moment, however i like it for being a special item in my collection and for the nice actual zoom performance, even more promising to increase if you choose to do a led/driver modification.
Thanks for reading……
….and if you notice some bad written phrases, feel free to correct me suggesting the right way to write it!!
