P60 voltage
3 posts / 0 new
Surhoff88
Last seen: 6 years 2 months ago
P60 voltage
I thought I came across a sticky a while back that had the answer to this question, but now I can’t find the post so hopefully one of you can help me. I found my old sure fire 6PL in the back of my closet yesterday. Lost that thing years ago lol. I want to get a new xpl or xml drop in for it and get some rcr123s. The module it came with was the first gen p60led, rated at 80 lumens if I remember correctly, from back in 08 or 09. Does anyone know what voltages it will support? Like I said, I’m going to get a upgraded p60 for it, but it would be nice to be able to use this one still too. I was thinking about getting a host and giving the light to my son for his first decent light. Running a 17670 would give great runtime, but with an output of 80 lumens at 6v, a single 3.7v cell just won’t cut it for output. The two 16340s should give it a tad bit more but I don’t know if the first gen p60led drop ins can handle the 7.4 or only 6v. If anyone knows what the sure fire specs were I’d appreciate the info.
Edited by: Surhoff88 on 06/19/2015 - 20:36
Henk4U2
Henk4U2's picture
Last seen: 8 min 16 sec ago
What i’ve found: http://www.opticsplanet.com/surefire-p60l-led-conversion-assembly.html
The P60L assembly is made for the 6P and 9P models, meaning that it was designed to work on 6 volt and on 9 volt. So it can run on 2 or 3 123A lithium batteries. IMHO it’s safe to use 2 × 16340s (7.4 volts effective and 8.4 volts max).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Surhoff88
Thank you Henk4U2, that info is just what I needed. I forgot about the 9p model. Looks like it will be perfect for two 16340s.
On a side note, in six years (09-15) a p60 module went from 80 to 1000 lumens. That’s amazing :exmark:
