REVIEW: Courui D01 (XM-L2 , 3x18650)
13 posts / 0 new
realista
realista's picture
Last seen: 7 months 6 days ago
(i am not so good to write in english, i am surely making a lot of grammar error, so please be compliant with me. I accept suggestions and corrections if you wanna point me where i wrote a “strange phrase” and suggest me the correct way to express myself in the english language)
First impressions:
Shipped from: GearBest http://www.gearbest.com/led-flashlights/pp_85126.html
Special Price $29.99 with coupon GBCourui
The flashlight reflector is really big….and it is clearly made to “throw” the light!!
When i irdered it i thought it could have been bigger than it accually is, i expected a bigger host to contain 3×18650 batteries but the internal space is really optimized like described by pictures.
I appreciate the fact that i choosed the gray version instead of the black one, and the switch is not at the back but on the side, and it’s electronic kind.
Modes and estimated lumens:
Switch type: ELECTRONIC
There are “ 3 ” modes in the following order:
1) High – 2) low – off. 3) long press for strobo (hidden mode)
You need to press all modes (naturally except strobo….it’s hidden) to turn it off.
My estimated lumens are 1000
>>>LIGHT >>> The angle of refraction:
Weight and dimensions measurements (made myself, not by specs):
This flashlight weighs precisely 467 gr
Height 18 cm
Diameter 4,5 cm
Head diameter 7,6 cm
Construction quality:
It arrived in perfect condition, just a tiny scratch on the front crown, the lense and reflector was clear at 97% but i cleared all opening the front part and taking apart the lense and the reflector, i thought the 3% of “non smooth leflector” was a construction defect ( like generally it is) but i was wrong…. just a little speck!
I’t impressing how fine and precise is the quality of the host,it is stupendous and only macro pictures could explain it in the right way.
Lanyard hole: NOT PRESENT
Threads came NOT GREASED, but this is not a big con, i used my grease.(mine isn’t an high quality one, but you can buy a top notch if you prefer)
Led Tint, reflector and lense:
The led is well centered and its tint is warm white
Reflector made of: SMOOTHALUMINUM
Lense made of: GLASS
Outside beamshot at 25 meters, only at FULL power (same place for all my reviews)
Wall beamshot at 250 centimeters, from lower to higher power (same place for all my reviews)
Ceiling bounce test with LUXmeter:
PROS:
- a really good thrower
- proper price from gearbest (probably the lowest)
- to be a 3×18650 flashlight is “compact”
- host nicely machined
- side switch more comfortable than rear switch
CONS:
- impossibility to use flat top batteries (does not make contact without top button)
- i cannot find other problems, maybe i don’t have the necessary skills to find it disassembling the driver and led
Final thoughts and why you should buy it:
There are many “throwers” flashlights in the market but this one owns an actually wide diameter reflector which is capable of obtain excellent performances.
I am sure that in the future i’ll mod this flashlight ( at the moment i am not capable to do nothing…….) with some interesting new better performing leds, but even remaining at stock condition it’s a satisfyng chunk of flashlight, being 1000 lumens not so few if you figure them in a narrow beam!
Thanks for reading…..
….and if you notice some bad written phrases, feel free to correct me suggesting the right way to write it!! Smile
Edited by: realista on 04/26/2016 - 18:09
bibihang
bibihang's picture
Last seen: 14 hours 38 min ago
Nice review as well as the pictures, thanks!
You got a warm white LED in there?
Rusty Joe
Rusty Joe's picture
Last seen: 1 hour 27 min ago
Hi, Realista. Thanks so much for giving a review of the stock light (haven't seen a single one yet except for yours).
Wrathbringer27
Wrathbringer27's picture
Last seen: 16 hours 45 min ago
Nicely written review! Your english isnt too bad… Its good enough that we understand what you’re trying to tell us! Smile
Words can be broken,
so can bones.
Beachlogger
Last seen: 2 hours 10 min ago
Thanks for the review, shame that it can’t use laptop pulls Sad
Looks like a nice host for the modders
flashination
Last seen: 2 years 9 months ago
If it was just a few dollars cheaper I’d buy one. :_(
'I pledge not to get drawn into cpf/blf arguments, & just understand that both places have their own merits'.
awi89
Last seen: 2 years 7 months ago
Great review!
This is what i’ve been searching for long.
i wonder which one to buy between courui d01 and yezl y3(with xml2)… :~
nickelflipper
nickelflipper's picture
I use flat top Panasonic NCAR18650 (grey 2900mAh) laptop pulls in my Courui D01 with no problems. My measurements suggest the positive anode is approximately 0.15mm (6mils) above the protective vinyl washer. Also, include the fact that the spot welds are not completely flush after some touch filing to bring them down to size.
Kent
Rolz
Last seen: 9 hours 56 min ago
Nice review. I found your review interesting to read. Your English is very good. Thanks Smile
bibihang
bibihang's picture
Easy fix: Put a blob of solder on the flat surface and now it becomes “button top”. Wink
flashination
Wish came true!
“ Flash Sale Price $24.99 “:http://www.gearbest.com/led-flashlights/pp_101690.html?utm_source=Criteo...
The Miller
The Miller's picture
You know Realista this review i the reason I bought it
Nice light
realista
realista's picture
ehehehe i’m honored Wink
