Review request for HKJ [Chargers]
364 posts / 0 new
marty1
Last seen: 2 years 2 months ago
HKJ wrote:
Charger I will consider when my queue is smaller:
LiitoKala Lii-NL4  working on it
Dear HKJ,
I’m impressed by your battery charger reviews.
On Tue, 02/20/2018 – 07:22 you wrote that you were working on a review of the:
LiitoKala Lii-NL4
I am very curious if you have succeeded in testing it and what your findings are with the charger?
My personal experience is that NiMH batteries get rather hot to the touch in the last charging phase.
Keep up the great work.
Best of regards,
Marty
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 2 days ago
This is actually normal.
This is a property of NiMH cells that make them easy to end charge when full.
marty1
How hot, much degrees Centigrade may the batteries become? They get so hot that I almost can’t keep my hand on them for very long.
At what temperature will the NiMH batteries be harmed by heat?
BlueSwordM
40-45C, which means after some time, it does start to hurt if you touch them.
If they’re only hot for a short period of time, it should not be a problem.
60C is the threshold.
Mishanchik
Mishanchik's picture
Dear HKJ,
do you have in line to review the next charges: Xtar VC4S, MiBoxer Upgrade C4-12?
Blggg
Last seen: 1 week 1 day ago
Also the recently released VP4C.
HKJ
HKJ's picture
Last seen: 15 hours 14 min ago
Xtar has promised my some chargers for review, but I have not received anything yet.
Candil
Last seen: 3 days 11 hours ago
Hello HKJ is the Nitecore F4 charger in this years list of chargers to be reviewed? Thanks
HKJ
HKJ's picture
Not at the current time.
d_t_a
Last seen: 17 hours 54 min ago
Mishanchik wrote:
Dear HKJ,
Would like to see reviews of the above chargers, and also the new Liitokala Lii-500S… But I understand they will likely take some time..
HKJ
HKJ's picture
d_t_a wrote:
Mishanchik wrote:
Dear HKJ,
It will, but the VC4S is on the test stand at the current time.
contactcr
Last seen: 1 day 8 hours ago
Vapcell S4 plus on your radar?
d_t_a
+1 on this Vapcell S4 Plus charger (I’d think that Vapcell will be glad to send you one for testing since they’ve been sending you their batteries to test…), which looks like it has some promising specs:
- 4× 3A charging (similar to Miboxer C4-12 or SkyRC MC3000)
- discharge test at 1A (2 slots) or 0.5A (4 slots?) => this seems interesting since very few chargers can discharge at 1A (SkyRC MC3000 of course can discharge 4× 1A or 1× 2A), but other chargers that discharge at 1A may be discontinued (eg. Miboxer C2-4000); and the Opus BT-C3100 can also discharge at 1A but have a problem of heating up and “pausing” the discharging, which results in incorrect/too high capacity readout.
- internal resistance (would like to know how precise it is); we understand that most chargers might not be too accurate in DC IR test, but a ‘relatively consistent’ IR reading result would be good enough for most people.
Pete7874
Pete7874's picture
Last seen: 2 hours 18 min ago
+2
hank
hank's picture
Last seen: 2 days 2 hours ago
Here’s a teardown on the Apple USB charger. He praised its quality highly,
Quote:
Apple’s power adapter is clearly a high-quality power supply designed to produce carefully filtered power. Apple has obviously gone to extra effort to reduce EMI interference, probably to keep the charger from interfering with the touchscreen.16 When I opened the charger up, I expected to find a standard design, but I’ve compared the charger to the Samsung charger and several other high-quality industry designs,17 and Apple goes beyond these designs in several ways.
http://www.righto.com/2012/05/apple-iphone-charger-teardown-quality.html
Quote:
I was surprised to realize how enormous Apple’s profit margins must be on these chargers. These chargers sell for about $30 (if not counterfeit), but that must be almost all profit. Samsung sells a very similar cube charger for about $6-$10, which I also disassembled (and will write up details later). The Apple charger is higher quality and I estimate has about a dollar’s worth of additional components inside.14 But it sells for $20 more.
HKJ
HKJ's picture
Barkuti
Barkuti's picture
Last seen: 1 hour 59 min ago
https://www.aliexpress.com/item/33031980968.html
Hello! Henrik, would you mind sharing some preview of this charger's testing results? If possible, of course. I asked for its review a couple months ago.
Also, is the EAIEP 26F cells review coming soon? Big Smile
Thanks.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
HKJ
HKJ's picture
Barkuti wrote:
Hello! Henrik, would you mind sharing some preview of this charger’s testing results? If possible, of course. I asked for its review a couple months ago.
Thanks.
The charger is next in queue for my testing stations, this means I will probably start testing it in about a week and the test will take a week.
All the discharge curves are done for the battery, but I am missing the Ri curve and this will have to wait until I have some idle equipment .
Barkuti
Barkuti's picture
hank wrote:
Here's a teardown on the Apple USB charger. He praised its quality highly,
Quote:
I was surprised to realize how enormous Apple's profit margins must be on these chargers. These chargers sell for about $30 (if not counterfeit), but that must be almost all profit. Samsung sells a very similar cube charger for about $6-$10, which I also disassembled (and will write up details later). The Apple charger is higher quality and I estimate has about a dollar's worth of additional components inside.[14] But it sells for $20 more.
In my opinion, the role of apple is to create half-wit products for half-wit people who seemingly at will pay (too much) for them. A great piece of their very high profit margins get invested in preserving their abusive ways (intellectual property protection, devices often problematic to repair by 3rd parties, etc.), giving their products the exact amount of extra quality for half-wit people to continue thinking they are the best. In my opinion they're very far from this goal, though, and as Lightbringer likes to say what they really deserve is to be dragged into an alley and beaten  with sticks. Yes, I am biased. My money has no place in their pockets. Good luck to them.
samgalax
Last seen: 22 sec ago
@HJK
https://www.ikea.com/es/es/p/kvarts-cargador-pilas-80446667/
Do you have that charger in queue?
Looks good on paper
Any idea?
Thanks
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
HKJ
HKJ's picture
No.
hank
hank's picture
Hello, would you consider checking on some flashlights with built-in USB chargers, the ones that come with the socket and a little rubber cover?
Here are a couple, though a quick Ali search will find a lot more of them, mostly quite cheap:
https://www.aliexpress.com/item/33048502842.html?spm=2114.search0302.3.1...
https://www.aliexpress.com/item/4000300160230.html?spm=a2g0o.productlist...
I have an uneasy feeling about whatever dirt cheap little charging circuits are being used in such small spaces being reliable.
how crazy is this
Last seen: 1 day 6 hours ago
Barkuti wrote:
In my opinion, the role of apple is to create half-wit products for half-wit people who seemingly at will pay (too much) for them. A great piece of their very high profit margins get invested in preserving their abusive ways (intellectual property protection, devices often problematic to repair by 3rd parties, etc.), giving their products the exact amount of extra quality for half-wit people to continue thinking they are the best. In my opinion they’re very far from this goal, though, and as Lightbringer likes to say what they really deserve is to be dragged into an alley and beaten  with sticks. Yes, I am biased. My money has no place in their pockets. Good luck to them.
While I don’t see myself has a half-wit, I have bought many apple computers, I agree with most of the rest of your quote when it comes to apple today. I am a tight wad. When it came to buying macs they certainly did cost more but for my customers and myself were demonstrably significantly cheaper and more productive as deployed. Heck I’m writing this on a 7 year old laptop that still functions perfectly and preforms better than many brand new PC laptops. The first mac business systems I created competed only with mini (main-frame) System / 36 computers as the PCs of the day couldn’t come close to what I was able to do with a mac. People back then also said that they were over-priced toys for people who didn’t know better. That simply was not empirically true.
That said, Apple has completely removed computer from their name and have become the very representation of the evil big brother they set out to destroy. Shameful, immoral, and destructive company they have become.
how crazy is this
I would like to see the MiBoxer C4 V3 reviewed as I think there have been significant changes since the review you did.
I would also like to see some discussion of “smart” chargers vs selecting a charging current. (This may exist and I just haven’t found the thread.) I am noticing a fair difference between cells in charging time and much less “charge leakage” since I have been using that charger in “smart” mode. Some of the cells charge at what I thought was a good current and others take far more or far less current. Total charge will frequently require less mAh than what I was used to as I believe the “smart” charge matches the charging profile for a particular cell and therefore reduces waste heat while charging. Shouldn’t this be a good thing? Does it really matter? Am I just seeing things wrong?
Thanks,
Wade
HKJ
HKJ's picture
I am not really planning on them, I would expect they have a small charger chip build in and they usually do a good fairly job.
maukka
maukka's picture
Last seen: 6 months 6 days ago
Walter Sobchak
Last seen: 1 year 3 months ago
Dear HKJ,
Are you planning to review the BQ-CC63 from Panasonic (link below)? I’m interested in this charger because I want to switch from primaries to rechargeables at a school.
https://www.nkon.nl/de/charger-23/battery-charger/nimh/panasonic-eneloop...
Kind regards
Daniel
HKJ
HKJ's picture
Walter Sobchak wrote:
Dear HKJ,
I do not have it in my plans, but maybe it would be a good idea to include it.
whatsthepoint
whatsthepoint's picture
Last seen: 1 year 4 months ago
The Efest LUC 8 Double LCD Screen Fast Battery Charger
never underestimate the power of stupid people in large groups
angerdan
angerdan's picture
Last seen: 4 hours 44 min ago
