Review request for HKJ [Rechargeable Batteries]
807 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 5 days 4 hours ago
Hello!
Henrik, did you received the 3000mA 3-Mode LED Flashlight Driver Circuit Board I aforesaid nearly a month and half ago? Impressions?
Thanks and cheers Smile
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
HKJ
HKJ's picture
Last seen: 2 hours 7 min ago
Barkuti wrote:
Hello!
Yes, it arrived yesterday, but I have not looked at it yet.
Barkuti
Barkuti's picture
Hello! Any update with regards to the supposed PWM MOSFET switching driver? I'm really interested in knowing what PWM frequency it uses, hope it is very high, and some oscilloscope graph impressions. Smile
I am quite pleased with the way it works. There are a couple solderable track pair jumpers on the back, one of which comes soldered. I guess that has something to do with the driver modes.
Cheers
HKJ
HKJ's picture
Not yet.
Barkuti
Barkuti's picture
Today I used VISO Systems Flicker Tester application, calibrated with an incandescent bulb light source with a 100Hz reference value, to measure the flicker output of a torch I have with such driver. Gave me 10.13µs, which corresponds to 98716.68Hz, ≈98.7KHz … a bad result, pretty sure.
Waiting for confirmation, looks great
Cheers Smile
Originally posted on Mon, 08/20/2018 - 14:39. Edited for a fix.
Barkuti
Barkuti's picture
Hello! Smile
Don't wanna sound tiresome but, now that I'm sure my flicker tester measurements weren't right, could you please HKJ plug the FastTech's driver in an oscilloscope and measure its PWM frequency? Thanks.
Cheers
HKJ
HKJ's picture
Barkuti wrote:
Hello! Smile
Don’t wanna sound tiresome but, now that I’m sure my flicker tester measurements weren’t right, could you please HKJ plug the FastTech’s driver in an oscilloscope and measure its PWM frequency? Thanks.
It do not have any PWM, it is a linear driver.
Barkuti
Barkuti's picture
HKJ wrote:
Barkuti wrote:
Hello! Smile
I don't get it. Uses a very powerful AON7520 MOSFET plus what seems to be a current sense resistor in series with it and the emitter, right? If so, it must be using PWM to adjust output current. Either this, or am I missing something?
Cheers Party
HKJ
HKJ's picture
Barkuti wrote:
I don’t get it. Uses a very powerful AON7520 MOSFET plus what seems to be a current sense resistor in series with it and the emitter, right? If so, it must be using PWM to adjust output current. Either this, or am I missing something?
The mosfet is the linear regulator, a linear driver needs a current sensor, a pwm driver do not. I have written the review now, I do not know when I will publish it.
It was some work, because I had to locate my test fixtures for led drivers and modify my script to use my current test equipment (Everything has been replaced since I last did driver tests).
Barkuti
Barkuti's picture
As far as I understand, a MOSFET is a sort of high current solid state switch operated by driving its gate with voltage.
So that thing is a current adjustable linear design. This means unless you've found something wrong with it, far superior to the still predominant AMC7135 setups it must be.
Cheers Party
HKJ
HKJ's picture
It can work as a switch, but also as a linear regulator, you just have to use lower gate voltages.
There is also another issue, not all mosfets works well in linear mode (Nearly none do), this means they cannot handle full power, but only a fraction of their rated power.
Barkuti wrote:
This means unless you’ve found something wrong with it, far superior to the still predominant AMC7135 setups it must be.
I did not see anything wrong with it, except the mosfet gets rather hot at full power.
hIKARInoob
hIKARInoob's picture
Last seen: 6 days 23 hours ago
HKJ wrote:
hIKARInoob wrote:
Actually there’s a flash sale going on for the next 11 days at GearBest if it matters…:
18650 3000 mAh, 8 Euro: http://www.gearbest.com/batteries/pp_643012.html
26650 4500 mAh, 8.54 Euro: http://www.gearbest.com/batteries/pp_641267.html
That helped a bit on the price, I have ordered some.
I hope to get some batteries from Efest soon, that also means the 20700
Any update on the Imalent tests? http://budgetlightforum.com/comment/1140041#comment-1140041
Thanks.
HKJ
HKJ's picture
They are still waiting for time on my test stations.
With my current queue I will soon get to them, but if I get large collection of batteries from some of the usual suppliers, they will probably be discarded (They will get too old). There is no indication that I will get a large collection of batteries at the current time.
Barkuti
Barkuti's picture
Do you believe, HKJ, a proper high power linear driver could be implemented with a powerful high switching speed MOSFET used as a switch, plus a high power LC filter to smooth out the output? Sensing Vdrop at the coil would allow obtaining a reference voltage which, after the corresponding high/low comparison, would serve to dynamically adjust duty cycle to maintain constant current at the output for as long as high enough input voltage. I did not formally studied electronics, as you may guess, but the above sounds senseful to me.
Cheers Smile
HKJ
HKJ's picture
Cheers Smile
You will need a diode in the circuit and use a resistor for current sense, then you have a standard buck converter.
Agro
Agro's picture
Last seen: 21 sec ago
I would be interested in a test of Klarus 18GT-36UR.
This is a high-capacity 18700 with a built-in charger. What is special about it is that Klarus claims 10A discharge. So it should have lower IR than other batteries with built-in chargers…but does it really?
I don’t see any source for it yet.
HKJ, if you’re interested in testing it, I can write an update when I find it available.
HKJ
HKJ's picture
Please do, remember I am in EU, it limits where I can get LiIon batteries from.
Barkuti
Barkuti's picture
HKJ wrote:
… You will need a diode in the circuit and use a resistor for current sense, then you have a standard buck converter.
0K LoL, I really didn't wanted to reinvent the wheel. Big Smile
With regards to the AON7520 MOSFET linear driver, my guess is that the microcontroller uses the sense resistor voltage to determine the MOSFET's VGS, does it? You also say it runs hot, probably because I²R dissipated power. This means it will probably cook itself if output current is raised by lowering the sense resistor value, bad stuff. I wonder if making some sort simple copper heatsink, or buying one to attach it over the thing, would at least make enough difference for up to, let's say, 4.2 or 4.8A (2 or 3 pieces R050 stacked over the onboard R010).
Thanks a lot.
Cheers Party
HKJ
HKJ's picture
Barkuti wrote:
With regards to the AON7520 MOSFET linear driver, my guess is that the microcontroller uses the sense resistor voltage to determine the MOSFET’s VGS, does it?
More or less, you usual do not care about Vgs, but simple increase/decrease it until you have the correct voltage drop across the resistor for the desired current.
Barkuti wrote:
You also say it runs hot, probably because I²R dissipated power. This means it will probably cook itself if output current is raised by lowering the sense resistor value, bad stuff. I wonder if making some sort simple copper heatsink, or buying one to attach it over the thing, would at least make enough difference for up to, let’s say, 4.2 or 4.8A (2 or 3 pieces R050 stacked over the onboard R010).
Maybe, it will only be few watt, how much depends on the batteries.
I had the mosfet up to 165°C in less than a minute when I feed 4.2V into the circuit, but that was without any cooling (During test I had a fan on it).
Agro
Agro's picture
Nice that you’re interested.
I’m in EU too so this should not be a problem. Smile
MascaratumB
MascaratumB's picture
Last seen: 5 hours 49 min ago
Don’t now if these have been posted earlier or if you have them on your queue to be tested, HKJ:
Sofirn 16340 900mAh
https://www.gearbest.com/batteries-railway/pp_009458338007.html
HKJ
HKJ's picture
Sofirn 16340 900mAh
I have ordered them.
I have run out of small batteries to test (i.e. anything below 2800mAh) and are very open for suggestions.
MascaratumB
HKJ wrote:
Sofirn 16340 900mAh
Nice! I’ll be looking forward to your tests!
So far I have no other suggestions, but I’ll remember this if I see some ! Thumbs Up
Thanks for your work! Beer
Sillen
Sillen's picture
Last seen: 4 days 22 hours ago
Thanks.
Interested in Imalent results. These are supplied with RT35/RT70 kits. Rewrapped protected 30Q’s
LichtAn
Last seen: 8 months 3 weeks ago
Edit: guess I don’t get an answer because the Vapcells were mentioned before. Sorry, I retract my post then.
HydrAxx
HydrAxx's picture
Hi HKJ, I’m here, HydrAxx, I’m helping the vape community with lithium-ion batteries of all sizes and types of discharges, I’m testing and analyzing for myself, too. sometimes helps Mooch in terms of results, comparisons and technical documentation on different cells, I come to you to suggest the test of a cell, which I have serious doubts about the capabilities announced by the rewrapper, he This is a 20700 cell probably made by Howell, but which is not yet referenced and documented, its capacity is 3400mAh and its continuous discharge announced at 30A by Listman, in short, I give you two links: the first is the official page on the rewrapper Listman’s website and the second, a page of the FastTech site, where you can order this rewrap individually, by two or even by four.
http://www.listmanpower.com/proinfo.php?id=22&cid=18&sid=0
https://www.fasttech.com/products/1420/10015452/9629428
ps: I have already asked to perform the test of this cell to Mooch, unfortunately it is currently overloaded with work pending (many cells, chargers / dischargers / analyzers, various mods mechs, etc …) so it does not I do not really have a lot of time right now, knowing that I’m the only one to have her test this cell, personally I think if my fears are not based on Listman’s cell specs, it may that it is a good alternative to the Sanyo NCR2070C (20700 / 3500mAh / 30A), that’s hoping that you accept my suggestion.
Regards,
HydrAxx
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
HKJ
HKJ's picture
I have not answered because I had not decided yet. Sometimes it is difficult to decide and I just let them stand until I am missing cells to review, then I look back and may order something.
In your case I am missing lower capacity batteries to review and the 2800mAh fit that bill and I have ordered it.
I have also ordered this cell.
Agro
Agro's picture
I didn’t realize, but there are trustworthy sellers offering Sony US18650VC7 already. For example:
https://www.orbtronic.com/sony-vc7-18650-3500mah-li-ion-rechargeable-bat...
Would love to see the test…
HKJ
HKJ's picture
Agro wrote:
I didn’t realize, but there are trustworthy sellers offering Sony US18650VC7 already. For example: https://www.orbtronic.com/sony-vc7-18650-3500mah-li-ion-rechargeable-bat... Would love to see the test…
I would also love to test them, but I cannot buy from US (It is way to expensive in shipping).
ggf31416
Last seen: 11 hours 41 min ago
https://eu.nkon.nl/rechargeable/18650-size/sony-konion-us18650vc7-3500ma...
