Review request for HKJ [Rechargeable Batteries]
807 posts / 0 new
Agro
Agro's picture
Last seen: 2 min 56 sec ago
Folomov 18700 cell with a built-in powerbank?
https://www.gearbest.com/batteries-railway/pp_009708949923.html
I’m liking Folomov more and more. They need to switch to USB-PD instead of proprietary cables though.
Anyway, put it in DQG Tiny to have the smallest and lightest flashlight/powerbank out there.
Agro
Agro's picture
Fenix ARB-L16-700UP – Fenix’s second 16340 with a built-in charger, supposedly a higher-discharge one.
I don’t know any EU source for it, HKJ, if you’re interested, I can look.
HydrAxx
HydrAxx's picture
Hi HKJ, I would have another suggestion to make you on a cell of a format little standard, the “Zhiyun IMR 26500 3600mAh / 13.3Wh” or existing also in another version of rewrap the “EVO Gimbals IMR 26500 3600mAh / 13.3Wh “, I would be curious to know the continuous discharge capabilities knowing that the device that uses them (the Zhiyun Crane-M for example, a stabilizer) can fired up to 6 continuous amps. Here are some pictures and links to places where you can buy them.
Cells rewrapped by Zhiyun
Cells rewrapped by EVO Gimbals
Cells with their original wraps
Extract from the technical paper Zhiyun Crane-M regarding electrical consumption and battery used.
Buy Links:
https://www.ebay.com/itm/2pcs-26500-3600mAh-Li-ion-Batteries-for-Zhiyun-...
https://www.ebay.com/itm/NEW-EVO-IMR-26500-LI-ION-RECHARGEABLE-BATTERIES-FOR-RAGE-AND-RAGE-S-GIMBALS/263921986288?hash=item3d72f9eaf0%3Am%3AmjgKEkDg9WhCTX5fG2cchUA&var=563367862607
https://www.hobbygaga.com/fr-2pcs-3-7v-3600mah-26500-battery-for-zhiyun-...
https://www.proav.co.uk/zhiyun-crane-m-battery-set
https://www.marcotec-shop.com/en/zhiyun-26500-lithium-battery-for-crane-...
https://fr.aliexpress.com/item/ZHIYUN-Officielles-Batterie-Chargeur-pour...
Can a single flapping of a butterfly's wings trigger a tornado at the other end of the world?
Barkuti
Barkuti's picture
Last seen: 3 days 1 hour ago
HydrAxx wrote:
Hi HKJ, I would have another suggestion to make you on a cell of a format little standard, the "Zhiyun IMR 26500 3600mAh / 13.3Wh" or existing also in another version of rewrap the "EVO Gimbals IMR 26500 3600mAh / 13.3Wh ", I would be curious to know the continuous discharge capabilities knowing that the device that uses them (the Zhiyun Crane-M for example, a stabilizer) can fired up to 6 continuous amps. Here are some pictures and links to places where you can buy them.
I do not mean to sound too judgmental, but the price of these Zhiyun cells is offensive, outrageous. Totally looks like whoever has designed such device is just trying to milk the cows. Seems like the previous version of the Zhiyun used standard 18650 cells, they could have gone any other industry standard format this time, like 26650. This totally smells like I said above. If it were me, I would say some kind Flat Stare words to that people in that regard.
Cheers Smile
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
HydrAxx
HydrAxx's picture
Cheers Smile
All depends on the site where you buy them because I only gave links for purchase as an example, it is not the best prices of the net that I chose specifically, for example look at this one: https://www.hobbygaga.com/en-2pcs-3-7v-3600mah-26500-battery-for-zhiyun-... , the price of 2 batteries 26500 3600mAh is 12.89 € ie 16 $ This is not very expensive for two cells in this category.
Agro
Agro's picture
According to https://18650.uk
Vapcell 21700 4000 mAh is Sony US21700VTC6A
And Vapcell 21700 3960 mAh is Samsung INR21700-40T.
HKJ do you happen to have them in the queue?
HKJ
HKJ's picture
Last seen: 2 days 18 hours ago
I prefer to test the cell marked with the Sony/Samsung name.
Sorry about not saying yes/no to the other suggestions, but I am a bit slow to decide what cells to buy.
Agro
Agro's picture
That’s OK. Smile
maukka
maukka's picture
Last seen: 2 months 4 weeks ago
Lithium Ceramic Batteries from ProLogium
Agro
Agro's picture
It appears that Klarus has added the same cell to their catalogue now:
http://www.klaruslight.com/index.php?m=content&c=index&a=show&catid=156&...
Again, I don’t know where to buy it yet.
It’s interesting that they claim to use a Panasonic cell inside.
I don’t see any 16*** cell on the Panasonic site…
Barkuti
Barkuti's picture
The following are only a few suggestions, first two LiFePO4 cells for which I'd like to se how accurate are their ratings (33A continuous and up to 1800mAh in 18650 cells is interesting):
https://eu.nkon.nl/rechargeable/18650-size/heter-enerpower-18650-lifepo4-1100mah.html
https://eu.nkon.nl/rechargeable/18650-size/heter-18650-1800mah-5-4a.html
Finally the much acclaimed Samsung 20S, theoretically tested before in a Vapcell wraphttps://eu.nkon.nl/rechargeable/18650-size/samsung-inr18650-20s-2000mah-30a.html
Various other interesting cells in nkon's lineup.
Cheers Party
Barkuti
Barkuti's picture
Hello? Davie
I remember having suggested the Samsung ICR18650-32A in the past here (#384) and there (#465), guess it was forgotten and/or something went wrong… Question
How about the above LiFePO4 cells? Heter is a quality cell manufacturer, but I have seen next to no reviews of its cells.
Cheers Party
HKJ
HKJ's picture
Good question with the 32A, I have tested them long time ago, but did not publish it when I found out it was at the wrong voltage (4.2V charge, they are only about 2700mAh at the voltage).
I have some cheap LiFePO4 in queue and I may also look at your last suggestion, but 20S is not in stock.
Barkuti
Barkuti's picture
Barkuti
Barkuti's picture
Mmm, none of those EAIEP offerings look appealing?
We can be glad we can buy lots of first OEM batteries in their original industrial wraps, which is because brave retailers manage to get and market them. However, due to the li-ion battery OEM to consumer sales reluctance/reticence I do not see an easy way to buy non-first OEM (LG, Murata, Panasonic, Samsung) cells except with a non-OEM wrap.
China is still a bit of an isolated land with certain good OEMs and products. Since the unit price of these cells is super affordable they could be top candidates for a large battery pack, of course for as long as their performance and consistency are decent at the very least. The aforementioned ukrainians were building e-bicycle battery packs with them.
Cheers Party
HKJ
HKJ's picture
I have ordered two of them.
Barkuti
Barkuti's picture
Thanks!
May we know which ones? A little birdie told me the wide triple leg pink wrapped “26F” cells come from BAK. I may delve in a more detailed identification if I can find some chinese indigenous lad willing to cooperate.
Cheers Party
HKJ
HKJ's picture
EAIEP 18650 2500mah INR18650-25R discharge lithium batteries electronic cigarette Battery 18650 2500 25R
EAIEP New Original INR18650-33E 3300mAh Li-lon Battery 18650 3.7V Power Rechargeable batteries Max 30A discharge
Agro
Agro's picture
HKJ wrote:
Agro wrote:
HKJ, if you’re interested in testing it, I can write an update when I find it available.
Please do, remember I am in EU, it limits where I can get LiIon batteries from.
Finally sources for Klarus 18GT-36UR start showing up.
Pricey beast. :/
https://www.ecologeek4u.com/catalogue/lampes-klarus/batterie-klarus-18gt...
https://www.ledsupermall.com/klarus-18gt-36ur-3600mah-3-6v-micro-usb-cha...
Barkuti
Barkuti's picture
HKJ wrote:
EAIEP 18650 2500mah INR18650-25R …
EAIEP … INR18650-33E 3300mAh …
LoL thanks. I'd have likely chosen the same models. Both 33E and VTC7 seem to use the same cell underneath and I wonder if they could be rewrapped LG MJ1 cells. With respect to the penta-leg top 25Rs, no  idea.
Pricey beast. :/
https://www.ecologeek4u.com/catalogue/lampes-klarus/batterie-klarus-18gt-36ur-18650-3600.html
https://www.ledsupermall.com/klarus-18gt-36ur-3600mah-3-6v-micro-usb-charging-high-discharge-18650-li-ion-battery.html
That cell is likely to use one of the top OEM available high capacity cells, maybe an LG M36.
Steep pricing. I'd look for alternatives.
Cheers Party
Agro
Agro's picture
LoL thanks. I’d have likely chosen the same models. Both 33E and VTC7 seem to use the same cell underneath and I wonder if they could be rewrapped LG MJ1 cells. With respect to the penta-leg top 25Rs, no  idea.
Pricey beast. :/
That is a steep price. I’d look for alternatives.
Cheers Party
I believe there are no alternatives of equivalent quality.
It seems that most of usb-rechargeable 18700 cells use 18650B or similar cells, low discharge and OK capacity.
Klarus has used 18650GA in their cells before in their “3600” cells and I expect that’s what’s inside this one; better at both discharge and capacity than others. Though yes, it may come with a M36 or something similar.
Aside from a better cell this might have a lower-resistance protection circuit as well.
Andrew_Debbie
Last seen: 1 month 1 week ago
If they aren’t already in the test queue, would you please test the Liitokala 21700 4000mAh 5C discharge
from Aliexpress store 133859 (Edit: Reality is bent*. I have no idea what is real anymore)
https://www.aliexpress.com/item/Liitokala-21700-li-lon-battery-4000-mAh-...
You can get them at the 11/11 sale price.
*bent
1.
sharply curved or having an angle.
“a piece of bent wire”
synonyms: twisted, crooked, warped, contorted, deformed, misshapen, out of shape, irregular
2.
INFORMAL•BRITISH
dishonest; corrupt.
Barkuti
Barkuti's picture
Andrew_Debbie wrote:
… please test the Liitokala 21700 4000mAh 5C discharge
From the real Liitokala Aliexpress store 133859
https://www.aliexpress.com/item/Liitokala-21700-li-lon-battery-4000-mAh-3-7V-15A-discharge-rate-power-5C-ternary-car/32848013569.html
As real as any other AliExpress seller.
Lishen LS21700SA OEM cell, true 3C rating. Already reviewed in their yellow Lii-40A wrap.
Cheers Party
Andrew_Debbie
I agree. It is hopeless. There are too many Liitokala stores and websites to know what is what. I edited my post.
Liitokala’s website at http://www.liitokala.com.cn links store 217753. < sigh >
217753 has the yellow 21700s and the black and gold 26650s.
Store No.217753
shenzhen, Guangdong, China
http://www.liitokala.com.cn/Contact.asp
LiitoKala Power Co.,LTD(DongGuan battery factory)
Add: No.38 Changsheng Road, Tiantangwei, Fenggang Town, Dongguan City, Guangdong,523690,China
website: www.liitokala.com.cn
Contact: ZhangNi
TEL: +86 13760394452
Email and Skype : liitokala@126.com
Office hours: (HK Time) Mon – Sat: 9:00am – 22:00pm
The “other” LiitoKala website at http://liito-kala.com/ links store 133859 < big sigh >
This one has the pink 21700s that might also show up in red or blue. They also sell the blue 26650s
Add: 6th Floor,Ling wu industral Road 8 D,Shenzhen Guanlan Junzhibu,Guangdong province,518110,China
Tel: +86-13417331508
Email:emily@liito-kala.com
Office hours: (HK Time) Mon – Fri : 9:00am – 6:00pm
Purchase link:
https://liitokala.aliexpress.com
Barkuti
Barkuti's picture
Just found this fairly priced sale for Panasonic NCR18650BM cells: https://www.192led.com/product/2pcs-3-7v-3200mah-10a-18650-li-ion-rechargeable-battery/
Couldn't find any meaningful review besides this video:
SKV89 mentioned this cell back in January
Maybe a high quality cell for small electric vehicles.
Cheers Smile
HydrAxx
HydrAxx's picture
Couldn’t find any meaningful review besides this video:
Cheers Smile
The cells that you propose have the same specifications as this model: https://eu.nkon.nl/rechargeable/18650-size/panasonic-ncr18650bd-3200mah-...
What are the differences between these two cell models (both from Panasonic)?
Barkuti
Barkuti's picture
https://eu.nkon.nl/rechargeable/18650-size/panasonic-ncr18650bd-3200mah-10a.html
¯\_(ツ)_/¯
There's the “BD” and the “BE”, and now this “BM”. All I can say is the capacity figures that guy in the video gets, even if at 0.25A discharge rate, are rather beefy.
I miss some formal Panasonic cell reviews.
Cheers
HydrAxx
HydrAxx's picture
¯\_(ツ)_/¯
There’s the “BD” and the “BE”, and now this “BM”. All I can say is the capacity figures that guy in the video gets, even if at 0.25A discharge rate, are rather beefy.
Cheers
You forget the BF and BL too, lol, it’s really unclear their name, it seems to me that the BE and BL are 7-amp cells, the BF meanwhile gives 4.9 amps it seems to me?
Pajda cz
Last seen: 10 hours 46 min ago
My informations about Panasonic cells:
BE – 1. generation of Tesla Model S 85 cells with carbon anode (unconfirmed)
BM – 2. generation of Tesla Model S 85 cells with C-SiO anode (parameters confirmed by direct comparison with Tesla 85 cells (MY2016) and many cycle life tests in my lab)
BD – is BE or BM technlogy based cell without bottom vent (unconfirmed)
BF and BL cells are based on other technology, I think BF and BL both are C-SiO anode succesors produced by Sanyo of an old Panasonic NCR18650B. (unconfirmed)
HydrAxx
HydrAxx's picture
BM – 2. generation of Tesla Model S 85 cells with C-SiO anode (parameters confirmed by direct comparsion by Tesla 85 cells (MY2016) and many cycle life tests in my lab)
Do you have information about NCR18650PD, NCR18650PE and NCR18650PF?
