This pill is made from true copper, that has more than 380 W·m−1·K−1 thermal conductivity, and weighs 43 grams.
“It has slightly pink color (camera can not show it`s real color). Low-cost chinise pills are often made from brass/bronze (they also has high density, so pill can be heavy, but will not have much red in it`s color) or different colored alloys (they look like real copper but weights much less).”
Please be patient as they are coming from Russia to me, then I will send out individually
If i remember things right (i don’t have one yet but me & the 600+ other BLFers will quite soon ;), the needed spacer for the A6 triple is the size of 20mm noctigons & one 16mm one. At least that is how i plan to make one, but i would be nice if there was such an copper spacer available.
To save a bunch of time sanding & soldering those together for a nice & quick drop in for the A6-SE, just order a spacer & a triple noctigon with the leds you want for a very quick upgrade.
I only know one who have tested it & he wrote about it in the A6-SE thread + i also discussed it with Dale in the same thread.
And as far as i remember that was the conclusion, if you don’t have a custom spacer you will have to make one in the size of one 16mm+3 20mm noctigons in height, for the triple 20mm noctigon to match up with the carclo.
