Accucel 6 80W and Charge Master
Hello everyone,
I would like to know if some of you been able to use chargemaster correctly with the accucel 6 80W.
The charging setting aren’t good,
For examples, when i set NiMH battery in charge master, it set the accucel to LiHv mode when set to Nicd in charge master it set NiMH in accucel etc…
Is there a way to modify the firmware to fix it or is there any turnaround i can do?
Thank you
Edit : Is this what i need to be able to balance charge battery with this charger? : http://www.ebay.ca/itm/silicone-6S-JST-XH-Adapters-for-5-Cell-Pack-7-PIN-wire-New-/181713380732?pt=LH_DefaultDomain_0&hash=item2a4ef6257c
Here is the link for the working version of charge master : http://www.skyrc.com/index.php?route=product/product/download&download_id=140
What is a charge master?
Your link is garbage.
Not garbage at all. The linkis to download the chargemaster software to use with the charger
I thought it was a devlce. I have an Accucell and I’ve never heard of it.
Looks like it is for dT6755 SkyRC charger. Might not work with yours.
