The X5 is eating up battery power. Just played a little with it yesterday, set the thermal settings and today, I tested the thermal setting, and noticed that the lights was less brighter then yesterday from the start. Pulled the battery, and it was down to 3.3V
And that’s a protected Keeppower 840mAh. So it’s not using the full power of the light.
So not much runtime with the X5.
Not tested the X6 yet, but there I have 30Q, HG2, MJ1, GA batteries I can use.
The X5 is eating up battery power. Just played a little with it yesterday, set the thermal settings and today, I tested the thermal setting, and noticed that the lights was less brighter then yesterday from the start. Pulled the battery, and it was down to 3.3V And that's a protected Keeppower 840mAh. So it's not using the full power of the light. So not much runtime with the X5. Not tested the X6 yet, but there I have 30Q, HG2, MJ1, GA batteries I can use.
My Keepowers are protected 800mAh - maybe 3 years old but with little use. I can't run turbo without tripping the protection. Yours must have a better circuit. Even so, you wouldn't expect "full power" on a protected cell. With such little capacity in a 14500 and this awesome driver, eating batteries will be inevitable in the higher modes.
Yep, the full sized FET driver on a small 700mAh cell gobbles it right up. (non protected high discharge cells in the 14500 class are ~650mAh)
When you are able to pull 5000mA (5 Amps), a 650mAh cell is being slammed!
But it sure is nice to have big flashlight output in a palm sized little beastie that fits in a pocket easily.
So, now imagine going up to 11.5A on that little cell with a Quad. :bigsmile: I stepped outside night before last to go to the shop for a quick mod (put a tail clicky in a SupFire M6 for lockout) and was wearing my Nitecore HC50 Headlamp. The dog was acting like there was something he wanted to go after and the headlamp wasn’t showing me the far end of the yard (200’ deep) So I pulled out my little Cu X5 Quad and BAM! lit up the whole backyard ( I wear the Quad X5 in a horizontal open top Kydex holster on my belt, have had it with me ever since it came).
Bunny rabbit, stupid Yellow Lab was all excited about a lil ol bunny rabbit! As you might can imagine, that little Efest Purple 14500 isn’t going to do 3000 lumens for long, but it sure is nice to have it if/when you need it! And of course, this is what 7 levels is all about, battery level control.
My lights come in today so I’m leaving work early to meet them at the door!!
John 12:46 “I have come into the world as a light, so that no one who believes in me should stay in darkness.” Genesis 1:3
And God said, “Let there be light,” and there was light.
Got my Al set today and they look pretty nice. I’ll have to get some better cells to push these lights to their max potential. The only issue I have is with a cracked lens on my X5. It’s only towards the edge, but I wonder if it will become a bigger issue, especially if it’s ever dropped. You can see the cracks extending past the edge of the reflector or O-ring, not sure which it is, as I don’t want to open it up and risk the cracks getting worse.
One of my Al X5 was doing the same or similar to yours. It corrected itself after doing a tear down, clean and lube job. Not sure of the cause, but happy it worked. There was some shavings around threads and loose around the internal components, but that is an observation, not a causal factor.
Definitely a hardware issue. It's getting the wrong voltage levels on its sensor, so it thinks you're always at a critical low-voltage level. As with many driver issues, you might be able to fix it by touching up the driver's solder joints. Maybe there's a resistor shorted or something, likely R1 or R2. But you might also have to ask Neal for a replacement driver. It's also possible that some other connection is barely touching, somewhere on the power connection path. You might want to take apart the tailcap and put it back together, loosen and tighten the driver retaining ring, maybe clean the threads and end of the tube if it's an aluminum model. Possibly swap the switches between the two lights to see if the issue follows the switch. Sometimes spurious low voltage can be caused by a faulty connection from the battery to the driver. I had a faulty switch do that once.
Thanks TK. Did a tear down, clean and lube. Everything tightened up nicely. Tailcaps switched and no change. I will contemplate getting a solder iron to investigate/troubleshoot more. Your suggestions are greatly appreciated.
Outer packaging was beat and ripped open, but the foam and cardboard box were OK. Inside, the wooden box and lights looked fine. They shifted inside some but could not find any blems.
I have matching serials # 69 (hurr hurr…)
They work great. Love the UI! Tint is not as warm as I would prefer but I wouldn’t call it cool. It’s truly neutral. Not bad at all.
I just wanted to say Thanks to all the members at BLF Krono, Bugsy, PilotDog, TK and on and on, just another wonderful project and certainly a HUGE success, Thank You Everyone Involved in this project..!!
Edit: Just got through setting up UI and this light is just spectacular #6 fixed some issues I was personally having, so edited out my stupid comments, sorry..
I love the voltage check, extremely easy to understand, I wasn’t prepared for the 9/10Ths blink and thought I’d broke something, try to count that, it’s fast for me,
Also nice touch with the 1/8th or so back off on the switch to turn off pilotdogs lighted tail cap, fantastic.
Edit: Delete..
I have actually realized that I do have favorite lights based on the switch action,
Thanks everyone who worked so hard, this is one beautiful light.
Edit: Just finished with programing X5&X6 and *“TK” you did not miss a thing, some of my issues previously mentioned above (deleted) are resolved at many levels, I thought I’d read this UI instructions many times but apparently I really wasn’t getting it until now with light in hand, UI is just Fantastic, Thanks..!*
I made this post longer than usual because I lack the time to make it shorter.
That is what I call dedication!
My wife would call it something different
I know exactly what you mean! Although, I must say my wife was very impressed with these new lights and that is quite an accomplishment considering her feelings towards what she calls my “new obsession”.
Okay I left work early only to get home 30 minutes too late I missed my lights by 30 minutes. Now I’m hunting down our mail lady, she is suppose to meet me at the post office at 3:00 to give me my lights hopefully!
Aint’ that the way of it! If you’re a bit behind, they’re early. If you’re early, they’re hours late. I’ve even watched tracking and knew the package was on the truck for delivery, was walking down to the mailbox when a sub drove up, stuffed a notice in the box, and drove away. He was 200 yds down the road at the next mailbox and I was out in the street trying to flag him down. Bass*** drove away with my stuff! I called the Post Office and talked to the manager and threw a tissy fit. lol
That “Sorry we missed you” stuff, when they don’t even try, really gets me riled. lol
Also had a $400 Titanium light coming with signature required labeling. Happened to be standing outside talking to a neighbor when I saw the mail carrier coming down the road…another sub stuck that expensive package in the big rural mailbox 300 yds down the lane and drove off while I watched. I honestly don’t know where they find these guys….
I am still impatiently waiting for my set, pacing, checking the box, checking the tracking… but I admit I am already very grateful as well. I feel pretty lucky. And it is not going unnoticed how the organizers are still working and troubleshooting, every day, through the individual issues members are experiencing with their new lights, teaching and offering corrective solutions, fielding all questions. When the time comes, I expect my hand might need a little holding as well, and their attentiveness to this project has eliminated all concern. Assuming the organizers don’t feel too beat up by the randomness beyond their control, all will be well. This has thus far been an amazing journey, literally an illuminating adventure.
Thank you, organizers… and Keep up the good work! We’re all counting on you!!
jk on that last part, I really hope there is no pressure felt from our ranks. We’re just not worth it. Don’t sweat the small stuff, and its all small stuff.
I received mine yesterday and WOW. Even the family agreed that they were nice lights. Thanks again guys and gal. Orsm team effort. I cant thank you all enough.
djozz quotes, "it came with chinese lettering that is chinese to me".
118/400 checking in finally!! WOOOOWWWW!!! These lights are amazing hands down the best looking lights I have and the brightest! Thank you to everyone who had anything to do with these masterpieces! Now waiting for the night to fall! And as a side note there is nothing wrong with my lights at all, BEAUTIFUL!
Funny you say that. My wife didn’t get too excited about them. She said they were very pretty but too heavy. Then again she doesn’t get too excited about any of my lights. My kids, on the other hand, won’t leave them alone. Between all the shiny metal and the neat lighted tailcaps, they’ve quickly become favorites. Little rugrats weren’t supposed to get these lights for another 50ish years but they’re trying to claim them early. I guess I shoulda ordered a couple extra sets
PS: Thanks to ToyKeeper for the muggle mode. Its definitely getting used at my house.
I’m out of state on a installation and yesterday evening my (2) SS/Cu w numbered box’s came in. I lost one of my SS/Cu w Box set to my wife! She owns a few Sinner, Over Ready,Vinh 54, PFlexPro, Surefire, and a few of my special Custom and Modded lights and upon her inspection exclaimed, “These are some bad azz light’s!!” I’ll have #50 thanks hun! Need I say more? I guess I get SS/Cu w Box set #139? Both set’s by her critical inspection are perfect! Zero Flaws! She is charging up the 14500’s I got from RMM as we speak! And here I am 2-3 weeks before I go home for a weekend off? :_( Thanks “Team KRONOS” outstanding job!!!
Kenneth Myhre
It's a little gem of a light!
It can be that it run on full turbo, have to wait to get some IMR cells on their way before I know for sure.
Kenneth Myhre
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
Andy? Do not look into the light! I know you will, but don’t say you weren’t warned…
KuoH
gadabout,
true flashaholic!
Received my first (boxed) SS/Cu set.
Outer packaging was beat and ripped open, but the foam and cardboard box were OK. Inside, the wooden box and lights looked fine. They shifted inside some but could not find any blems.I have matching serials # 69 (hurr hurr…)
Thanks again to all that made this happen!
I like copper
Edit: Delete..
Good luck! 3:00 draws nigh…
Can you recommend a holster for these lights? Links if you got them.
yeah DB, got a pic of that kydex holster? make it yourself or buy it?
Here are mine with standard rubber grommets for ease of grip.
Life’s Questions/Answers here: http://www.answersingenesis.org/home/area/qa.asp “So then, each of us will give an account of himself to God.” Romans 14:12
Where did you get those great grommets?
I got them originally from Alliance Express but that company has since changed to Essentra:
http://us.essentracomponents.com/
I don’t know about part numbers since they have probably changed too.
A5
I am in triple set al cu ss
www.flashmylight.com
Counting down for my numbered set…
Expected Delivery Day: Thursday, February 4, 2016
one year rookie
KB1428 “Live Life WOT”
I have programmed mine to have mode memory…. is there a way to keep this after the tail has been unscrewed or locked out?
Light reverts to moon mode first and no memory when the tailcap is locked out and then re-engaged
That’s weird, it shouldn’t. Locking out the tailcap doesn’t do anything different than simply pressing the switch.
My Favorite Modded Lights: X6R, S8 , X2R , M6, SP03
Major Projects: Illuminated Tailcap, TripleDown/TripleStack Driver
