- The Fake-Cree LED Awareness Thread - The new "low" in Budget lights.
1015 posts / 0 new
CEHepp
CEHepp's picture
Last seen: 7 months 4 weeks ago
Check out this weird LED I found on the tool truck last week:
Click the second picture for full resolution.
Zebralight S6330 – Zebralight SC600w – Zebralight SC52 – Zebralight SC51w – EagleTac D25A Ti 219 – 4Sevens Quark Turbo AA2 219 – FourSevens Preon PenLight -
DBSAR
DBSAR's picture
Last seen: 2 days 7 hours ago
Looks like another variant of a copy of an XP-E emitter.
mrjoda
Last seen: 3 years 6 months ago
Hi all,
I bought cheap “GENUINE XHP70” led lamp from aliexpress (as starting point to my own project with XHP70). Here are pictures. Is this genuine led ? i don’t think so. Is it bright ? yes. Is it good ? I don’t know Big Smile
Wieselflinkpro
Wieselflinkpro's picture
It es neighter an XHP70 Nor an XHP70.2.
It is no known Cree-LED.
DBSAR
DBSAR's picture
Definitely not a XHP70 (or 50) in any way. must be some kind of new knock-off, or just a odd-ball un-branded LED. The dies size look close to that of a CREE MC-E emitter, but its not one of those either.
mrjoda
i recieved genuine XHP70.2 XHP70B-00-0000-0D0BN40E5 from farnell. By comparing these two there are few major differences :
1) light emittors are up to 3 times bigger than chinese
2) “dome” (i don’t know exact name) is not that clear as is on chinese copy
3) you can not see supply traces on support pcb
4) there is one dot and one rectangle instead one dot
5) there are almost invisible spaces between emittors. Chinese has huge gaps.
dchomak
Last seen: 3 years 3 months ago
I am posting this question here because I didn’t want to create a separate thread just for this question. This emitter is from a genuine CREE spotlight, and I can’t find any information on it. My first impulse was to call it a CXA1603, but I can’t find any information on that emitter.
BTW, I once read somewhere a couple of years ago that CREE was planning on using non-CREE emitters is some of their light bulbs to keep cost down. So i suppose it is possible that this is a “fake” CREE emitter in a genuine CREE light Sick
Does anyone know what this is????
DBSAR
DBSAR's picture
Looks like a Cree CMA series LED, similar to this: > https://ca.mouser.com/ProductDetail/Cree-Inc/CMA1840-0000-000N0H0A30G?qs...
dchomak
DBSAR, thanks I had never heard of the CMA series
http://www.cree.com/led-components/cma
But this one doesn’t match up with any of those.
Diameter of the COB is 14mm while the metal substrate is 18mm. Measured voltage while running is 67.8V
Also they are calling this a high CRI light.
It would be interesting to see how far one of these can be pushed. As it is driven now it is rated at 850 lumen.
DBSAR
DBSAR's picture
Maybe it was a special version/model of the CMA series they make for only use in their LED light bulbs running on the 120 volts line-voltage, (with a voltage reduction circuit) and not available as a separate component? difficult to know in that case.
dchomak
Well after searching and searching I have concluded that this emitter is not made by CREE but rather made for CREE using their patents. I suspect that CREE licensed the technology and outsourced the manufacturing to an outfit in CHINA.
Bet THAT’S never happened before, right? Wink
Here is the UPC code and statement Made in China and Manufactured for Cree, Inc.
If that is true, then is this a “fake” Cree emitter?
I don’t think so, its could just be called a Cree emitter made by someone else Smile
DBSAR
DBSAR's picture
Definitely looks like it! Silly
dchomak
This is an example of the first Cree light bulbs that I know of. This first iteration, like other brands, had heavy ribbed heat sinks at the base for long life (23.8 years) LOL
Later on Cree came out with the cheaper to make “4Flow” bulbs that were vented but had no sink
These older bulbs were actually made by Cree, the newer “4Flow” were made for Cree
welight
welight's picture
Last seen: 1 week 1 day ago
1603 is a date code I assume week 3 of 2016, does not have Cree logo so not cree
Cutter Electronics Pty Ltd
Web: https://www.cutter.com.au
snakebite
snakebite's picture
Last seen: 1 week 2 days ago
hi cri?
maybe oem by yuji or whoever their oem is?
DBSAR
DBSAR's picture
That could be possible.
vidramon
What do you think ?
LINK of the light on Aliexpress.
DBSAR
DBSAR's picture
These do look like another variant of either latticebright or other fake/clone of XM-L2 LEDs.
vidramon
Thinking the same…
This is genuine Cree led.
This is unknown.
As far as I can see the Cree is a little bigger and there is no this little square in the dome, also grey area around the dome on Cree is like OP reflector, and on unknown is like SMO.
If it is Lattice bright than can be XM2 or XF2
DBSAR
DBSAR's picture
The fakes all seem to have a smaller die, and most have square bond wire pads where genuine Cree LEDs have round pads.
vidramon
This is maybe a better picture it is from Convoy S2+.
You think this 2 wires that are touching the LED ?
DBSAR
DBSAR's picture
The 2 bond wires on the side of the LED die is the most notable indication for most of the fake ones, the real Cree ones have the round pads like the pic above.
vidramon
Yep, understand.
Does anyone here find a way how to determine differences from genuine Cree led series like XM-L2 ?
U2, U3 and U4 for example how to know what is about or it is not possible ?
DBSAR
DBSAR's picture
vidramon wrote:
Yep, understand.
i’m not sure how to tell that part of the LED designation.
JFeldschau
Update! I figured out how to post.
Real or fake cree?!
https://s1036.photobucket.com/user/JFeldschau/media/C8E09A86-759A-4CAF-B...
I have a picture I would like to post, but for goodness sakes I can’t figure out how to add a picture. I’m in my late 30’s, not ancient lol. Can anyone help? I don’t have a “url” to post a picture. Why can’t I simply copy and paste?! Lol
Tom E
Tom E's picture
Last seen: 2 hours 24 min ago
I'm 61 and have posted 100's, maybe 1000's of pics here, of course I've been programming computers for like 40+ years smile
I use "Advanced Post Editor", then click on the top most "Insert", choose Insert/Edit Image. Then in the Source field, you need to enter a URL directly to a picture. Here's one to use as an example:
 https://oi1054.photobucket.com/albums/s496/TomE2012/Custom%20Mods/P1030101_zpsac2bbr10.jpg
In the inserted image, it will look like this:
I reduced the size from 1024x768 to 300x225 in the "Dimension" entry. The tricky part is to find a hosting service/server that you can get url links from. I use PhotoBucket in a paid for mode though. Lot of people here use imgur.com, but I find it somewhat hard to use.
JFeldschau
Tom E
Tom E's picture
Could be an XTE, check here for the ultimate LED ref: http://budgetlightforum.com/node/26665
DBSAR
DBSAR's picture
Real or fake cree?!
I am unsure what those are, they look like a cross between a XTE Cree and the odd-ball LEDs found in some Skyray King clones i seen, as most of the cheaper random-branded lights have been using the knock-off Latticebright ( and now other random unknown LEDs, its difficult to tell when it comes to buying unknown brand lights.
JFeldschau
Ok. Your meaning Cree XTE? It does look like the picture in that thread. I’m about to buy 60 of these and I just want to make sure they are the real deal. So it can be a Cree and not say Cree?
