Another Cheap DIY Powerbank
When I bought it the price was $1.71, they’ve raised it to $2.45 by now.
It has a nice aluminium casing with screw on cap. Plastic sleeve with electronics and slot for battery inserted into it (image from review on GB):
IC has no markings on it.
Charging cut off: 4.21v
Discharging cut off: 3.03v
At about 3.2v the blue led will start flashing.
Power bank wont start charging if battery voltage is under 3.4v
Based on amp draw from USB it uses CC/CV charging, draining 0.7A/4.6V at the start and 0.05A near the cutoff.
How are the threads on the body and cap?
I would say they are reasonable for the price. They are quite thin and feel somewhat rough, but do the job.
How is it holding up?
This is an 18650 battery right? What’s the real capacity? I doubt it holds 3500mah.
I am a newbie when it comes to power banks - can the cheap ones be charged and discharged at the same time?
