Test/Review of Vapcell IMR18350 700mAh (Purple)
Official specifications:
  • Product: Vacell 18350 700mAh
  • Model: IMR 18350
  • Size: 18.1*34.6mm
  • Nominal voltage: 3.6V
  • Charge voltage: 4.2V
  • Typical Capacity: 700mAh (0.2C discharge)
  • Min capacity: 650mAh (0.2C discharge)
  • top:Flat top/button top
  • color: purple
  • weight: 25g max
  • Standard Charge: 0.5A, 4.20 ± 0.05 V, CCCV 50mA cut-off
  • Continuous maximum charge current: 2A
  • discharge cut-off voltage: 2.5v
  • Continuous maximum discharge current: 10.5A
  • Max Discharging Current: 15A
  • Operating environment: Charging, 0°C ~ 40°C, Discharging, -20°C~55°C
  • Storage environment: -20°C~55°C, storage >3 months: -20°C~45°C
The low capacity 18350 from Vapcell, the do also have a 900mAh version.
I got two different cells, one is flat top, the other is button top, this usual means a small difference at high currents (Button top usual has a slightly bit more resistance).
This does not look good, they do not track, they have both different capacity and resistance and that difference is not due to button/flat top.
One of the cells can handle 10A, the other can only handle 5A and only with difficulties.
Conclusion
The A cell has fairly acceptable performance, but with this much variation between the two cells I will call this cell a bad choice.
Notes and links
The batteries was supplied by Vapcell for review.
I did not mix the 700 and 900 cells, both 900 cells has above 900mAh, there is more about them later.
Note from VapCell: All our 18350 batteries are out of production. Please ignore the specification.
Comparison to other LiIon batteries
Thanks for this review. I'm about to have more 18350 flashlights, so I''m in for a good cell. I hope Vappower gets this sorted because it looks like they generally make some good batteries.
Hi djozz
i am glad see you are interested in 18350 batteries. maybe you can look windyfire 18350 battery .you can see the HKJ rewiew .
Where did you read Vappower? Vappower has a different line of IMR18350, Im undecided between theirs 18350 https://www.fasttech.com/product/1932600
which are green as all their line
and the AWT which has already been tested by HKJ, the AWT has also a flat top, which i tend to avoid where is possible
