DIY diving light
7 posts / 0 new
xkertx
Last seen: 6 years 1 month ago
DIY diving light
Hello,
I am building a diving light to my friend.
We are using a Underwater Kinetics C8 for host
It has to be a 1-mode spotlight, no flood.
Dont know about batteries yet, maybe 4×18650?
What do you suggest for LEDs? I was thinking about 3x XM-L2 U2, or maybe a single xhp50?
What reflector do you recommend to get maximum throw (the lense/glass diameter is 60mm)?
And what about the driver? We want to drive the LEDs to max. So I was searching for a 6-9A drivers with only on/off modes, but no luck.
Edited by: xkertx on 08/18/2015 - 14:59
itsonlyme
Last seen: 6 months 5 days ago
Throw won’t really work underwater will it?
For the driver, what about the LD-2?
http://budgetlightforum.com/node/39824
arek98
Last seen: 2 days 15 hours ago
I think XHP50 is to big to give you good spot.
XM-L2 or something similar size (maybe XP-L HI or bigger XHP35 HI) will be better.
This is regular incandescent version, it is all plastic, right?
I don’t think you will be able to run LED in it at 20W+ power.
Note that eLED version of this light has heat sink going from LED thru lens to water.
I may be wrong but I would check with one how hard you can push a led in this host before going to far with project.
djozz
djozz's picture
Last seen: 3 hours 7 min ago
I agree, drive a led hard in that and it may overheat inside.
Btw, welcome to BLF!
will34
will34's picture
Last seen: 4 hours 22 min ago
Many years ago I tried to mod a Princetontec mini wave II diving light with 4× 26650 and a single cree MC-E, with a couple of laptop heatsink style copper pipes going through the head as heatsink. Failed miserably because I couldn’t secure the LED on the pipes. Copper mcpcb didn’t exist at that time so there wasn’t a way to secure it by solder.
If I were to do the same mod today I would use an XHP-50, 2S2P batteries config, and a heatsink like this that goes through the head. Copper pipes can be cut and re-soldered.
bikedude
bikedude's picture
Last seen: 11 months 2 weeks ago
These aren’t mere copper pipes, they’re heatpipes
Cutting them open will release the working fluid, usually water. The inside of the heatpipe is at low pressure, once you open it the water will immediately boil/vaporize.
Why didn’t you try thermal glue or just screwing the MCE down?
power911
power911's picture
Last seen: 1 week 6 days ago
for drivers
how about these?
since you only need one mode so a regulator would do.
plus you can adjust voltage on this
some even allow you to adjust amps so a small cpu heatsink would work if you have it balanced.
just search for dc-dc converter
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
