Test/Review of 5V 1.2A Microsoft Japan 1621
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 12 hours ago
DSC_0766
Official specifications:
  • Input: 100-240VAC 50/60Hz
  • Output: 5V 1.2A
  • American standard two flat plug us plug universal
  • UL listed E132068, this is LiteOn AC adapters.
I got it from aliexpress with the help of a reader.
DSC_0763
The charger arrived in a plastic bag inside the envelope.
DSC_0765
The bag included the charger and a usb cable.
DSC_0768 DSC_0769
DSC_0767 DSC_0770
Measurements
  • Power consumption when unloaded is 0.033 watt
  • Output is coded as USB charger (DCP)
5V%201.2A%20Microsoft%20Japan%20load%20sweep
5V%201.2A%20Microsoft%20Japan%20120VAC%20load%20sweep
I measured the charger on both 120VAC and 230VAC, at 120VAC the efficiency is slightly better.
The overload protection trips at 1.4A, this is a good value for a 1.2A charger.
5V%201.2A%20Microsoft%20Japan%20load%20test
The charger has no problem running for one hour with full load.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp2197
M1: 44,5°C, M2: 41,2°C, HS1: 51,7°C
HS1 is the transformer.
Temp2198
M1: 44,1°C, M2: 41,1°C, HS1: 57,1°C
Here HS1 is the mains switcher IC.
Temp2199
M1: 40,4°C, M1: 50,4°C, HS1: 52,4°C
Again HS1 is the mains switcher IC. The rectifier diode can also be seen (M2).
Temp2200
M1: 39,2°C, M2: 50,3°C, HS1: 62,7°C
Here HS1 is the transformer.
10ohm
There is not much noise at 0,5A with 7.5mV rms and 80mVpp.
5ohm
The noise increases slightly with load 10mV rms and 100mVpp.
4ohm
Even at full load the noise is very low: 11mV rms and 100mVpp.
Tear down
DSC_0983
I could not open this with my vice, instead I cut it open.
DSC_0984
The input fuse is a fusible resistor, just beside the resistor is a inductror. There is also a safety capacitor with a high ohmic resistor accross it.
The copper tape on the transformer is probably used to reduce noise.
DSC_0986
The transformer has a piece of plastic that goes beside the usb connector. This piece of plastic is used to move the low voltage output from the transformer away from everything mains connected and over to the usb connector.
DSC_0987 DSC_0989
Between the two mains input the fusible resistor can be seen together with some specifications: 5.1ohm, 1Ws.
DSC_0988
Here the safety capacitor and the resistor between mains and low voltage side can be seen.
The resistor is about 90Mohm.
DSC_0985
On the bottom of the circuit board is the mains bridge rectifier, a mains switcher IC (With 7 pins). On the low volt side is the rectifier diode.
DSC_0990
The plastic shield that is mounted on the circuit board is a important part of the safety.
DSC_0992 DSC_0991
As long as the plastic shield is mounted the safety distance is 6mm, but when it is removed the distance accross the gab is much less.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
This power supply looks to be real Microsoft and not a copy/clone. It has good safety, very low noise and overload protection.
This looks to be a good 1.2A charger.
Notes
This charger was supplied by a reader.
I have changed my power meter from the Gossen Energy to a mains powered one, it is faster and more precise.
Read more about how I test USB power supplies/charger
joevik
Last seen: 2 weeks 4 days ago
Thanks for the review!
