Test/Review of Vapcell IMR18650 2200mAh (Yellow)
Official specifications:
  • Product: Vapcell 18650 2200mAh
  • Model: IMR 18650
  • Size: 18.3*65.0mm
  • Nominal voltage: 3.6V
  • Charge voltage: 4.2V
  • Max. charge voltage: 4.25V
  • Typical Capacity: 2200mAh (0.2C discharge)
  • Min capacity: 2150mAh (0.2C discharge)
  • top: Flat top
  • color: yellow
  • weight: 48g max
  • Internal Resistance: <20mOhm
  • Standard Charge: 1A, 4.20 ± 0.05 V, CCCV 100mA cut-off
  • Continuous maximum charge current: 4A
  • discharge cut-off voltage: 2.5v
  • Continuous maximum discharge current: 40A
  • Maximum pulse discharge current: 60A
  • Operating environment: Charging, 0°C ~ 45°C, Discharging, -20°C~75°C
  • Storage environment: -30°C~55°C, storage >3 months: -20°C~45°C
A low capacity cell with very high current rating.
There is some capacity difference between the cell, one of them has the rated capacity, the other more.
Conclusion
I do not like the difference between the cells. It is interesting to compare this cell to the Vapcell 2600mAh that is rated for 30A continues, that cell has the same or higher voltage and more capacity.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
Good morning Henrik.
Is it the same battery ?
You mean the 2200 & 2600? I doubt it, but due to the wide tolerances on them it is difficult to see.
From the picture and trace of discharge , however , resembles that of LG HE2 / 4.
I’m right ;
