Test/Review of 6-Ports 30W USB charger
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 2 hours ago
DSC_0727
Official specifications:
  • 30W USB Power Adapter
  • Input: 110 - 240V 0.8A 50 - 60Hz
  • Output: DC 5V 6A
  • Cable length: 130cm
  • Color: White
I got it from Gearbest sku:130812702
DSC_0724 DSC_0725
I got this charger in a cardboard box.
DSC_0726
The box included the charger and nothing else.
DSC_0728 DSC_0731
DSC_0729
DSC_0730
Measurements
  • Power consumption when unloaded 0.16 watt
  • All outputs are in parallel.
  • USB output #1 and #2 coded as Apple 1A
  • USB output #3 coded as Samsung
  • USB output #4 USB charger (DCP)
  • USB output #5 and #6 coded as Apple 2.1A
6-Ports%2030W%20USB%20charger%20%231%20load%20sweep
6-Ports%2030W%20USB%20charger%20%236%20load%20sweep
Output is fairly stable at any current drain and there is no individual over load protecion.
6-Ports%2030W%20USB%20charger%20load%20sweep
The charger has a protection at 7A, that is a good value for a 6A charger.
6-Ports%2030W%20USB%20charger%20load%20test
The charger could run one hour at 6A load, but as can be seen below it got very hot.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp2181
M1: 52,4°C, M2: 49,9°C, M3: 78,1°C, M4: 52,7°C, HS1: 114,6°C
HS1 is the rectifier diode.
Temp2182
M1: 51,3°C, M2: 62,3°C, M3: 45,7°C, HS1: 69,2°C
Temp2183
M1: 49,1°C, M2: 74,1°C, HS1: 86,0°C
Temp2184
M1: 75,5°C, M2: 42,8°C, HS1: 104,9°C
HS1 is again the rectifier diode.
10ohm
The rms noise is very low, but there are some spikes in it: 17mV rms and 700mVpp
2.5ohm
Again it is the spikes: 30mV rms and 970mVpp
0.8ohm
Full load do not increase the noise: 32mV rms and 930mVpp
Tear down
DSC_0753
Some pressure in the vice and it popped open.
DSC_0754
On the mains side there is a fuse, bridge rectifier and a mains switcher transistor. The circuit board has space for a common mode coil, but it is missing.
The low volt side has the optical feedback and one rectifier diode. There is also a indutor.
DSC_0756
Most of this side is covered by the rectifier diode heatsink.
DSC_0757 DSC_0759
Look careful at the two low voltage capacitors. One has a flat top as they are supposed to have, the other is bulging. This is very bad and shows that the capacitor is just about dead.
DSC_0758
The mounting of the transformator is not very good, the pins was not pushed fully into the circuit board before it was soldered.
DSC_0755
There are two chips on the bottom, U1 is the mains switcher controller and U2 is controlling the optical feedback.
Below the usb connectors are the resistors for coding them.
DSC_0760
Temp2188
M1: 98,4°C, HS1: 130,0°C
The rectifier diode gets rather hot and is heating the capacitor, this might be the reason the capacitor is nearly dead.
Temp2189
M1: 115,4°C, HS1: 131,6°C
On the mains side there is a single resistor getting warm (Often resistors are rated for 150°C).
DSC_0761 DSC_0762
Safety distance in air is 4mm, but on circuit board about 6mm. This usb supply only has 4mm.
Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger gets way to hot when supplying the specified current and the noise is also on the high side. The safety do not live up to the CE requirements, but it is not directly dangerous.
Notes
The usb power supply was supplied by gearbest for a review.
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
Ormbett
Ormbett's picture
Last seen: 5 months 4 weeks ago
Great review as usual, thanks! The first sign of failure is when it pops open with just a squeeze 8)
