All sold out: ReyLight Custom,Lumintop Tool AAA Copper. (Driver available)
502 posts / 0 new
djozz
djozz's picture
Last seen: 13 hours 50 min ago
emarkd wrote:
Just for clarity's sake, this happened with me on NiMH. I've got a house full of eneloops; no alkalines here. Shouldn't matter though I guess - voltage is voltage.
I agree if it is interpreted as: voltage under load is voltage under load. Hmm, no, could be a bit more complicated, perhaps it actually is the resting voltage that is the trigger to get the driver going...
I'm testing a partly drained AAA-alkaline right now, first number: resting voltage 1.34V, output 0.91 lumen (consistent with 24 hour runtime), the light switches on alright.
edit: next number, resting voltage (10 minutes rest) 1.12V, output 0.58 lumen (consistent with ~60 hour runtime), the light switches on alright.
edit 2: I tried to find the drain level where the light does keeps on working when it has been on, and does not switch on once switched off. It seems that right around 1.0V the light refuses to light up on low, wether you come from switch off, or from the high setting (a mode switch also powers the light off for a moment of course). The fun came when the light had a close to drained alkaline battery. On high setting the voltage drops under 1.0V, so when switched to low the light went out. But with the flashlight in low mode but with the led off, the battery recovered and a few seconds later the low mode started working and stayed on. This could be repeated: switched to high for 10 seconds, change to low, no light, and after some seconds *magic* low started working again.
I let the battery recover as well as possible (flashlight on low setting for 20 minutes) and measured the light: 0.53 lumen. So this failure to switch on starts at about 65 hours in the above runtime graph, which is -roughly estimated- the last 10% of the battery's energy. So it is a pity that this light is not able to light until full drain of the cell (unless you do not switch the light off in between), but I do not see this as a major problem. Also NiMh batteries stay well above 1.0V at all currents up to even much less than 10% energy level.
I do not know of course if other copies of this light stop switching on at a higher voltage as mine.
edit 3: a simple test if it is the mode control chip that is not switching on: with the almost drained battery, and the flashlight on high, I half-pressed the switch three times. The led went out and came on 15 seconds later, as expected. But if the chip has functioned all the time, it would have come on in high setting (three half presses from high =high), instead it came on in low, indicating that the chip started from off again.
sandalian
sandalian's picture
Last seen: 2 years 5 days ago
Huray, the boat is moving now.
I'm switching my BLF account into LumenZilla. Thanks!
ChibiM
ChibiM's picture
Last seen: 5 days 16 hours ago
Would it be possible to get this driver as a 15mm board?
djozz
djozz's picture
You could use it floating above a 15mm contact board, the heat produced by this little driver is not that much.
emarkd
emarkd's picture
Paypal sent for 2 drivers. Thanks Rey!
Gunga
Gunga's picture
Last seen: 7 hours 24 min ago
Yep. That’s exactly what I did.
emarkd
emarkd's picture
Anybody else tried a 10440 in this light? I know the instructions given to us say it could burn out the regulator and leave you with a direct-drive light, but did anyone else try it anyway?
ReyLight
ReyLight's picture
Last seen: 1 month 2 days ago
Thank you! All sold out!
vulpes
vulpes's picture
Last seen: 5 months 6 days ago
Thank you Rey and glad this GB worked out so well! Beer
And here is little something I hope you will make affordable to us in the future. :bigsmile:
antiparanoico
Last seen: 3 weeks 6 days ago
WOW!!! Love
I like it.
Depending on the price…
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
Gunga
Gunga's picture
Nice!!!
ChibiM
ChibiM's picture
But please in AA format (as well)!
sandalian
sandalian's picture
Would be super dope if there’s a tritium slot on its tailcap.
But it will make magnet contact less strong (because thicker tail cap).
But will make it look more fantastic.
ReyLight
ReyLight's picture
Looks like a AAA.   All the people are going to have a holiday for Chinese New Year, maybe in late Feb, we can do a GB on this one.
Edit: Shame there is no slot for any trit.
djozz
djozz's picture
So what happened to the switch? Is this version a twisty? That would imply that the major claim to fame of the Tool is lost.
(edit: this must be a version of the Tool Magnet, indeed a twisty)
(edit2: no twisty, see gunga's post below)
Gunga
Gunga's picture
They claim it’s a metal electronic switch. I want one bad!
http://www.lumintop.com/tool-ti.html
LSX
LSX's picture
Last seen: 1 month 4 days ago
Wooaahhhhh now that’s what I’m talking about! I would definitely grab a few of those.
djozz
djozz's picture
...but that annoying mode order again Tired
LSX
LSX's picture
But Rey could organise for a different mode order as part of a group buy.
djozz
djozz's picture
+moon. In!
emarkd
emarkd's picture
Did this just turn into an interest list? I’m in, too!
Really, the driver’s already done. Just put the one from this group buy into that titanium light and I’m ordering it. Or rework it again. The only thing I think it really needs is better 4v support. I’d take it either way.
djozz
djozz's picture
emarkd wrote:
Did this just turn into an interest list? I'm in, too! Really, the driver's already done. Just put the one from this group buy into that titanium light and I'm ordering it. Or rework it again. The only thing I think it really needs is better 4v support. I'd take it either way.
I'm afraid it is a different driver, as I understand this light uses an e-switch.
emarkd
emarkd's picture
djozz wrote:
I’m afraid it is a different driver, as I understand this light uses an e-switch.
Ah. I missed that detail. I like it though, kinda makes me want it even more. Come on Rey, lets have this one fixed, too!
sandalian
sandalian's picture
Additional deep carry clip will also great.
Gunga
Gunga's picture
Yes! The clip could use an update.
RotorHead64
RotorHead64's picture
Last seen: 3 months 4 weeks ago
+ 1 for a deep carry clip… Made of titanium….
bugsy
Last seen: 6 years 1 month ago
I like my copper ReyLight a lot. I kinda regret not buying a second one. The driver is excellent. The “moon” mode is absolutely perfect.
sandalian
sandalian's picture
I received mine, today. It’s beautiful!
emarkd
emarkd's picture
I know exactly what you mean. This little thing is great and has hardly left my pocket since I got it. I couldn’t snag another light, but I did buy an extra couple of drivers just for repair purposes. The copper ReyLight is awesome.
LightVision1
Last seen: 4 years 1 week ago
Your light is absolutely beautiful, thank you Rey.
It arrived perfect, the packaging was just awesome.
I kind of wish I would have gotten two and still looking at your titanium put money is really low at the moment.
Thank You Rey..!!
By the way that factory Worm is just a worm and doesn’t even deserve to be in that family photo, ha
I made this post longer than usual because I lack the time to make it shorter.
