Test/Review of Soshine 26650 5500mAh (Black)
Official specifications:
  • Model: 26650P-3.7-5500
  • Color: Black
  • Cell Type: Lithium Ion
  • Head Type: Button Top
  • Mark Capacity: 5500mAh
  • Actual Capacity: 5300mAh
  • Voltage: 3.7V
  • Rechargeable: Yes
  • Rechargeable Times: 1000
  • Built-in Protected Circuit: Yes
  • Over Voltage Protection: Yes
  • Short-Circuit Protection: Yes
  • Over-Charging Protection: Yes
  • Over-Discharging Protection: Yes
The two cells do not match perfectly (With 26650 it is difficult to get perfectly matched cells) but the capacity is fairly constant within rated load. The protection prevent drawing 7A for a long time.
Conclusion
The cells are sligtly below rated capacity, but they are some of the top capacity 26650 cell and for single cell low current (up to 5A) usage, they work fine.
Notes and links
Compare to 26650 and other batteries
hmm, didn’t someone test these a while ago and got >5500 mah? not sure if that’s with less accurate equipment, or just some variations of different batteries/batches.
thanks for the test anyway, great job!
