BLF A6 FET+7135 Light Troubleshooting and Mod thread
1004 posts / 0 new
Rufusbduck
Rufusbduck's picture
Last seen: 8 months 4 weeks ago
dracothraxus wrote:
Update to my initial problem as described over pages 24 and 25:
After some back and forth Banggood is now sending out another head unit, with no further service beyond that (which sounds reasonable for a budget provider).
And I bought a second one, which arrived today – pop the battery in, and it just works, all the modeshow life is meant to be. I guess it’s hit and miss with these lights.
UPDATE: After charging the battery and putting it back in, the new torch now doesn’t appear to work again… sigh, more debugging.
Will see if the new head fixes the problem with the original.
M
Debugging is a process. The first thing to try varies with the problem. On a light that doesn’t come on the first thing I sound do is remove the tail cap and put a paper clip from the bare metal of the tube to B-. If you get light then the problem is in the tail cap. Loose retainer, bad switch, rubber button pressing on the switch and opening the contact(remember, a reverse clicky turns off with a half press which is just what happens when there’s no play under the button). A light that comes on when the switch retainer is tightened is could have a short somewhere on the switch pcb. Pics would help.
Scott
dracothraxus
Thanks – yep having done that entire process on the previous light was going to go through it again.
However happy news – it just seems like it in turbo mode it cuts out on one protected battery but not the other. One can go to 7 and hold it, one goes to 7 but cuts out after half a second – I assume it’s tripping something. I can step back to 6 and it’s fine.
Flashy Mike
Flashy Mike's picture
Last seen: 3 min 11 sec ago
Probably the protection circuit of the cell.
patmurris
patmurris's picture
+1
You want unprotected high drain to run turbo.
keengeorge
Last seen: 10 months 3 weeks ago
patmurris wrote:
Flashy Mike wrote:
dracothraxus wrote:
I assume it's tripping something.
+1 You want unprotected high drain to run turbo.
Or batteries with a known quality Seiko Protection IC.  wink
Best Regards,
George
SIGShooter
SIGShooter's picture
Last seen: 44 min 51 sec ago
If it’s the protection circuit then it has to be reset correct?
dracothraxus
On mine it does turbo for a moment then cuts out – but I can instantly switch back to level 6 and it works so not sure if that resolves whether it’s the protection circuit or not.
SIGShooter
My understanding is that when protection kicks in then the battery is dead until the circuit is reset. So it doesn’t sound like your issue is due to the battery’s protection circuit tripping.
patmurris
patmurris's picture
It probably depends on the protection circuit… For what i’ve experienced with a few lights and batteries, when the protection kicks in, it does reset by itself as soon as the light is turned off.
This happens to me with the TrustFire mini 01 and 02 for instance, using fully charged TrustFire protected 16340. On high the light blinks at full once quickly and then shuts off. Turning the light off and on again,the light comes on in mid mode. Once i’ve cycled back to high it blinks and turns off again. Once i’ve managed to drain a bit the battery on mid for a few minutes, then it can hold on on high. FWIW.
SIGShooter
Thanks for the info. I don’t use protected cells but at least I know now that they work in different ways.
congo
Last seen: 1 week 4 days ago
I read through all BLF A6 threads, but did not find anyone with the “problem” I have. Banggood made it right, just want to share, maybe someone else will get lights like mine.
The tail cap of my A6 does not screw in fully to the body tube. There is always a small gap, which I think should not be there. I can touch the O ring with my nails in the gap. Actually I thought the body tube was too long, but after ordering an Astrolux S1 which has an even bigger gap, the culprit must be the tail cap incorrectly machined. It is even worse on the Astrolux, which interestingly has a slightly different machining at the end of the body tube, and a smoother anodisation.
Did anyone notice something similar?
Flashy Mike
patmurris wrote:
+1
Or Keeppower 2900 mAh 18650 protected. It’s protection circuit is designed to step in not under about 10 amps.
Flashy Mike
Is the PCB retaining ring completely screwed in?
congo
I think it is, can’t move it easily.
Flashy Mike
Can you show a picture of the inside of the tailcap?
Did you try different cells? Perhaps the used one is too long.
congo
Thanks for looking into this.
First one is the A6, second is the Astrolux S1: http://imgur.com/a/2Jdf9 (sorry for the crappy pics)
Actually, the rubber switch of the S1 protrudes a little from the button guards. Maybe it is overtightened.
I am using Samsung 30Q flattops, they are standard size AFAIK.
Flashy Mike
The pictures look ok, I checked the tailcap of my Astrolux (don’t own the Blf A6) and even after loosening the retainer ring the tube fits – my retainer ring has a smaller diameter than the inside of the tube. But what I see in your first picture: the knurling of tailcap and tube looks different, with my Astrolux it’s the same. Are you sure the parts belong together?
Flashy Mike
Did you try to turn the tube by 180 degrees (clip end of the tube to the head of the light)?
congo
Good question. Never noticed the different knurling, as it is not so pronounced in real life than on the photo. But it makes sense as the tail cap has a bit different anodizing than the body tube. I received the light like this. Maybe the tailcap is from a different unit, switched at the factory.
congo
I have one more thing. Does your light have the small ridge between the clip groove and the O ring?
congo
Yes. The head can be screwed in only halfway Smile
Flashy Mike
No, my Astrolux does not have this ridge. But I would like to have one to prevent slipping of the clip onto the threads during battery change.
congo
Interesting. I have never seen it in any review pictures either.
Rufusbduck
I came across a similar problem in the head of one of the original A6 anodized lights. The threading in the head for the retaining ring was not cut far enough into the head for the retaining ring to press against the driver and resulted in a weak driver ground with only spring pressure creating contact. Since I couldn’t change the threads I soldered two shims to the driver for good contact. To fix the gap just sand the end of the tube until you are satisfied with the looks. Don’t go too far or that lip will act as a stop before contact is made.
Scott
Rufusbduck
It might also just be a cocked switch pcb.
Scott
congo
Will try sanding the end of the body tube, thanks for the suggestion.
ToyKeeper
ToyKeeper's picture
Last seen: 1 week 1 min ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
jescereal wrote:
Has anyone noticed any issues using this driver with …
… a 15 amp Convoy S2 triple with all springs bypassed, 30Q battery, … strobe mode only works sometimes.
Known issue. The driver tends to reset under very high load. Specifically, at the end of a full-power FET pulse, the FET closes so fast that it creates a ripple effect, and if the amps and voltage were high enough, it can make the driver reboot. It’s being fixed in future BLF driver designs, but that’s totally unrelated to what Banggood sells.
patmurris wrote:
I received a bare aluminum A6 two weeks ago and the head section is very slightly skewed.
Mine is the same. Kind of disappointing. The front piece is a slightly smaller diameter than the rest of the body and I can’t swap some of the bare parts with anodized parts due to different threading. QC issues like this are one of the big reasons people have been unhappy with Manker.
Caleb
Caleb's picture
Last seen: 1 hour 54 min ago
Can anyone recommend a good soldering iron for a newbie. I want to try doing some of the basic mods in this post.
Thanks,
Caleb
Rufusbduck
A Hakko or one of the clones. The one I bought had a cold joint inside the wand and fixing that was the last time I used my old 20w Weller. The variable temp and different tips take care of all my basic needs. Hot air reflow would be nice to have but if you don’t assemble boards it’s not necessary. There are several threads on this topic.
Scott
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 1 month 5 days ago
Is it similar on the short tubes (fitting the early BLF A6) on the head-side. The slot for the O-Ring is too wide and the part with the bigger diameter ,on the opposite side to the thread, is too small. Thats why the O-Ring is only half covered.
