BLF A6 FET+7135 Light Troubleshooting and Mod thread
1004 posts / 0 new
zeremefico
zeremefico's picture
Last seen: 5 hours 45 min ago
Thanks TK.
Lvp will work with other firmwares or it will need modification?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
ToyKeeper
ToyKeeper's picture
Last seen: 13 hours 9 min ago
Depends on which firmware. In most cases though, you’ll at least need to set the LVP threshold to match the physical driver it’s running on. Those values change from one model to another, between brands, etc.
argolite
Last seen: 1 week 1 day ago
Thanks to DB Custom (and other posters that I can’t locate) for tips on improving my bypass:
niko82
Last seen: 4 years 3 months ago
How to turn of turbo timer ?
ToyKeeper
ToyKeeper's picture
Turning off the turbo timer on the BLF-A6 requires flashing modded code onto the driver. The code is available, but it needs about $10 or $20 worth of other hardware for the flashing process.
kaizer
I have the Astrolux version and it recently gets a spring bypass upgrade.
It gets hot much faster now and gets uncomfortably hot after putting usage.
Is that normal it there’s something I’m missing?
ToyKeeper
ToyKeeper's picture
kaizer-ish wrote:
I increased the power and now it gets hot faster.
So… it sounds like the spring bypass worked. Thumbs Up
kaizer
Hi TK, thanks for the explanation. Love your work Thumbs Up
lohtse
lohtse's picture
Last seen: 9 months 5 days ago
Looking to do the Spring mod but notice something odd with my tail cap switch… It has the main spring as it should do but the is a smaller spring made if thinner wire loose (see attached image)https://1drv.ms/i/s!AmKZHSJEsyYco00q9s6AvQ0_K6eu
Anyone know why or what it’s there for????
Problemes d'erection [url=https://www.viagrasansordonnancefr.com/]viagrasansordonnancefr.com[/url] meilleure pharmacie
Wieselflinkpro
Wieselflinkpro's picture
The inner spring is for lower resistance and higher amps / lumens. But it should be soldered to the board of cause.
lohtse
lohtse's picture
oh eer urm
so it should be there to do the spring mod then????
what would you suggest I do to correct this?
djozz
djozz's picture
Last seen: 8 hours 35 min ago
lohtse wrote:
oh eer urm
If you do the spring mod (bypass with a wire), the inner spring is not needed, it will not do much. You can just remove it if it is loose already.
lohtse
lohtse's picture
Cool thats great..
Question….Is it possible to do a TEMP mod to check and see if I really need it?
djozz
djozz's picture
What is soldered can be unsoldered no problem.
rizky_p
rizky_p's picture
Last seen: 2 weeks 29 min ago
Can anyone reminds me what the firmware that came with the A6 called? Bistro?
khas
Last seen: 4 days 1 hour ago
ToyKeeper
ToyKeeper's picture
Sometimes the answer is in plain sight. Big Smile
(the code was written specifically for that project, so I named it after the project)
Joey Adams
I still think for that specific light, your firmware is just about perfect. If that light is putting out 1500 or 1600 lumens and is triggered by accident in your pocket, 30 seconds step is very much appreciated. Fun fact: my mother in-law saw my a6 sitting on the coffee table and turned it on and didn’t see any light so clicked it on off, then looked into the end of it and clicked it again. That was honestly a slow motion train wreck that I had no intention of stopping. Priceless!!
Thanks TK, I love Bistro but the blf a6 and associated mother in-law stunning will forever hold a place in my hall of fame!
ToyKeeper
ToyKeeper's picture
As it turns out, the mother-in-law stunning is a pretty well-documented part of that light.
http://budgetlightforum.com/comment/1115819#comment-1115819
rizky_p
rizky_p's picture
khas wrote:
I believe it’s just called BLF A6 :
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/view/head:/ToyKeeper/blf-a6/blf-a6.txt
thanks.
lool so true, if i remembered correctly BLF A6 uses attiny13 right so bistro should fit right in?
also got convoy S+ can i put BLF A6/Bistro on in too, i dont like the 3 modes on this flashlight.
Phlogiston
Phlogiston's picture
Last seen: 2 weeks 1 day ago
I did that to my sister with an Astrolux S41S. I was wearing it on my belt, she was curious about it, so I handed it over. Never even thought about what would happen next.
click puzzled look click pause click
NOOB COUNTERMEASURES ACTIVATED
Once and once only. I simply don’t let anyone touch my A6-class lights now.
After all, I have plenty of nice, safe BLF-348s and sub-500 lumen Convoy S2+ lights for them to play with instead Smile
ToyKeeper
ToyKeeper's picture
rizky_p wrote:
if i remembered correctly BLF A6 uses attiny13 right so bistro should fit right in? also got convoy S+ can i put BLF A6/Bistro on in too, i dont like the 3 modes on this flashlight.
Bistro requires tiny25/45/85, and won’t fit on a tiny13.
BLF-A6 works on tiny13 drivers but requires an offtime capacitor (OTC), and prefers two power channels.
Biscotti works on single-channel tiny13 drivers like Convoy uses (nanjg/qlite/FX-12), with no extra hardware. There are also a bunch of others which work on Convoy drivers, like gchart’s “babka” and _the_’s “TheStar”.
The “INDEX” file in the firmware repository has more detailed information on all this.
rizky_p
rizky_p's picture
I see thank you for the explanation.
CircaM
Last seen: 2 months 4 weeks ago
What size do I need replace the Tail Button and O – rings? (I want to add some GITD coolness)
And what is the “Paper Clip” mod?
BobbyMK
BobbyMK's picture
Last seen: 1 day 22 hours ago
I have small issue here, i want to use BLF bistro driver with lighted tailcap. Is it possible and what kind of mods are required for this to work without problem? As far as i know i need bleeder resistor but is that all?
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
g_sintornillos
g_sintornillos's picture
Last seen: 1 year 6 days ago
No problem, no mod
The Bistro has the bleeder resistor
It is the 470R (471) on top, beside to red wire
In the BLF A6 you must add the bleeder resistor
Sorry for my bad English (gogole transtorla)
BobbyMK
BobbyMK's picture
But it does have the NMM with the lighted tailcap, works fine with normal one.
Litefighter
Litefighter's picture
CircaM wrote:
What size do I need replace the Tail Button and O – rings? (I want to add some GITD coolness) And what is the “Paper Clip” mod?
I’m unsure of the o-ring size but the A6 uses 14mm tail caps.
http://s.aliexpress.com/JRJzUfaE
I have one of the above installed and it glows brighter than Convoy’s glow-in-the-dark tail caps.
jetro
Last seen: 1 year 9 months ago
Hi, my first post.
I recently got 2 A6 from banggood on sale (16€ I think)
I got the warm and the white version. Now the white verson blinks much slower (strobe,bikeflash, bat check)
I seem to recal reading something about old drivers beeing under-clocked when i did my research, but i can’t find it anymore.
Is there a fix? did banggood just dump some old stock on me?
If I would replace the driver, is there a ramping alternative? (I really like the Q8 software)
Rob_K
This driver with Crescendo FW and you have ramping
