BLF A6 FET+7135 Light Troubleshooting and Mod thread
1004 posts / 0 new
d_t_a
Last seen: 21 hours 2 min ago
Flitsmal,
turn on the flashlight first (full-press)
then half-press 15 or more times, until the flashlight will do a sequence of 2 blinks. (observe first, don’t do anything yet).
Be observant when it does that “blink — blink”, pause a short while, then another “blink — blink”.
You need to turn off (full press) during the first “blink — blink” (after the 1st blink but before the 2nd blink) = this will switch from 7-modes to 4-modes or vice versa. (ie. blink — [turn off])
Now, to toggle mode memory, do the configuration again, wait for the “blink — blink”, then “blink — blink”) (ie. blink — blink, pause, blink — [turn off])
Flitsmal
Flitsmal's picture
Last seen: 5 days 1 hour ago
Hi d_t_a,
Thanks for the quick reply, I have tried thanks, but it will not go to those blinks, it just continues to go through,low,medium,high,turbo. And like I said, there seems to be no moonlight
Hi, my name is Anton, and I’m addicted to flashlights.
Cereal_killer
Cereal_killer's picture
Don’t bother counting 15 clicks out, power it on and just half press it until it stops getting brighter.
MRsDNF
MRsDNF's picture
From memory you have to start the quick presses from low mode and moonlight was only on the seven modes. Keep pressing quickly until the light stops responding to your presses.
Flitsmal
Flitsmal's picture
On further reflection,I might have damaged the driver with over voltage, I was testing with a power supply, and a battery, and instead of using a multimeter on Amps, I accidentally added 4V from the power supply to the back of the battery… Facepalm the bond wires on the led blew, but I am lucky enough to have those fixed at work Big Smile So, I fixed the led, but maybe the driver was damaged in some way with the 8 V I combined whenI added the power supply to the battery.
It’s just the moonlight I miss really, as I still have at least 4 modes, with the quick access to Turbo….
Thanks for the inputs
Cereal_killer
If you’ve still got modes its still working.
Does this light have a lighted tail cap?
SIGShooter
SIGShooter's picture
Last seen: 2 hours 2 min ago
The modes were doing really weird things on one my lights after I did a spring bypass. I reflashed the driver and that fixed the issues. If you have the know-how perhaps you should consider doing that.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
Flitsmal
Flitsmal's picture
No lighted tail cap that I am aware of. I put the driver in my old BLF Eagle Eye X6.
No, I don’t re flash drivers, that’s just creepy/weird LOL
But it definitely has no moonlight now, I can’t get to the 7 modes or the configure modes, and the battery checker doesn’t blink, it just stays low( But I know it’s the battery checker mode, because it has the strobe before, and the bike flasher after…)
Cheers
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 46 min ago
Sounds like maybe the 7135 chip died, which would also cause the battery check mode and config mode to not look like they work. The amc7135 chips don’t respond well to excess voltage, even if other components survive.
d_t_a
I see. how do AMC7135 chips usually die? Aside from over-voltage? How about over-current? or other scenarios?
ToyKeeper
ToyKeeper's picture
Usually just from excess voltage, which makes them overheat and burn out. Afterward they usually stop responding to the MCU and let a constant amount of current leak through. This would make all the 7135-only blinky modes stop blinking, and would make moon and other 7135-only levels all look the same.
thisnameisvalid
thisnameisvalid's picture
Last seen: 1 day 18 hours ago
Anybody know where I can get a new reflector? I had a little accident with mine Facepalm I’m currently using a smooth S2+ one but it doesn’t have a groove for the oring.
Cereal_killer
I’ve killed more with excess heat [during soldering] than any other way.
I ONLY reflow 7135’s now, not that you can’t still overheat them but I find I have a whole heck of a lot lower failure rate with hot air then I ever did with an iron.
hodor
hodor's picture
Last seen: 5 hours 40 min ago
Is there a way to test the 7135 is ok, say with a multimeter? I suspect mine may have also gone as it appears to be stuck in the highest 4 brightest modes and I can’t cycle to the config menu.
toddcshoe
toddcshoe's picture
Last seen: 1 hour 41 min ago
You didn’t try to put a lighted tail cap in it did you? I know that will cause that problem if a bleeder resistor isn’t used when installing the lighted cap.
"Everywhere I go, there I am"
hodor
hodor's picture
Nope, everything as standard. I believe the lighted tailcap issue is that mode memory won’t work correctly, i.e. mode memory will be on even if set to off.
toddcshoe
toddcshoe's picture
I see. I think this thread is what you are looking for.
http://budgetlightforum.com/node/26887
hodor
hodor's picture
Thanks, I’ll take a look.
Cereal_killer
hodor wrote:
as it appears to be stuck in the highest 4 brightest modes.
Are there holes in the UI? In lower modes the FET isn’t on at all so if the 7135 has gone bad there will be modes (moon & lower modes) where there’s zero light output. If that’s not the case it’s probably not the 7135 being bad…
Anuway to test the 7135 you jumper the right pin to Vcc, this will make the 7135 turn in full (0.35A) which you can measure to confirm its good.
ToyKeeper
ToyKeeper's picture
If I recall correctly, the 7135 chip tends to fail in a way which passes current, so it would have the same brightness regardless of the PWM signal sent to it. If the lowest few modes are all the same, that may be what happened.
hodor
hodor's picture
No holes in the UI. Essentially the light has 4 modes consisting of the brightest 4 modes of the 7 mode group (compared against my other A6).
Thanks for the info on testing the 7135, I’ll take a look when I’m back home.
Would a failed 7135 prevent access to the config menu?
Cereal_killer
There must be multiple failure modes possible then cause I’ve had more than my share of them suffer heat related deaths in which they have zero output. The only time I’ve had them fail in a way which causes them to stick open is in over voltage scenarios (2s builds).
Tom E
Tom E's picture
Last seen: 6 hours 32 min ago
My experiences have been what TK mentioned - they fail for me wide open. I've killed several this way on my modded 35K lumens XHP50 based light, and in a couple triple XHP70's I modded, all with FET+1 drivers. Ohh yes, same thing CK is saying - all in high powered 2S builds.
AmberFlo
Last seen: 1 year 3 months ago
it is possible to adjust current in firmware of a6 driver? i want to get about 4,5A-5A in fet turbo mode
Tom E
Tom E's picture
Well no, not exactly. Firmware has no control over a FET based driver accept for PWM'ing to lower the effective amps, but not to any exact amperage level - it can't read back amps, can't adjust accordingly. You could add resistance (thinner, longer LED wires for example), but that depends on the cell also.
beachdrifter
Last seen: 11 months 1 week ago
Hi everyone, my first post here, my first flashlight which was recommended to me.
I just got it in the mail, but have the following issues:
I press the button (click), and nothing happens (this is where moonlight should be). A half-click gets me to a low setting, the next half-click to the exact same setting (definitely identical), and then it gets all the way up to turbo. So basically I’m missing 2 out of the 7 modes (moonlight and low or med1).
In the second group (supposed to be 4 different modes), the first two modes are identical (so it’s 3 instead of 4).
Switching between the groups is possible, but there are no two blinks as there should be, it’s just dark, I can still get it done just by guessing.
Battery check also does not work.
Is this a known problem/easily fixable by a noob, or do I have to send the lamp back?
Thanks in advance for your feedback!
ToyKeeper
ToyKeeper's picture
It sounds like a hardware problem, like the driver has a bad amc7135 chip. It’s not easily fixed unless you have some of those hanging around and know how to resolder it.
beachdrifter
Thank you so much for your reply! Thumbs Up Too bad that the first flashlight I order from China has this, but I’ll see what the vendor will say!
I really have no experience in the field whatsoever, naively thinking there might be something like a “factory reset” to fix this! I guess I’ll just have to wait for a few more weeks then.
d_t_a
I recall that sounds exactly the same behavior as a (defective) Astrolux C8 or S41 (both use BLF A6 driver) that I encountered before…
Espresso
Hi all, new here and still a relative noobie with the A6.
Seems I’m also experiencing the same issue with being unable to access the configuration menu with 15+ taps. The light simply keeps on cycling through the levels until it settles on moonlight after repeated taps but no blinking into configuration.
So far I’m liking it much, except I’d really like to enter the configuration mode to tur on memory mode like I have on my others like my Thorfire C8s.
This is a stock BLF Special Edition A6 from Banggood, no tweaks, no mods. Any ideas? Defective?
