18350 question
8 posts / 0 new
tenohfive
18350 question
I’m looking for a couple of decent 18350 cells to go with a Nitecore MT-10C light. I don’t really know where to begin – any suggestions? Is there a clear leader, or would something like the KeepPower 900mah cells work?
Streamer
Streamer's picture
Last seen: 2 years 4 weeks ago
The AW's are nice.  (The red AW's are IMR)     Any brand 18350,  except the  XXXFIRE brands, should be acceptable. Wink
ETA:    You will benefit in Amp Draw from IMR type Cells.     Efest  has an IMR type 18350         http://budgetlightforum.com/node/16589
http://www.mtnelectronics.com/index.php?route=product/product&product_id=132&search=+18350
Firelight2
Firelight2's picture
Last seen: 1 hour 50 min ago
The Efest purples are really nice.
You can find them at Mountain Electronics
SubLGT
Last seen: 7 hours 21 min ago
The AW 700mAh version is my #1 recommendation, and what I bought for my Armytek Prime C1 Pro. If you can’t get that, then get the AW800mAh, but testing shows it to be slightly inferior to the 700mAh version in V and capacity.
Rtdvapor.com has the genuine AW 700mAh for under $7 each.
According to HKJ’s tests, at a load of 2A or lower, the Windyfire 700mAh and the AWT 800mAh are close in performance to the AW-700.
The Efest 18350 batteries are unimpressive in capacity.
Nicolaas
Last seen: 1 year 12 months ago
Make sure you light has a low voltage warning before you use unprotected IMR cells………!
Otherwise you run a substantial risc to overdrain your cells.
And yes, both AW IMR (red) and Efest (purple) are good cells, that will easily do up to 5A!
Grtz
Nico
Ronin42
Ronin42's picture
Last seen: 2 years 2 months ago
Any that RMM aka Moutian Electronics has! are fine.
Factory lights as opposed to Vaping will not run into big Amperage needs.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Boaz
Boaz's picture
Last seen: 4 min 24 sec ago
He's in the uk
Nicolaas
True.
There aren’t that many good 18350 anyhow, and with PCB is even harder to find.
I did notice however, that Nitecore is selling a protected 18350 under their own brand name so…….order two of them together with the light perhaps?
Grtz
Nico
