Test/Review of Xiaomi 3 USB Power Strip
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 23 min ago
DSC_0411
Official specifications
  • Port: 3USB+ 3 Internation combination power jack
  • Brand: Xiaomi
  • Fast charge
  • Overload protection: 10A
  • Rated input: 10A, 250V
  • Rated output: 10A, 250V
  • Rated power: 2500W
  • USB module input: 100-240V, 50/60Hz, 0.5A
  • USB module output: single USB, 5V 2.1A(TYP)
  • Three USB, 5V 3.1A(TYP)
  • Use of the environment temperature: -10°C ~ +40°C
  • Safety resistance: 75N
  • Support 2A fast charger
  • Weight: 300g
  • Product Length: full-length 1.8m
  • Size: 22.5cm*4.1cm*2.6cm
I bought this from Banggood
DSC_0403
The charger/power strip was in a long box.
DSC_0405
It contained the charger/power strip and a instruction page in probably Chinese and Chinese 3 pin plug.
DSC_0409
The mains socket can mate with EU / US 2 pin plugs.
DSC_0410 DSC_0413
DSC_0412
Measurements
  • The mains plug is a Chinese plug with earth.
  • Universal sockets on the strip do not fit UK plug or any EU/US earthed connections.
  • With power strip turned on, but unloaded it uses 0.2 watt
  • All Usb outputs is with auto coding up to Apple 2.1A
  • Usb outputs are in parallel.
Xiaomi%203%20USB%20Power%20Strip%20%231%20load%20sweep
The output voltage drops slightly when loaded and then stays fairly stable. There is overload protection at 3.3A.
Xiaomi%203%20USB%20Power%20Strip%20%233%20load%20sweep
Same on this socket.
Xiaomi%203%20USB%20Power%20Strip%20load%20sweep
Running all 3 socket in parallel shows that the overload protection is common for all 3 socket, i.e. the total current is 3.3A before the protection kicks in. This means you have to be careful with what devices are connected to the usb power too stay below 3.3A.
Xiaomi%203%20USB%20Power%20Strip%20load%20test
One hour with 3.1A load is not a problem.
The temperature photos below are taken between 30 minutes and 60 minutes into the 1 hour test.
Temp2140
HS1: 67,6°C
HS1 must be the mains transformer.
Temp2141
M1: 48,2°C, M2: 38,8°C, M3: 38,0°C, HS1: 56,6°C
Here HS1 looks to be the mains switch transistor.
Temp2142
M1: 57,8°C, M2: 45,1°C, HS1: 63,3°C
M1 is the rectifier IC.
Temp2143
M1: 49,1°C, HS1: 49,9°C
Temp2144
M1: 48,0°C, M2: 49,7°C, HS1: 71,8°C
HS1 is the mains transformer.
10ohm
At 0.5A the noise is 12mV rms and 280mVpp, this is fairly low.
5ohm
At 1A the noise is 13mV rms and 207mVpp
1.6ohm
At 3.1A the noise is 25mV rms and 390mVpp, even at full load the noise is acceptable.
A short look at the power strip
The specifications says it has overload protection, is that correct?
Overload40A
The answer is yes, with 40A current it trips in about 1 seconds.
Overload20A
With 20A it is about 10 seconds.
Overload13A
And at 13A it is about 4 minutes. These trips times looks very resonable.
All test was done with a low DC voltage.
Tear down
DSC_1723
Beneath the feets was four screws, but that was not enough to open it. Around the edge was a lot of locks that had to be opened.
DSC_1725
On this side there is a input fuse, a common mode coil, a inductor and the mains switch transistor on the mains side. There is a safety capacitor between mains and low volt side, but nothing of interest on the low volt side.
DSC_1726
On this side we have the mains rectifier bridge (BD1) and the mains switcher controller (U1). On the low volt side there is two chips to handle the automatic coding of usb (U3 & U4), but there is no rectifier diode. Instead there is a synchronous rectifier chip (U2).
DSC_1727
On this side is the fuse (Brown block) and the safety capacity (Blue).
DSC_1728 DSC_1730
The common mode coil and the transformer are mounted at the ends.
DSC_1729
The mains switch transistor and the inductor can be seen here.
DSC_1731
DSC_1738
The black box is the switch with the automatic fuse. All connections inside and the sockets are done with unisolated metal.
DSC_1724
There is done a lot for safety in this power strip/usb power supply. The first part is the cutout and plastic shield in the circuit board, that handles nearly all creepage distances, including a good safety margin.
DSC_1732 DSC_1734
At the end of the cutout, there is also enough distance.
DSC_1733
On the other side there is the distance from the mains switch transistor to the usb connector, it must be 4mm and is just about that. Note: The plastic shield is also present in the top part of the power strip and will keep the transistor away from the usb connector.
Testing the mains input with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
Just about everything looks fairly good on this power strip, but I have a few complains:
3A is not much current to share between 3 usb sockets, especially not when they all will report 2.1A capacity.
I would have liked if it could handle earthed connections for EU plugs, but that would probably spoil the versatility for other plugs.
If you can live with the limited usb power and the accepted mains plugs I believe it is a good power strip/usb charger, but it will probably be a good idea to replace the mains plug with one for your area.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
coolz
Last seen: 5 years 10 months ago
awesome! Thanks a lot HKJ!
i bought 2 of these
Ormbett
Ormbett's picture
Thanks for a great review!
+ 1
will34
will34's picture
Last seen: 52 min 23 sec ago
Somehow i missed this review.. Thanks!
Too bad Xiaomi is not making one with a US plug, I even considered using an adapter for it but the lack of earth connection is a no go.
